Question about Kodak Office Equipment & Supplies
Advance Fwd & Bkwd does not work? - Kodak Office Equipment & Supplies
    President:
  • Kodak Master
  • 412 Answers
When the advance & reverse stops working on an older KODAK Slide Projector, chances are that it has a broken "link" that connects the cycle solenoid to the slide change mechanism. An authorized repair dealer can fix this for you.
Posted on Nov 03, 2010
Ran over a tree root and bent a blade. Replaced blades. Checked belts. Belts are fitting loosely. Mower won't shift into gear fwd. or bkwd. Transmission not engaging. What might be the problem?
The gear would, obviously, have been engaged when you hit the root. I presume this will have caused some resistance in the friction material of your transmission. Consider the engine rotating the trans and the root stopping it from rotating, the transmission and the blade will have borne the brunt . Have your transmission checked for damage
Jul 16, 2015 | Garden
Phone rings 4 times then goes to message I want it o keep ringing
Basically, you want to disable Forward No Answer to voicemail:
Feature ** CONFIG
Terminals&Sets
enter ext #
advance past Line Access to Capabilities
go to Fwd No Answer
CHANGE softkey to None
go to Fwd On Busy
Jul 01, 2014 | Nortel Lands Phones
Volume control.have craig mp3 player cmp616f. how do i turn down volume ?
press the volume control once - the speaker picture on top should blink, then press the fwd or bkwd buttons on either side. if the speaker does not blink, press the volume control again. do not hold the volume control in.
Feb 16, 2011 | Craig Audio Players & Recorders
I have an old model of Panasonic PBX system Model D816. I am connecting the main telephone device Panasonix KX-T7730 to Ext. No. 1, this main telephone device has no line and the FWD/DND button light is...
What are the other phones? a 7730 is an analog PITS phone and requires 4 wires to make it work. If you connect it to a digital jack, the data lets it indicate key functions, but there is no voice, and that sounds like what you have. Try taking a 4 pin base cord and plugging directly into port 1 of the 816 and see if everything works. If it does, you have your answer.
In passing, the FWD/DND light will flash if there's a forward or DND condition on the phone. Dialing 7100# from the intercom will clear all FWD/DND conditions, as will pressing the button until nothing lights.
Your delephone reference doesn't mean anything to me.
Carl
Sep 05, 2010 | Panasonic KX-T7730 Corded Phone
Slide advance forward or backward does not work. When depressing the fwd/back buttons, can hear a slight buzzing sound. Need to find out how to unjam fwd/back motor device.
By your description, chances are you have a broken solenoid "link". This "link" connects the cycle solenoid to the slide change mechanism. Over time these plastic "links" get brittle and crack. This is not an easy repair, but there are still parts available. Contact a factory-trained repair dealer to get this repaired correctly, and it should run another 20 years!!
Apr 17, 2010 | Kodak Office Equipment & Supplies
Panasonic KX-TG2583. How do I change the time?
TIME/DATE ADJUSTMENT:
Press Function/Exit/Ch on the handset.
Press the up & down arrow keys until it points to 'program'
Press the Fwd/Edit > (yes key)
Press the up & down arrow keys until it points to 'tad program'
Press the Fwd/Edit > (yes key) the base unit will now display programming opitons.
Press '0'...'set time' is announced
Enter the time (hour & minute) using a 4-digit number
(Ex. To set 9:30 enter 0930)
Press * to select AM or PM
Press # repeatedly to set the day.
SELECTING THE NUMBER OF RINGS:
Press '2'...the current setting is displayed on the base unit
Press 0 or 2 or 7 to set the number of rings
(0='Toll Saver, 2=Two rings, 7=Seven rings)
Press Fwd/Edit (save key) a beep will sound
To return to normal mode press Function/Exit/Ch
I HOPE THIS HELPS! I copied it from my phone manual!
Best of luck!
Emma
Jul 22, 2009 | Panasonic GigaRange KX-TG5432 Cordless...
I have no manual and I need to set the time on a kenwood kdc-mp205 stereo
press the "SRC" button repeatedly to select the standby mode. "ALL OFF"
Press the MENU button for at least one second.MENU is displayed and the menu is turned on.
Keep pressing FM button until the SET CLOCK appears in the display.
Press the FWD button for at least two seconds to enter the time adjustment.
Adjusting the hours,press the FM button to advance the hours,or the AM button to make the hours go back.
Adjusting the minutes,press the FWD button to advance the minutes or press the RWD button to make the minutes go back.
Press the MENU button to end the menu mode.
and BINGO.
Mar 23, 2009 | Kenwood KDC-MP205 CD Player
FWD Car Traction Problems
yea man u have a very loose nut between the seat & the stearing wheel! Lol!!
Mar 13, 2009 | 2006 Renault R5
I need the number on the computer (ECU) nissan Stanza 87 SW, STD,FWD
Hi... On your question For ECM to 1987 Nissan Stanza..
Are 6 Available number .
2 are for vehicles 4WD. Incl. wagon. Calif emissions. 2261A-20R66RE,
with out calif, 2261A-20R06RE,
2 For vehicles FWD Wagons only. Calif emissions, 2261A-20R75RE,
With out Calif emissions, 2261A-20R15RE.
2 For vehicles Sedans FWD Exc Wagon. Calif emissions, 2261A-D5507RE,
With out calif emissions, 2261A-D4507RE,
NOTE , " RE" Mean Remanufactured ECM. Is not available new.
Ok.. Are the number I have Based on Mitchell ondemand, Repair Software.
I hope this info help on your question.
Any more questions let me know...
Nov 07, 2008 | 1987 Nissan Stanza
153 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
