Question about Carrier 38CKC036 Air Conditioner
Tripping my breaker when the compressor tries to come on. The condensor fan has a really slow start and never reaches normal speed. Do you have a solution?
  • Michael Nichols Sep 27, 2010
    I will try your solution, Thank you!
  • 1,711 Answers
Replace the compressor starting capacitor. This might be the problem. If not then the compressor need to be replaced.
Posted on Sep 27, 2010
Poured a beer and noticed temperature reading of 56F. Compressor not running. Notice a periodic clicking sound.
The clicking sound is the compressor overload tripping out and resetting. For whatever reason, bad capacitor, bad relay or locked up compressor....the compressor is not starting. Of course it could also be overheated due to a defective condensor fan motor or extremely blocked condensor coil.
Dec 12, 2014 | Refrigerators
Fan moves slowly ,compressor still hot even with a portable fan blowing on condensor ,but temps are back to normal. What would cause the fan to blow slowly and there is no obsructions
Ralph78yanks,
Your condenser fan (fan motor by compressor) is a variable speed and controlled by a computer board and compressor speed. If the fan motor slows down and the compressor is running in high, the unit can over heat and cause temperature issues in refrigerator sections. GE has a program which can see actual fan RPMs of motor. As I research this incomplete model number (7 possible different models) I see they all use the same fan motor Part# WR60X10209, this is a DC motor. Make sure you fan has not melted also. The heat from the compressor can melt the should or blade when this motor fails. I hope this information helps you..
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 11, 2011 | GE Profile PSW26P Stainless Steel Side by...
I have a window unit in which the fan appears to have stopped. It is a eight year old unit but was working fine last season. It was when I started up this year that this occurred. I also noticed that it...
The reason your breaker is tripping is when the fan stops running the compressor is having to run at much higher amps than normal. The replacement of the fan can be very difficult to reasonable. The fan sometimes can be removed then cleaned up (remove all dust, lint) then just lightly oiled to free it back up. Good luck and try to have fun.
Jun 10, 2011 | Heating & Cooling
Is it possible for a delfield freezer 6151 XL-S to trip a breaker every 2-3 hours if the TXV valve was faulty letting liquid get to compressor. This unit has had controller and relay start assembly...
I would look to see if it is tripping during the defrost cycle. One of the heater elements my be faulty. Never heard of a bad TXV causing a breaker tripping, but I guess it's possible. I would adjust the superheat so that it is about 6 to 8 degrees just prior to unit reaching temp and shutting off. I'd start there.
Apr 01, 2011 | Delfield Freezer 6151XLSR Stainless steel
With the thermostate off the interior fan runs but when i turn the thermostat on it trips the breaker
Not good! The thermostat only supplies power to the compressor section, so a breaker tripping is a sign of a 'dead' short to that area. If lucky, it just an exposed wire or terminal connection damaged in that area, but rarely the cause. More likely is compressor mtr "locked rotor", or stuck "potential" start relay holding the mtr circuit in hi-amp load, or shorted internal motor winding's. The condensor fan can also short closed, but is rare due to it's design. I have to assume the electic breaker suppling that circuit is not failing, as cause?
Jul 09, 2010 | True TD-95-38-LT Beverage Cooler
Ckl60-1 having a prob with the condensor tripping
Could be a few things wrong here. If it only happens when the unit is starting up, I recommend getting what's called a "kick start" capacitor. You can buy them at most HVAC supply houses, and they're very easy to install (just turn off the power first, and if you're uncomfortable working on 240 Volts, please find someone who is experienced).
The older a compressor gets, the more apt it is to have some resistance in the coil windings. These kick start capacitors essentially give the compressor a "boost" to get started. One reason that your breaker may be tripping is due to what's called an "inrush current". Compressors (and other inductive motors/loads) use a large surge of electricity to start running. This surge can become larger as the compressor ages, and can exceed the threshold of the breaker.
Whatever you do, DO NOT replace the breaker with a higher amperage breaker. This effectively just makes the wires in your walls a large heating element, and is a good way to burn down your house.
If, however, your breaker trips after the condensing unit has been running a long time (or on very hot days), try cleaning the coils. Most people don't realize that the outdoor coils should be cleaned regularly, and when the get covered in dust/dirt/pollen, they can't reject heat. As a result the Freon pressure gets higher and higher inside the compressor, which can cause the amp draw to rise dramatically.
Good luck.
Aug 25, 2009 | Goodman Heating & Cooling
A/c is drawing 20 amps and keeps tripping breaker after running
If the fan is running and the compressor is getting hot and tripping off you may have a failed capacitor.
Jun 29, 2009 | Dometic Rooftop RV Air Conditioner
Turn the unit on, the fan runs, and when the compressor tries to start the fan slows down and the compressor will not run. After a few seconds the fan speeds back up. I put an amp meter on the compressor...
sounds like you have a bad capacitor, if it's not tripping the breaker it doesn't sound like the compressor is drawing LRA unless the breaker is oversized for the condenser.
Apr 24, 2009 | Heating & Cooling
I have a payne 04 3 ton heat pump it flips the breaker when you turn it on but does not blow the inline fuse.the blower motor and electric heat strip comes on and works .troubleshoot
grounded or shorted compressor. remove power. remove compressor leads and tape off . does breaker stop tripping? if it stays set on, then compressor is gounded or shorted. if it still trips then wiring or condensor fan is shorted or grounded, remove wires there and test same way . the item you disconnect that keeps breaker from tripping is your shorted or grounded item. usually the compressor. time for all new 410 a equipment. r22 is obsolete and out of production next year and equipment, and oils ,and gases dont mix at all. it must be all or nothing. don't invest a big cash repair in something unusable in a few years. good luck.
Dec 07, 2008 | Heating & Cooling
Only fans work on split system model ls-k2463hl earth breaker trips when compresor tries to start
Does the compressor try to start and the shuts off or is the breaker slamming off as soon as it is turned on. If it takes a few seconds the comp could be locked up and trying to start, high amps and tripping breaker. Tripping breaker right now would indicate a shorted or grounded compressor. Really would need to be ohmed out with a meter to check for ground. Not good either way.
Apr 25, 2008 | Heating & Cooling
Carrier 38CKC036 Air Conditioner Logo
139 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
