Orion STV2763 27" TV Logo
Posted on Sep 27, 2010
I cant adjust the color, brightness, and contrast on my Orion TV set model stv2763 I have no original remote to this set. Can the use of other remotes solve my problem as there are no buttons or dials on the tv itself to make these adjustments. Marty
5 Related Answers
Anonymous
  • 556 Answers
  • Posted on Oct 01, 2007
SOURCE: Get into service mode
if it cannot be adjusted then there is a problem in tv. as your green color is absent you will get red+blue=purple your problem is in green video ckt please check 1 sypply to green cathode ckt 2 loose contact in crt base 3 loose signal connector 4 check components related to green cathode& green video tr. itself 5 check for green signal is coming to green video section from processor. 6 signal processor ic if you are not tech person get it done by skilled tech. it is a common problem. it is a not a major problem. please check
Anonymous
  • 62 Answers
  • Posted on Feb 23, 2008
SOURCE: Orion model 1929
Hiii...
Mightbe you can buy a universal remote on the market what support your tv set ?
Than's
[Vrya]
Anonymous
  • 57 Answers
  • Posted on Mar 11, 2008
SOURCE: Orion TV remote
my orion if you channel down below channel 2 it goes to aux.
Anonymous
  • Posted on Apr 27, 2008
SOURCE: cannot adjust the color, brightness, contrast etc, using my olevia remote
Well....uh....duh....I'm sort of embarassed to say I had the TV set on High Def TV. (LOL) Once I put it back to Standard Def TV, I was able to adjust the color and so forth. Oh well, you never know, someone might need this solution. TA DA!
Anonymous
  • 233 Answers
  • Posted on Dec 25, 2008
SOURCE: Convergence Problem and Contrast Adjustment
Have you checked all of the resistors inthe convergence circuit as well? If not, check them for the correct impedance.. Remember, you have to pull one side of the resistor out of circuit to measure it correctly.
If all of the resistors are good, then you have to do a coarse convergence adjustment on the set through the service menu.. if you need the service manual for the convergence directions, I have one uploaded in the technicians corner of techlore.com
2answers
How do I adjust the "Brightness" on my 20 year old Model TXJ 2566 Samsung TV?
Hi Norman Malkin, to adjust the brightness of your Samsung TV, you must enter Menu, select Image, display a list where Contrast Brightness Color and other parameters appear, select Brightness and increase or decrease the brightness to your liking, you may need make Color and Contrast adjustments
I hope you can adjust it
Greetings Franco Dosil
Hola Norman Malkin, para ajustar el brillo de tu TV Samsung, debe entrar en Menu, selecciona Imagen, de desplegara un listado donde te aparece Contraste Brillo Color y otros parametros, selecciona Brillo e incremente o disminuye el Brill hasta tu gusto, puede que necesites hacer ajustes de Color y Contraste
Espero lo puedas ajustar
Saludos Franco Dosil
3helpful
The remote does not work and the tv will not accept an universal remote.How can I adjust the color, brightness, contrast, and etc. with out a remote. The screen is dark and can not be adjusted without a...
Tries press the tv menu button on the tv front frame bazel to select color,brightness,contract so on...Adjust ur setting.Try website like remotes.com to buy an a exact to the original remote.
2answers
Can't adjust color, brightness, etc. w/universal remote
Use the MENU on the front panel display of the
TV
I cant change input without a remote how do i do this?
Unfortunately Orion has no other way to switch the inputs but with the remote. www.remotes.com has an original remote. Thanks
Sylvania 27" derailed by Emerson universal remote
CHECK YOUR TV MANUAL FOR REMOTE INSTRUCTIONS IF STILL HAVING PROBLEMS CALL EMERSON AND TALK TO THEM ABOUT YOUR PROBLEM
Orion stv2763
You need the original remote to access the menu system in your set. Most all the TV's on the market are like that.
Jerry G.
Get tv off of 16:9 ratio without original remote.
You must have the original remote. Do a search on the net for Orion customer support toll free number
Sound
The SAP must be turned off and you must have the original remote apparently. I would do a search for Orion customer support and get a remote.
27 inch Orion
the best way to do it is by having some color bars on Tv and then do the setting by eye. it is the best way to go. you have to adjust the brightness, contrast, color and sharpness. good luck
Top Orion Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
