I have Toshiba Portege M700 ,which my daughter was playing with it and setted bios password on the laptop, please, help me to bypass the password. I need the response code to bypass the bios password
  • 1 more comment
  • ansusteven Sep 27, 2010
    I have tried "Toshiba" or "toshiba" and it did not work. The operating system is windows vista
  • ansusteven Sep 28, 2010
    please, I do not have access to the system, when I turn the laptop on the power on bios password is required.please, I have removed the batteris and it did not work
    President:
  • 2,777 Answers
The response code is generated by Toshiba... you can try taking out the cmos battery, but that is a whole operating in itself requiring complete dis-assembly of the laptop itself, and even then it is backed up by another battery of sorts if I remember correctly on these M700's. At this point you are going to want to contact Toshiba if they can advise you on how to bypass the password and remove it, they are the only ones, as most of the time people that are trying to do what you are trying are people who have "found" or "stolen" the laptop and are trying to get into it, but of course Toshiba has a way around it. I am definitely not accusing you of doing those things, but am just saying that the only way to get around it is with the help of the manufacturer.
Their number is 1-800-457-7777
Posted on Sep 28, 2010
  • 4,737 Answers
I have few queries, did she set it or did it come up unexpectedly? In many cases, the Bios password comes up unexpectedly. And it's also important to let me know the operating system installed on the system. There are several tools, but it's a little complicated to fix it if you aren't a tech, but I will definitely try my best to assist you.
If in case, she didn't set the password, but came up unexpectedly, then the password should be "Toshiba" or "toshiba" (without quotes).
Let me know the details.
Awaiting.
Thanks.
Posted on Sep 27, 2010
  • Lebanon Raingam
    Lebanon Raingam Sep 27, 2010
    Ok, then try the Command Prompt method :
    This method works only if you have access to the system when its turned on because this method requires MS DOS. Open Command Prompt [click Start and then type in "cmd" in the search here box and press Enter] from Programs menu and provide following commands one bye one:
    debug
    o 70 2E
    o 71 FF
    exit
    (Note: you have to press Enter at every command from debug to exit)
    NOTE: The first character in the above commands is letter "O" and not the number 0.
    After providing the above commands, restart your system and it should reset the CMOS Settings along with the BIOS password.
    If you are curious to know how it works? then let me explain the above commands:
    In this method we are using the Debug tool of MS DOS. The "O" character present at first in these commands, outputs the values to IO ports. The number 70 and 71 are port numbers which are used to access CMOS memory. By providing FF value we are telling CMOS that there is an invalid checksum and it resets the CMOS settings as well as BIOS password.
    If this doesn't help, you'll need to disassemble and try jumper trick or Cmos battery method. There are several tools, but I don't think it'll be possible for you since those techniques are very complicated and time consuming.
    Let me know if you need further help.
    Good luck.
    Thanks for using FixYa.
  • 13,433 Answers
The bios password can only be reset by sending the laptop to a toshiba service center. Please contact your dealer or toshiba directly.
  • Ekse Sep 28, 2010
    The bios password is there to protect the laptop incase it is stolen, you can not bypass the password for a good reason, techs at toshiba will be able to reset it.
  • Ekse Sep 28, 2010
    aslong as you provide proof of ownership.
Forgotten bios password for toshiba laptop
Forgot bios password? You can use Smartkey Password Recovery Bundle to help you. and you can see the detail direction from http://www.recoverlostpassword.com/products/passwordrecovery.html
Aug 26, 2012 | Toshiba Portege M700-S7001X Laptop AC...
Remove password bios toshiba portege m400 please!
Here is a guide toremove windows passwordwith Windows Password Recovery Tool Professional from http://www.windowspasswordsrecovery.com/Step1: Download and install Windows Password Recovery Tool.
Step2: Burn CD/DVD/USB Flash Drive. (Namely it is to burn a Windows password reset disk.)
Step3: Set the target computer boot from CD/DVD or USB.
Step4:Remove the forgotten Windows passwordwith the burned CD/DVD/USB. Then log on to Windows without a password.
Of course, you can also finish Windows password remover if you have a password reset disk in advance. That's also an easy solution.
Source: http://www.windowspasswordsrecovery.com/windows-password-remover.htm
Aug 13, 2012 | Toshiba Portege M400 PPM40U01000E Tablet...
How do i bypass the password for the bios
There is only 1 way and that is tearing the laptop down to get to the bios battery. Unseat the battery for about 2 minutes this should set the bios back to factory settings without a password. Good luck dont break anything getting there.
Aug 10, 2011 | Toshiba Portege 7100 Notebook
Hi I have a toshiba portege m750 and my little brother was using it and I have decided to use it for college but the only thing is he cannot remember I was just wondering how would I go about changing the...
You can set a user password from inside Windows. From the configuration panel look for an icon that represents two persons and click on it. Follow instructions on setting a user password.
You can also set a password on boot but you have to be careful: If you forget it you cannot open the tablet to remove the password. You will need to take the computer to a Toshiba Certified Service Center.
To set the password on boot you can use the BIOS SetUp configuration or a Toshiba Windows applications (HRWset).
For Windows XP tablet PC edition 2005
If you have the CrossMenu application you can run the HRWsetup from there. You can also go to All programs, Toshiba Utilities and look for HRWSetUp.
For Windows Vista or Windows 7, the name of the application may be Toshiba Security Assist.
Be very careful. You must not lose the password
Jul 30, 2011 | Toshiba Portege M700-S7002 Tablet PC
I have a toshiba portege m100 with a bios password set that i need to bypass. toshiba want 80 quid just to look at it. some sorces say short clr1 jumper but i cant find it on my machine. please help.
Most DESKTOP computers have a jumper to "clear CMOS settings",
but most NOTEBOOK computers do NOT have that jumper.
The password exists to protect the owner of the computer, should a thief be trying to use the computer.
You probably can remove the disk-drive, and copy the files onto a new computer, if you don't want to pay TOSHIBA to bypass the password.
Feb 26, 2011 | Toshiba Portege M100 Notebook
Toshiba Portege 3500 Win Xp Bios password - How Can I flash bios?
Go to your friend. Download and burn this cd http://www.9down.com/Hiren-s-BootCD-9-8-Keyboard-Patch-73110/
Boot your pc from it and use BIOS / CMOS Tools from it.
After that use the patch
Mar 08, 2009 | Toshiba Portege 3500 Tablet PC
Bios password for toshiba laptop needs reset
Try This: Resetting a Toshiba BIOS Password KeyDisk will reset the BIOS password on Toshiba laptops.
Older Toshiba laptopsmag-glass_10x10.gif can be convinced to boot without their power-on BIOS password by attaching a dongle to the parallel port which crosses a number of the pins. The pin out is:
Pins 1-5-10 2-11 3-17 4-12 6-16 7-13 8-14 9-15 Some Toshiba's can be convinced to bypass the startup BIOS password if you hold down the <LEFT-SHIFT> key while booting the system.
Feb 14, 2009 | Toshiba Portege S100-S1133 Notebook
Toshiba portege 7100 serise laptop,,, dont know password
Can you press F2 and DEL lots of times to get the BIOS menu up?
If so then does it ask for a password?
If so then you have a BIOS password set. Unless you can boot the laptop to DOS or from a CD it is difficult to bypass this.
The other way is to disconnect all batteries - including the one inside the chassis and then leave it for at least 1 hour.
Then connect it up again and see if the pasword is reset,
Aug 05, 2008 | Toshiba Portege 7100 Notebook
Computers & Internet Logo
282 people viewed this question
David Payne
David Payne
