Question about Minka Aire F809-BN Cobra® Fan
I am looking for a replacement globe for a Minka Air F809-BN ceiling fan. Do you carry these, or suggest where I can find. Thanks.
SOURCE: minka aire concept II ceiling fan bulb replacement
I found that the minka website has the installation manuals online.
www.minkagroup.net/http://www.minkagroup.net/minkaairemanuals.asp The glass cover on a Concept I fans turns counterclockwise. I had to use rubber gloves to get a good grip on the light cover.
Posted on May 03, 2008
SOURCE: Minka Aire remote controlled ceiling fan
I have the same problem, except I live in a multi unit condo where many of the occupants own the same fan! You can imagine how  frustrating this is when your fan or light comes on or you can't  agree on a fan speed. Anyway, I spoke to a MinkaAire customer service guy and he tells me that the switches in the receiver are located under the mounting ring. You need to unscrew the ring and it should be located in there. I haven't tried this myself as my fan has a mind of its own as I type and everytime I turn it off to unscrew the mounting ring, the damn thing turns on again.
Posted on Sep 04, 2008
SOURCE: light dims up and down repeatedly
PROBABLY THE WALL CONTROL SWITCH IS BAD.
ASK YOUR LOCAL DEALER TO BORROW ONE HE HAS IN STOCK. AND OR BUY BOTH THE RECEIVER AND THE SENDER. MY WALL SWITCH MALFUNCTIONED.
Posted on Feb 18, 2009
I have a newer Minka w/ wall controller. The books says to make sure both the wall control and the receiver(up in the fan) are both programmed the same. My receiver has no little switches but has a sticker stating that you need to hold the 'fan off' button down for 3 seconds after turning on the power so the receiver can memorize the program in the wall switch. You have 60 sec to do this after power is turned on. Good luck !
Posted on Feb 25, 2009
mcgyver468
  • 710 Answers
SOURCE: I currently have 2 switches on the wall for a ceiling fan(this was pre-installed when I bought my new home, but my Minka
The red and white should be hot all the time for the fan to run even when the light is not in use. The black and white wires are used for the switch on the wall to turn the light on. Hope this helps.
Posted on Apr 25, 2009
My Minka Aire conceptII ceiling fan comes with a 100w bulb. where I can buy a brighter bulb?
most well stocked hardware stores will carry bulbs that are larger then 100watts -- or a specialty lighting shop will also have a higher wattage bulbs.
c...
Feb 24, 2011 | Minka Concept II Flush 44 Ceiling Fan by...
How do i get light bulb cover off k9375 ceiling fan
The entire glass globe twists off (counterclockwise looking at the globe from below). It is kind of tricky, but if you apply constant pressure eventually it will begin to turn slowly, and then (1/4-1/2 turn) it will pop right off.
WARNING: I strongly suggest you have another pair of hands to help ensure the globe doesn't come crashing down to the ground, as it's VERY easy to do!
Nov 20, 2010 | Minka F603-WH Ceiling Fan
I have lost my instructions and cannot figure out how to replace the burned out light bulb in my Minka Aire F603 ceiling fan unit; I can't figure out how to get to the bulb - can't figure out how to get...
Hi Bill. So far I have not been able to find a manual, but I will keep looking. In the mean time, if you want to give it a try, it appears to me that the circular piece that has the fingers that hold the light globe is probably put in place to hold the globe by a "turning" motion. If you were to reach up and grab this ring and gently turn it counter clock wise I bet it would turn perhaps 1-3 inches and disengage the fan body. Makes sense that the manufacturer would make it easy to change light bulbs and viewing the fan, this would be about the easiest way to do it. I would assume the glass globe is NOT fastened to this ring in any manner, so if you do decide to try this, be ready to have the glass globe release from the holding ring.
I will let you know when/if I find a manual. If you decide to try my solution and are satisfied with it, I would appreciate a Thumbs Up rating from you. BTW, nice fan. Paul
Oct 08, 2010 | Minka F603-WH Ceiling Fan
How to i replace the light bulb in the minka aire ceiling fan
This is the concept f518-bn or 519-bn with recessed light.
According to the manual you twist the clear plastic cover counter clockwise. This is on the opaque white lens cover itself.
Manual is found here:
http://www.minkagroup.net/Admin/UploadFiles/F518-English.pdf
Mar 15, 2010 | Minka -Aire Brushed Nickel Remote Control...
The tenants say that the motor has stopped
Could be a breaker that has reset have they tried re-seting them? And the light switch could be bad you need a test meter to check this out with and if the switch is bad then the motor could be defective as well but would have to check connetions at the box in the wall switch and the cealing fan. Do you have a vlot ohm meter? If you do post it here and I will fix you up.
Aug 26, 2009 | Minka Aire F809-BN Cobra® Fan
No clips to hold globe on ceiling fan
You best resolution now may be to replace the light kit with one available at Home Depot ..
Jun 07, 2009 | Hampton Bay 52 In. White Redington...
Apr 25, 2009 | Minka -Aire Brushed Nickel Remote Control...
Minka Aire Como F603 ceiling fan - light bulb replacement
Try Googling (Minka Aire)(F603)(manual) without parens for instructions.
Jul 28, 2017 | Minka F603-WH Ceiling Fan
Minka Aire F809-BN Cobra® Fan Logo
77 people viewed this question
Top Minka Dryers Experts
Joseph Coppeto
Joseph Coppeto
Are you a Minka Dryer Expert? Answer questions, earn points and help others
