Question about Cell Phones
Having misslayed my user manuel for my bluetooth slimhead set type VSH-511, I am not sure when it is switched on or off and I do not knoe if it is paired with my mobile
    Sergeant:
  • 270 Answers
The display has special icons that let you know what is on and what is not. The bluetooth icon is very distinct and should diplay like the one on this site
Having misslayed my user manuel - moz-screenshot.pngmoz-screenshot-1.pnghttp://www.bluetooth.com/English/Pages/default.aspx
If you go in to your menu, on tools or settings, you can determine if your Bluetooth is on or broadcasting a signal.
Optimal setting if using bluetooth is to turn it on, and after you are done with pairing, hide your device.
The pairing will stil work, but others will not be able to detect your device.
good luck and don't forget to vote!!!
Posted on Sep 27, 2010
Como activo el bluetooth de la gateway 6307
Juan Manuel,
I have to apologize that I can only post this in English. I was able to understand your question though.
You want to know how to turn on the Bluetooth Features of your Gateway 6307.
Try the instructions below:
1. Enable Bluetooth on the mobile phone or other Bluetooth enabled device. This procedure is dependent on the make and model of the phone or the device. You need to see the user manual accompanying your mobile phone or device to see how to enable Bluetooth.
2. Turn on your Gateway laptop. Check the area next to the clock in the System Tray. There should be an icon with a stylized "B" on a blue background. This is the Bluetooth icon. Double-click on this icon and select "Enable."
3. Go to Control Panel. Locate "Bluetooth Configuration" and double-click on it. A window should pop up.
4. Select the Accessibility tab. Check the option "Let other Bluetooth devices discover this computer." A check mark should appear against this entry 5. Select the Local Services tab. Startup type for all services should be set to "Auto."
6. Select "OK" and click. Wait for a few seconds. Your laptop should have Bluetooth enabled by now.
I hope this helps.
Jun 18, 2014 | Gateway M6307 Notebook
Hi there, I'm trying to play a VSH/DVD through my
This happens when the computer signal is being used as the input, and the signal disappears or is the wrong type.
It may have tried switching inputs if you were using the video input rather than the pc input.
Press the auto image button to get it to select the correct input.
If you are using the PC as the dvd player, then change the display settings ie computer screen refresh rate, and resolution to suit the projector
Apr 06, 2011 | InFocus IN26 Multimedia Projector
User has a iCom Bluetooth Hearing Aid adapter paired with her Plantronics Voyager 500A base station on a Cisco 7940. When on an active call and she receives another incomming call, her current call is...
Make sure that the Plantronics 500A base inteli-sensor switch is set to the number one setting (should be set on the one line, not the two line setting, on the right side of the 500A base unit). Also if you are using an EHS (Electronic Hook Switch) instead of an HL10 Handset Lifter, that could be the issue as well. The only other thing is to check the user guide for the hearing aid and make sure that there is not an "auto answer" setting that may need to be turned off. Here is a link below for the 500A / 510S user guide.
Plantronics 500A/510S User's Guide
Good luck from Headsets Direct!
Apr 04, 2011 | Plantronics Voyager 500A Deskphone Adapter...
Lost user manuel. need to know how to connect to
how to connect a bluetooth to a cellphone
1. go to the menu on you cellphone and find connections-bluetooth
2. click options
3 be ready to click search for device (don't click it yet)
4. press the on button on your earpiece and hold till you get a solid bluelight.
5. when you get the solid blue light on earpiece click search for device on the phone
6. when it finds your device select it and click on it
7. it will then ask for a code or if you want to bond or pair the devices click yes and type 0000
8. it will ask you to confirm click connect
you should be able to connect.
if it works for you don't forget to rate me
thx
Apr 28, 2010 | Plantronics Explorer 220 Bluetooth Headset...
I cant find the manuel on how to use my hbm 210 bluetooth head set
You could Download the manual from :-
http://safemanuals.com/user-guide-instructions-owner-manual/LG/HBM-210-_E
Click on the Download the Complete User Guide and save it on the Desktop.
Make sure that you need to have Acrobat Reader to View the .pdf file.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 27, 2010 | LG HBM 730 Bluetooth Headset Wireless...
I need to install the bluetooth mouse on my note book
follow installation manuel step by step after incerting driver
Jul 29, 2009 | Computers & Internet
How to use / user manuel info
The HBS110 is a bluetooth headset. To pair it with your phone, first turn on the headset. Then turn on bluetooth in your phone and search for bluetooth device. When your headset is detected, just select it and follow onscreen instructions to pair it with your phone.
Hope that helps,
Sai.
Mar 16, 2009 | LG HBS-110 Wireless Headset
Agreed bluetooth passcode required to pair phone and hands free k
1. Make sure that the mobile phone is switched on and the battery is
charged.
2. Switch on the Advanced Car Kit. For further information, see
“Switching the Advanced Car Kit on/off,” p 20.
3. Open the Bluetooth menu in the mobile phone and activate the
Bluetooth function.
4. Make the required settings on the mobile phone to activate a search
for Bluetooth devices within range. For further information on the
settings required on your mobile phone, see the relevant user guide.
5. Select Advanced Car Kit from the list of Bluetooth devices found.
6. When prompted, key in the Bluetooth passcode 0000.
Jan 03, 2009 | Nokia 3110 Cellular Phone
Cell Phones Logo
41 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
