Question about Maytag MMV5207A Microwave Oven
Maytag over the stove microwave MMV4205BAS blew the ceramic fuses and burnt some wires that were located under the metal cover where the light bulbs would be. I am wondering if this is worth fixing. I am going to do it myself
4 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave keeps blowing fuse
If it went dead almost immediately after pressing the Start pad, that\'s usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that\'s usually a failing high-voltage transformer.
Here are some links with info on part testing:
http://www.microtechfactoryservice.com/cap_test.html
http://www.microtechfactoryservice.com/diode.html
http://www.microtechfactoryservice.com/mag_test.html
http://www.microtechfactoryservice.com/xformer.html
You can usually find helpful exploded view diagrams and order parts by
entering your full model number here: http://tinyurl.com/gv383
Please write back with your brand and model number if you need further help.
We\'re happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 13, 2008
rickzilla
  • 706 Answers
SOURCE: MAYTAG MMV4205BAS Running but not heating
If the food in the cooking compartment is not heating at all, then you may have one of several components related to microwave energy generation that have failed or became disconnected internally.
Magnetron Tube, HV Capacitor, Filament Transformer or any number of sensors that disable power to the system. The control board could also cause the system to noty function correctly.. You wanted general inputs.. there ya go.. LOL
Not sure I told you anything you didn't already know but you should ask the tech what he did after he gets it going...
Regards,
Rick
Posted on Nov 28, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: I need to replace just the door handle on a Maytag
The handles run about $25-35 here.
Here are the part numbers & descriptions:
W10279351 Black handle
W10279353 White handle
W10279355 Bisque handle
Posted on Sep 08, 2010
Testimonial: "I've ordered the replacement part. Thanks for the help! Very much appreciated."
While changing the light bulb under the unit, the wire connected to the light bulb holder touched the metal housing and totally blew out the microwave so it doesn't work.
normally there is a glass fuse in the circuit where the power comes in
check that fuse/ replace if necessary
As silly as it sounds --turn the equipment of at the wall before you work on it as it might have been you that blew and not the fuse
Jan 16, 2016 | GE Adora DVM1850 Microwave Oven
How do i replace the light bulb in my maytag microwave oven. the bulb broke in the socket.
The cooktop light bulb(s) is(are) located on the underside of the microwave oven, and is(are) replaceable. Remove bulb cover screw, and open the bulb cover. Replace bulb, close bulb cover, and secure with screw. Cavity light: The cavity light bulb is located behind the vent grille at the top front of the microwave oven, under the bulb cover, and is replaceable. Remove 2 screws on the vent grille, tilt the grille forward, and lift it out. Open bulb cover and replace bulb. Close bulb cover, replace vent grille, and secure with screws.
For more information, your owners manual can be viewed here (scroll to the bottom of page 4):
Maytag MMV1164WB Owners Manual Page 4
Feb 11, 2015 | Maytag MMV1164WB Microwave Oven
Sharp microwave r-1875. Replaced damper motor. upon start up sounded like it blew a fuse. Where is the fuse located
The fuse located under the keypad near the high voltage capacitor "silver and rectangular" unplug and discharge high voltage capacitor, fuse is a ceramic type, replace with same type and rating.
Feb 07, 2011 | Sharp Microwave Ovens
Fuse location for fan motor/lights??
Unplug microwave, remove the top cover "several screws" fuse location under keypad and near the high voltage capacitor "silver and rectangle in shape" fuse is a ceramic type, must be replaced with identical fuse and rating, and don't forget to discharge capacitor with "long handle screwdriver"
Feb 06, 2011 | Frigidaire GLMV168K Microwave Oven
MMV4205BAS no power. Was not using it.
Try checking the fuses under the button panel.
Jun 08, 2010 | Maytag MMV4205 Microwave Oven
Light won't go on; Model MMV1153WB-O
You can download owner's manuals and installation instructions for several brands (including Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
Enter it as MMV1153WB0 (no dash, zero on the end, not "oh")
Or just get it here, to be more exact.
On page 4, it says:
"Installing/Replacing Filters and Light Bulbs
■ Grease filter: Grease filter is on the underside of microwave
oven. Clean monthly. Slide the filter away from the tab area,
and drop out the filter. To reinstall, place end of the filter into
the opening opposite the tab area, swing up the other end,
and slide it toward the tab area.
■ Charcoal filter: The charcoal filter is behind the vent grille at the
top front of the microwave oven. The charcoal filter cannot be
cleaned, and should be replaced about every 6 months.
Remove 2 screws on the vent grille, tilt the grille forward, lift it
out, and remove filter. To reinstall, place the filter into its slotted
area – wire mesh side up, replace vent grille, and secure with
screws.
■ Cooktop light(s): The cooktop light bulb(s) is(are) located on
■ Cavity light: The cavity light bulb is located behind the vent
with screws."
HINT: Unplug the oven before removing or installing the bulbs, or you may need this service.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites. Hope this covers it.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
May 06, 2010 | Maytag Over-the-Range Microwave
Fuse location ge spacemaker under the counter
it is behind the control panel.to access that remove the top grill by removing two screws on the top or in the fron of grill.then u should see see a screw on the top of control panel holding it.remove that screw and u should be able to remove the control panel.fuse will be behind the panel.it is not mounted on the panel but in the cavity behind it.
Aug 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Blown microwave
look for any disconneted wires.u could have pulled some wire while replacing the bulb.if every thing chks ok then it could be the control board.
Aug 13, 2009 | Microwave Ovens
Kenmore over the range microwave 721.63684300 - nothing works
you must remove the MW take off the cover then look for a large metal can (capacitor) and a white (ceramic) fuse...look and, smell and, you should find the cause
Apr 02, 2009 | Kenmore 63682 / 63684 / 63689 Microwave...
Is the Advantium Mod: SCA1000HCC03 the same as the SCA1001SS?
They are indeed the same bulb, a 10W halogen. Care must be taken not to touch the lamp, as the oils from the skin will shorten its life. In many recent models, the oven must be removed from the wall (a two-person job due to safety concerns) and the cover must be removed. The manufacturers consider this a "technician-only" type job to lessen their liability. You can find helpful exploded view diagrams of both ovens and order the bulbs here: http://tinyurl.com/gv383
May 03, 2007 | GE Advantium SCA1001SS Convection /...
Maytag MMV5207A Microwave Oven Logo
214 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
