Question about Canon PIXMA MP510 All-In-One InkJet Printer
How do i change the ink cartridge in my canon mp510 printer
  • 472 Answers
  1. Press the "On" button on the top panel of the printer to turn it on. Open the paper output tray at the front of the printer.
  2. Lift the entire printer cover, which should snap open. Then lift the small inner cover.
  3. Press down on the tab below each ink tank to snap out and remove the tank. Lift the print head lock lever that holds the ink tanks in place.
  4. Lift the overflow tray toward the top of the printer and slowly pull it out of the printer. Take care to avoid spilling any ink that has collected in the tray.
Good Luck!
Posted on Sep 27, 2010
  • arnold mauer Nov 02, 2010
    Thanks for your help Pulkit558, but my problem is, I can't switch on the printer!!
    bye
  • nashiji jahari Aug 12, 2013
    thank you am done bro
hmerchant110
  • 7191 Answers
SOURCE: Windows 7 printer driver for Canon Pima MP510
You can download the required installation drivers and software from manufacturer's site by clicking this link
On the page which opens, select the operating system (Windows 7) of your computer and download the appropriate drivers and software.
Hope this solves your problem. Thanks for using FixYa.
Posted on Feb 06, 2010
  • 76 Answers
SOURCE: U150 Canon no cartridge recognised
Because these a refills inks the Chip things they are full so you must replace the cartridge with a new Canon one and the fault will go. If not just replace the chip with a new one!
Then your error u150 will go.
Posted on Oct 21, 2008
SOURCE: CANON PIXMA MP510 WILL NOT POWER ON
I had a similar problem. What worked for me was to remove the power pack, which is secured by two clips. Slide a knife or similar to release the power pack. It will slide out to reveal a mini-plug with five red wires. Disconnect this.
This where it gets a bit uncertain. I plugged in the power pack and put a meter across the outputs. They seemed to be working (ie I was getting voltage). I had a quick look at the indide of the MP510 and decided there was nothing further I could do. I then reassembled everything and, just out of curiosity, pressed the power button again. And it came back to life!
I suspect that in your and my cases, the MP510 had "crashed" and I performed a hard reset by removing and then reconnecting the power pack. But who knows? Best of luck
Posted on Jan 27, 2009
solofixya
  • 34 Answers
SOURCE: how to change ink cartridge in canon mp390
With the machine powered on. Just lift up on the entire top portion on the platen unit, lower the front verticle cover and the printhead should come to the correct position to change out the ink tanks, just tilt tanks towards the front of the unit and lift out.
Posted on Nov 11, 2008
efs_perpends
  • 1996 Answers
SOURCE: how to change ink jet cartridge canon 'pixma' printer mp160
Please go to this Canon link (click here) and enter the term "ink cartridge replacement" in the search window for a set of detailed instructions (with pictures) on how to replace your ink cartridges.
As you face the printer, with the scan cover open,in position to remove them, the black cartridge goes on your left and the color on the right.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Apr 09, 2009
Need to print only black ink on canon mp510
in the printer set up ( normally in the print section , change the color to black and white , make default and ok
Jan 11, 2012 | Canon PIXMA MP510 All-In-One InkJet...
Can't find my manual and don't know where the ink cartridges go, my printer is a Canon MP510
Your printer must be turned on.
Open the printer by lifting the whole scanner assembly. The Carraiges should move into position so that the cartridges can be inserted.
Aug 23, 2011 | Canon PIXMA MP510 All-In-One InkJet...
Canon PIXMA MP510 : When I print something in colour, I get alternating dark and light 3mm lines printed horizontally down the page. I've tried cleaning, deep cleaning and realigning the print...
Hello
what you need is to clean, you need to clean the prnt head and ink cell, you open the top part let the ink carrier move to the center then UNPLUG the power cord ,now you can easily clean ink cell.
Jun 29, 2011 | Canon PIXMA MP510 All-In-One InkJet...
HOW DO YOU GET THE INK CARTRIAGES TO COME OUT SO I CAN CHANGE THEM??? I am using a Canon mp510 usually you just open the lid and they move to the middle where changing them is easy.
Lift the top cover and you will see the cartridges toward the center of the printer (they are long thin ink tanks with different colored labels). On the side of the cartridges facing you there are tabs that you pressin and then lift that side up. Then you can pull the cartridge out toward you. To insert the new cartridges, simply make sure the side with the tab is facing you and slide the cartridge into the corresponding slot. Then press down on the cartridge where it says "press" untill it clicks into place. A red indicator light should come on if you did this correctly.
Hope this helps! Good luck!
Oct 11, 2010 | Canon PIXMA MP510 All-In-One InkJet...
Where are the ink cartridges located in my MP510 Canon printer?
open the panel on the top with the power on and they should come from the left hand side and stop in the middle needs to be plugged in and on
Dec 17, 2009 | Canon PIXMA MP510 All-In-One InkJet...
How do I change the ink cartridges in a Canon MP510 printer?
palese you are open the head couver and old cartridge is out of printer in holder and add a new cartridge when old cartridge palace in atech
a new cartridge and start printer and aply a prient.
Oct 23, 2009 | Canon PIXMA MP510 All-In-One InkJet...
My mp510 dont print black color, only print pink but the ink is full.
Sounds like you have a bad ink cartridge, you need to change with a new one.
Jun 22, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Ink cartridge full, but printing as if out/low
I have found using 3 r d party inks in Canon printers will mess them up fast but the ones with the contacts don't work period
Dec 01, 2008 | Canon PIXMA MP510 All-In-One InkJet...
Canon MP510 wont recognise cartridges
Using replacement cartridges that come without a chip seems to be the problem I had with the Canon Pixma 510 printer they are cheaper
but if they do not show the ink levels then its inconvienent so I have but Canon products with a chip and they work perfectly.
Nov 11, 2007 | Canon PIXMA MP510 All-In-One InkJet...
Canon PIXMA  MP510 All-In-One InkJet Printer Logo
2,089 people viewed this question
old marine
old marine
