Question about Bionaire Dryers
I'm trying to fix a Bionaire BT90R floor standing fan. It has 4 non standard screws in the back that I've been unable to find a tool for removing them. It looks like a standard slot screw but it has a raised middle. Heres a bad sketch of what I'm looking at :/ Standard slot http://www.kerbain.com/images/standard.gif and what I've got http://www.kerbain.com/images/strange.gif Hope someone has an idea :)
SOURCE: Dell Inspiron 1000 Disassembly
The teardown information from rbrown67 was very accurate and easy to follow. It helped tremendously in tearing down my machine to replace the AC plug.
Posted on Mar 26, 2008
Mark_Webber
  • 472 Answers
SOURCE: Dell monitor back removal
This can go one of 2 ways..very easy or very hard.
Having said that here we go.
  • Get a towel and lay it on a flat surface.
  • Remove the 4 screws from the stand and remove it.
  • looking from under the monitor you should see 2 small notches between the front and rear covers.
  • Carefully insert a flat blade screwdriver (not too far) into the hole and lift upwards. It should pop. Do the same on both sides.
  • Carefully pop it all the way around (without using anything but light pulling pressure.)
Hope that helps =)
Posted on Apr 09, 2008
SOURCE: tower fan 07586 parts (screws)
The M5 indicate it is a metric size and the 12 is the length. I had the same problem when I unpacked my fan and was able to buy two M5-16 screws from my local hardware stoe for 45 cents a piece. In case your asked, they have an 80 pitch.
Posted on Aug 19, 2008
  • 168 Answers
SOURCE: grinding of fan
There should be a black round nut in front of the blades in the very center. It will have ribs on it so you can grab it. Turn it Counter clockwise, and it should unscrew.
Then you can remove the blade assembly and get to the back cage to tighen the screws.
This should take care of the problem.
Re assemble in reverse order.
Let me know if you have any more questions or if this doesnt work.
Good luck.
Mac
Posted on Sep 11, 2008
SOURCE: I am trying to remove
If you are looking at the back of your tv there is the stand bracket with a screw on each side. remove those screws and nothing will happen. that is the problem i was having but if you look right above the ones you just took out and there is going to be a black screw. take those off from each side and it will fall off.
Posted on Dec 26, 2008
I can't remove the stand off the tv
Hi, i have instruction on removing your base stand.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat,
cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface.
Note: Extreme care should always be used when removing
the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose
the pedestal stand screws. The jack pack cover can be removed
without tools.
3) Remove the four screws shown in the diagram below. This will
allow removal of the pedestal stand.
4) Once you have removed all four screws holding the pedestal
stand in place, remove the pedestal stand from the TV by
sliding the pedestal stand away from the TV.
Feb 12, 2011 | Toshiba REGZA 52RV530U LCD TV
The inside of my fan looks very dirty and I would like to take it apart to clean. Do you have any instructions on how to do that?
#1 CLEAN WORK SPACE
#2 PLACE FAN ON ITS CONTROL SIDE DOWN
#3 REMOVE PHILLIPS HEAD SCREW FROM HANDLE
#4 REMOVE NON-SKID COVERS
#5 REMOVE OTHER 2 PHILLIPS HEAD SCREWS
#6 REMOVE BLACK SIDE & CLEAN
#7 REMOVE YELLOW FAN COVER & CLEAN
#8 7/16 SPIN-TYPE DRIVER REMOVES FAN NUT
#9 CARE....WASHER ON OTHER SIDE OF FAN
#10 PUT FAN IN SOAP& WATER ....TAKE YOUR TIME
Oct 14, 2010 | Lasko 655702 Stanley Blower Floor / Box...
How to remove and install a transmission
FIRST OF ALL YOU NEED TO FIND A HAYNES REPAIR MANUAL FOR A 1983 300 MERCEDES - BENZ IT WILL SHOW AND TELL YOU HOW TO REMOVE TRANSMISSION.YOU WILL ALSO NEED TOOLS LIKE 1/4 3/8 1/2 RATCHET SET WITH STANDARD AND METRIC SOCKETS.OPEN BOX END WRENCHES STANDARD OR METRIC ALSO.YOU NEED 2 JACK STANDS FLOOR JACK AND TRANSMISSION JACK TORQUE WRENCH.
Nov 12, 2009 | 1983 Mercedes-Benz 300-Class
Where is the resistor for the heater blower located on my 2000 Pontiac Sunfire 2.2L ?
Replacing the blower motor resistor on a 2000 Pontiac Sunfire is a bugger of a job!.This project is far easier if you remove the blower fan first. You may be able to do it leaving the fan in, but you have to be an elf with very good eyesight. Tools required: 1/4" driver with a universal and a short 5.5 mm or 7/32" socket. First remove the wiring harness and the visible screw. Here's the tricky part! The rear screw is out of sight, and you have to push the floor liner down to get the socket attached. Once you get the 2nd screw out, simply remove and replace with the new one, reinstall the fan motor and your back in business. Hint: If you are not agile, or you are a large person, remove the front passenger seat. It's only 4 nuts and it will save your back. Good luck and hope this helps, keep me posted be glad to help.
Jun 06, 2009 | 2000 Pontiac Sunfire
Cannot remove blades
hi! there,
there are two type of removing the blade of electric fan,one is there is a center knob with mark arrow loosen and tight direction at the center holding fan blade, this to lock fan blade on its shafting. to remove fan blade.loosen holder knob on clockwise direction while holding the fan blade,to release the knob check the arrow on the knob. after loosening knob pull out blade from the shafting.
the other type the fan blade has lock in bolt at the back side of the fan blade bolt in on the shafting of the fan, you need here a tools such as set of socket wrench small one to loosen the bolt
after loosening lock in bolt, pull out fan blade.
besure doing this tha electic fan was unplug to elecrtic source. have a nice day.just rate me,thank's
Apr 18, 2009 | Heating & Cooling
Fan blades are filthy!
put motor oil to the midst of your fan blade may there are lots of rust inside then wait 5 hours then try to pull again patiently...
Apr 16, 2009 | Bionaire BSF1731RC Stand (Pedestal) Fan
Removing the stand
Check to see if you got all the screws, usually there are 4-6 screws holding the stand in the TV. The are usually all on the center bottom on the back. When the TV is on the floor, try lifting with two people, one on each side directly up evenly. The stand should stay on the floor as the TV is removed.
Apr 02, 2009 | Sony KDL-52XBR5 52 in. LCD HDTV
Lasko 2535
Lasko 52" tower fan, model 2535, works fine but has the annoying loud 3 second beeeep when turned on/off, waking us up at night. Have been unable to get at the circuit board to investigate due to non-std screws (regular slot head but with a bump in middle of slot, so slot is filled in in middle of screw head, if you will)
Any thoughts on killing the beeeeping?
Mar 09, 2008 | Lasko 2535 Stand (Pedestal) Fan
Dryers Logo
352 people viewed this question
Top Bionaire Dryers Experts
Jerry Greenberg
Jerry Greenberg
Are you a Bionaire Dryer Expert? Answer questions, earn points and help others
