Question about Brother CS-8150 Computerized Sewing Machine
I had my brother cs-8150 apart i was cleaning the dust out. The top tension parts flew out, now I need a diagram to put these parts back together. All the upper tension parts flew out. Can anyone help with instructions or diagram. Thank you.
  • 16 Answers
SOURCE: Cannot wind the bobbin
Check to make sure that the bobbin is locked onto the winder. If is not locked on then nothing will move. I know I had this problem as well and found that the bobbin must be locked on the winder.
Posted on Sep 15, 2008
SOURCE: How do I disassemble my
If you or someone you know is mechanically inclined, you will need to take five screws out of the back including a hard to find one under the foot raising lever (lower the foot), then one form the front that is under the thread cartridge, and you will have to remove the bobbin winding plate cover which is held by one small screw, and then remove a small screw from the support bar.
Posted on Nov 10, 2008
bibleman01
  • 334 Answers
SOURCE: Brother CS-8150 Won't Work in Reverse
Look at the feed dogs under the foot see if they are raised high enough to pull the material through.
Posted on Dec 05, 2008
  • 108 Answers
SOURCE: wanted a maintenace manual
i was able to fnd manual at www.ifixmachines.com
Posted on Feb 15, 2010
  • 1116 Answers
SOURCE: I don't know how to adjust the tension on my
It is the wheel on top of the machine near the thread guide.
I believe you will find more information on page 29 of the manual.
Posted on Mar 11, 2010
Testimonial: "Exactly the answer I needed - short and sweet!"
I am trying to find out how to put part of a sewing machine back together that was taken apart. It is a cs 6000! computer sewing machine Brother. The rod that goes up an downthat holds the needle has
There are three types of CS 6000 they are CS 6000B, CS 6000i and CS 6000T
You can download the service manual and parts manual from this site
http://www.nodevice.com/manual/Brother/page2.html
One file costs 4.95 Euro, or a 24 hour download (better value as you can get the parts manual too) costs 7.95 Euro to download
Oct 02, 2014 | Brother CS-6000 Computerized Sewing...
L2525 tension
Which tension? If it's the upper tension (loops on the bottom of the fabric), rethread the top from scratch, this time with the presser foot UP so the thread can enter between the tension disks. Presser foot down to sew, which engages the tension.
Jan 21, 2014 | Brother CS-8150 Computerized Sewing...
I need several parts for my brother CS8150
sewingpartsonline.com
a1sewingmachines.com
sew4less.com
sewvacdoctor.com
ebay
Apr 19, 2012 | Brother CS-8150 Computerized Sewing...
Bottom thread from theh bobbin is in big loops.
Problem with Brother CS-8150 Computerized Sewing Machine
bottom thread from theh bobbin is in big loops.
I have a CS-8150 as well -it was fine until I decided to clean the shuttlecock and I thought I had put it back correctly. However, it was after replacing the shuttlecock in place that my bobbin thread was making big loops and no matter what tension it kept doing it. So I removed everything out of the bobbin area. Cleaned and made sure that the shuttlecock was exactly in place as per the manual. Guess what it does not make big loops any more.
Just a suggestion.
Sep 09, 2011 | Brother CS-8150 Computerized Sewing...
Brother CS-6000 E1 error message - my presser foot is not up!
Did you take this machine apart? If so, then the lever that extends from the thread tension wheel is to the right of the raised presser foot switch plate (inside the sewing machine), keeping the switch from being unpressed.
Take the machine apart again, raise the presser foot, and put the machine back together. This will ensure proper alignment of the plates.
Jun 25, 2009 | Brother CS-6000
I need to know how to change the bulb on a brother ps 33 sewing machine!
Hi, thank you for using FixYa! I don't see a model PS-33, however; you posted in the CS-8150 machine section, the link to the manual for a CS-8150 machine is attached. It has a section for winding and installing the bobbin and another section for upper threading. If your machine is not the CS-8150, please comment with the correct model number (PS machines start at number 1450 and increment upwards). If this is the correct manual, would you please take minute to rate this solution? Thank you! Gregg
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_CS_8150_EN_183.PDF
Mar 29, 2009 | Brother CS-8150 Computerized Sewing...
Where can I get a small part online - no stores locally
The Brother home sewing solutions support center can be contacted at:
7777 North Brother Blvd.
Bartlett, Tennessee 38133
1-877-BROTHER (877-276-8437)
901-379-1210 (fax)
9:00am to 5:45pm Eastern Time
They don't list the spool disc part specifically on-line, rather they show accessories you might purchase - but your manual should list the part in the parts diagram, the manual is located here:
The Brother service centers, which could also provide your part, are listed here:
http://www.brother-usa.com/service/default.aspx?WT.cg_n=Support&WT.cg_s=Service
I couldn't look up the one closest to you because doing so requires your zip code!
Hope this gets you on the right path, if you appreciated this information, could you please be so kind to take a minute to rate this solution for me? Thank you!
Gregg
Aug 24, 2008 | Brother CS-8150 Computerized Sewing...
Brother CSi 6000
have you adjusted the tension?
Jul 21, 2008 | Brother CS-8150 Computerized Sewing...
Brother CS-8150 Computerized Sewing Machine Logo
49 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
