Question about Canon DR-2050C Path-Through Scanner
I clean the glass but there are still black streaks
  • 490 Answers
Try scanning the same document in two diff brightness levels (in B&W, say one at 75 and other at say 210. I am assuming you are using CapturePerfect. If the black streaks are same in both the images, then it could be scan module problem. If the streaks vary in size, then it is definitely dirt on the glass. use isopropyl alcohol (rubbing alcohol) to clean the glass. DONT USE solvents. S. Mohan, Chennai, India
Posted on Sep 28, 2010
Black streak on scanned printed copies
Hi
Open your scanner lid and make sure their is no dirty marks sitting on your scanner glass. Also does this happen on the scanner glass or when using the ADF? If its on the ADF its most likely that the glass is dirty and needs to be cleaned. 6c66c542-b5d2-4d0a-8a21-00c054973a29.png
Apr 28, 2014 | Office Equipment & Supplies
I have an hp LaserJet 3015 PCL-6 all in one printer, copier & fax. When I use the copy function, there is a black streak running down the length of the copied paper. I tried replacing the toner...
Clean the thin glass strip that sits to the left of the flat bed glass.
That is the glass used when the ADF is being utilized.
There is dirt on it causing the black streak.
Oct 11, 2011 | HP LaserJet 3015 All-In-One Printer
Hi, My Canon 3245 Imagerunner is streaking.
First, the streaks appears when copy from glass or adf, when printing or all?
Solution #1:
How many copies did you do from last drum changing? if over 80 000 copies, replace the drum unit.
-in case that streaks appears when copy and print
Solution #2:
If the streaks appears only if you copy from adf or glass, clean the glass and dry it out. Both glasses, narrow on left side beneath the adf/cover and glass for copy of original.
Solution #3:
If the streaks are wide and solid, with possible toner left overs, you need to replace fixing film.
Hope that helps!
Apr 04, 2011 | Canon ImageRunner 3245 Black and White...
Horizontal streak
Clean the scanner strip glass. This is the small strip of glass that is just to the left of the large main glass. This is the only cause for black line (s) when copying using the ADF(top feed). If prints or copies fine from the glass then it is this strip glass needing to be cleaned.
May 04, 2010 | Ricoh Aficio 450 Copier
Brother mfc. I made the mistake to use canned air to clean copier which got into my drum and made black streaks on my paper I keep cleaning the black streaks off the drum but when i put it back in i have...
First clean the glass of the laser.If you open the front door remove the drum from the machine just above were the drum was in place there is a glass mounted.Try and make a test print.If the streaks is still printing and you can see the streaks is deffinately from the drum you can strip the drum,clean the corrona wire and grit,and clean the drum brush.Strip only the drum unit if you sure the lines is caused by the drum.
Dec 11, 2009 | Office Equipment & Supplies
The scanner leaves a black streak on page only when in duplex mode. I have cleaned and cleaned and cleaned the parts the manual suggests and the streaks are still there.
Check if the glass is scratched. Try scanning in two different brightness levels. If the size/thickness of the streak varies and is also with 'steps' (when zoomed) then it is glass related. If the streak is same thickness and crisp at ends, it could be Scan module problem.
Oct 14, 2009 | Bell & Howell Sidekick 1400 Path-Through...
I have a black streak all on one side when i copy ?
If it is just when you copy and not when you print then it is a cleaning issue. Toner cartridge would cause the line to appear on copies, printouts and faxes. There is a piece of glass inside the auto document feeder that is probably dirty. Open up the document feeder as if you were clearing an original document jam. Look for a piece of glass inside the ADF, it will run the length of the document feeder. There is probably some dirt or another popular problem is white out. Clean off the glass with glass cleaner or alcohol and it should fix the problem.
Oct 04, 2009 | Brother IntelliFAX 4100 Laser Fax
Black streaking accross the print even after i clean the glass
Things to check.
Check the **** glass that the originals go across when using the doc. feeder. If it has even a spot, this will cause a streak.
Check the drum to see if the line is on the drum, if it is you may have a bad drum cleaning blade.
There is a corona cleaning device just above the drum that you can pull out and push in to clean the wire/comb. This too can cause a black streak.
Hope this helps
Jul 01, 2009 | Kyocera Office Equipment & Supplies
HP Officejet 6300 All-in-one machine makes black streaks
The problem is that that there a small piece of glass that the doc feeder use's to scan the orginal. You will have to clean the small glass it's about a half of a inch piece and is normally under the doc feeder unit. It will either be to the right side of the main copy board glass or it is under the doc feed unit where the paper goes down through the feeder. It is mostly some white out on the glass, just clean with a dam cloth with water or windex..... Good Luck
Nov 15, 2008 | HP 190 Copier
HP 7410 streaks when using auto document feeder to make copies
the document feeder of that unit have its own scanner glass. try opening the document feeder and clean the scanner glass with a lint free cloth that is moist with water and also clean the rollers of the document feeder
Aug 13, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Canon DR-2050C Path-Through Scanner Logo
349 people viewed this question
old marine
old marine
