Question about Gigabyte GA-K8VT800 Motherboard
When i reset by desktop bios is not loaded (i think) black screen and not disk activity. Ga-k8vt800m. this happened after cpu frequency change.
    Sergeant:
  • 270 Answers
If you can still go into the BIOS screen, disable the change you made and see if the system returns to normal.
If not, and you do not remember the settings, go for the default...
Ground yourself to the chassis to dissipate static electricity, with the system off, remove the bios battery.
This will undo any changes you made.
It will also undo and system changes that make you system unique.
At least it should start working again. You can go from there.
Good luck, and don't forget to vote
Posted on Sep 27, 2010
Ga-g41m-es2l xp install problem
do you have enough memory (RAM) ? .freezes means to little memory.
Jun 09, 2013 | Computers & Internet
My computer has a black screen and says "Reboot and select Proper Boot device or insert Boot Media in selected Boot device and Press a key." Im not that computer savy. Help!
Your computer tries to load an Operating System from several devices:
* the 'A:' diskette
* the 'C:' disk-drive
* the 'D:' CD-ROM
* any USB device
* via your network-port, "talking" to a "boot-server" on your network.
What probably has happened is that you have no disk in 'A:', and no disk in 'D:', and your disk-drive in 'C:' could *NOT* be read, i.e., your disk-drive has "died", and so your computer says "insert media".
Take your computer to a qualified technician, for complete trouble-shooting.
Oct 23, 2010 | Computers & Internet
No POST/Black Screen
Believe it or not, clearing the CMOS might actually help. Make sure you do it right by completely unplug the power cord or turn off the PSU, then take the battery out.
It also sounds like the CPU might be too hot. Look under the fan of the heatsink and see if there is any dust that will block the airflow. When the computer is on, touch the heatsink and feel if it is really warm. If it is really warm, it's a good sign, you might just need more airflow. If it is cold, you might need to reinstall the heatsink/apply new thermal compounds.
Mar 07, 2010 | Gigabyte Computers & Internet
I have a Gigabyte GA-7N400-L motherboard CPU problem
dit you try a bios update?Some motherboard needs a bios update for a newer cpu.
Jan 17, 2010 | Gigabyte GA-7N400-L Motherboard
Black screen cpu works.
ur problem is from ur cpu, it from ur memory or ur motherboard
Jan 15, 2010 | Computers & Internet
Computer does not see all ram. I have 2 of the same 512mb ram sticks it only sees one 512. If I only put in on at a time each one works but not both together. It does not show up in post or windows xp sp2...
u do need to remember that when you use 2 ram "sticks": 1. they CANNOT BE putted in slots directly next to each other. leave slot between them free. 2.they need to be exact same frequency and type [ddr1 or 2 or 3] and they both must have or not error connection on as if bios program upgrade utility is damaged do not try to upgrade bios as u may damage your motherboard beafore u try with 1gb stick refer to otherboard manual for ddr type and momory frequency
Dec 06, 2009 | Computers & Internet
No beep sound after switch on my desktop computer but power led of CPU are on and glowing , drive light are blinking and screen is black. Inspite of checking the memory ...
hmm if it not beeping it means that is something wrong with the Ram memory ..check if its right inserted ...and is it is ...remove the bios battery , to reset it ..and reboot...you might have to reinstall cause sometimes when everything appears to be ok .but get blank screen its cause you messed up with the video card driver ...or collor setings...reinstalling will fix the problem if its from there ..but cause its not beep-ing at boot means its not recognizing the RAM memory ...
So ..the cause may be multiple ...either you changed the frequency of the memory ..and its out of its range ...or you have made changes on the memory configuration ...( changed ram or added more...) and in this case its just making a little click like its booting in looping ...if the memory its still working ...removing the battery for a few moments and restarting will get the bios on the default optimal factory settings ..and it will take the memory frequency at automatic values ....Good luck !
Sep 03, 2009 | Computers & Internet
Blank screen on start up
Try removing all cards with the exception of the video. Remove all memory leaving (1) to boot from.
Disconnect power and reset the processor.
If you have a boot disk or copy of XP on disk, try to boot from the CD or DVD.
If the unit boots at all the problem may be the HD.
If not try downloading the BIOS update for your chipset.
Remove all extra drive, like secondary CD or DVD drives, Floppy or Zip drives.
You may have burnt the processor but I don’t think so.
Power supply is OK or you would not power up. Their are 3 or 4 supply voltages from supply, +- 12 volts, +- 5 volts and +-3.3 volts.
You may have a secondary 12 volt 4-pin plug but that is for on board video.
Try a boot disk and flash your BIOS, if you can.
Hope this helps.
Jul 26, 2009 | Gigabyte GA-M55plus-S3G Motherboard
Post problem
You could try a program like EZ-Flash to flash the bios without using a dos disk. Gigabyte should have some type of program on their website that would do the flashing without makeing a disk as most new computers do not have a floppy drive nor does Windows XP/Vista use dos. Hope this helps.
Dec 18, 2008 | Gigabyte GA-K8VT800 Motherboard
Gigabyte GA-K8VT800 Motherboard Logo
62 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
