Question about HP Deskjet 6940 InkJet Printer
PRINT IS FINE FIRST HALF OF PAGE, BUT QUICKLY FADES/WEAKENS LAST HALF OF EACH PAGE
  • 823 Answers
You need to clean your print head nozzles. Find menu on your printer and push the button then use the up and down arrows to navigate the options. Find the one that says "maintenance" and push "ok" or "enter" from your printers key pad. Then find the "clean print head or nozzle" option and again push the "ok or enter" button on your printers keypad. Follow the instructions to complete the cleaning and print a test page to make sure your problem is solved. If not, repeat the cleaning until the ink flows through your print head correctly.
Posted on Sep 27, 2010
Hp color laserjet black print fades to the bottom of the page.
dirty scanner.open the printer back cover.remove the scanner assembly clean it ,do the color calibration.u should be fine.
Amuna1
Jun 30, 2010 | HP Color LaserJet 2600n Printer
Fine line running from left to right across page but fades about half across page to nothing, if you print from memory no line, if you run origional thru adf no line, What is causing this line when...
if it is copied on long or legal size of paper are the fine lines on top to bottom or left to right? if it id from top to bottom check for the charge roller, clean an dry it with a cloth, wet with alcohol or water. if from left to right on a legal size of paper check for any vibration coming from the developing unit, like loose gears.
Mar 05, 2010 | Ricoh Aficio 450 Copier
In Print Preview my booklet looks like it will print correctly. When I print my book the 1st page of the 2nd half of the book prints on top of the last page of the 1st half of the book. I have tried...
rint Preview my booklet looks... Solve In Print Preview my booklet looks like it will print correctly. When I print my book the 1st page of the 2nd half of the book prints on top of the last page of the 1st half of the book. I have tried
Sep 11, 2009 | Microsoft Office Professional 2007 Full...
Only printing half a page
Hi KaseyQT,
I noticed your problem and thought I'd contact you about it.
Have you had your printer checked by an expert? As the problem you're having may be to do with the print heads being to close to the paper when printing, this could cause the heads to over heat and be gradually drying the ink while printing or even could be a case of the print heads being to far away from the paper while you're printing.
Also, what sort of paper are you using?
If using glossy paper, have you set the printer to the correct settings? As this could have a big effect on printing, I was once using plain A4 paper but didn't realize that my old printer (Lexmark 4300+) was still set on glossy paper, it was doing the exact same thing.
Instead of re setting the settings of the printer I went to the system restore on the system tools and restored my PC to the last known best working stage (Left click on start, place mouse over All Programs, put pointer over accessories then System Tools and then L click on System Restore, this should give you the choice of either restoring your system to the last known best working point or restoring to a date on the calender provided on screen to a date you knew your pc worked properly.
If this doesn't work then try deleting your printer from your PC by going on to the Control Panel, Add or Remove Programs, left click on your printer once and chose the remove or delete option and then try re loading the disk once your system has re started and you have fully logged back on.
If this still doesn't work, I would suggest getting your printer seen to by an expert or buying a new one.
Hope the information I've given does help.
Oct 08, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Printer only prints half a page
this is a driver problem, try reinstalling the printer with the laserjet4 driver which is a universal PCL driver, this should solve the problem. If not, there is also a blank HP Laserjet driver
May 10, 2008 | HP LaserJet 5L Printer
HP Laser Jet 2840
try to recalibrate the cartridge carousel. the central axel is twisted. there are more than 2 problems like this arownd...
Feb 27, 2008 | HP LaserJet 2840 Printer
HP Deskjet 6940 InkJet Printer Logo
426 people viewed this question
Seeker5211
Seeker5211
