Question about Whirlpool Duet GHW9150P Front Load Washer
MY WHIRLPOOL WASHER IS HOWING CODE # F 21 - Whirlpool Duet GHW9150P Front Load Washer
  • 15,935 Answers
"F21" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 27, 2010
My washer whirlpool duet steam has a code of F 21 what does that mean
The Whirlpool washer error code F21 means the washing machine has a "water draining issue", meaning the drain pump itself, or the drain hose is clogged and the washer is having problems draining the water out
Mar 30, 2018 | Whirlpool Washing Machines
My washer has the code F 21 can you tell me what the problem might be??
I'd check owner's manual, or Mfg web site for your model.
Feb 10, 2018 | Washing Machines
The washer is flashing f 21
Check this video on how to solve the F 21 error code problem
Jan 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What does f-21 mean?on my front loader washer
Please check this video on abut f 21 error code and how to rectify it.
Dec 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Code reading f 21, whirlpool, front loader, washer, duet sport
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:After 4 minutes the “Sd” error will be displayed, then
4 minutes later the “F/21” error code will be displayed. Press
PAUSE/CANCEL two times to clear the display.
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or
kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Mar 03, 2010 | Whirlpool Washing Machines
Code f 21 on whirlpool duet front load washer
cannot open door on washer it is locked and chothes are inside
Jan 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duetsport front load washer
Check the following link:
http://fixitnow.com/wp/2008/09/27/whirlpool-duet-washer-with-f-21-fault-code/
Nov 08, 2008 | Whirlpool AWM5145/2 Front Load Washer
Whirlpool duet f21 and d5 codes
You have me there, my book I learned from doesn't show any d codes.
Sep 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
20 people viewed this question
Dan Webster
Dan Webster
Sal De
