Question about Water Pik Waterpik& Flexible Arm Showerhead
Hello: Have water pik shower head with the flexible tubing (looks like an old scuba hose). The hose has come apart from the "nut" (as they call it) that fastens to the shower spigot. If I push it back in, it stays for awhile but then eventually pops back out again. Not sure if it's broken (permanently) or there is some way it can be attached again. Seems to fit in within a series of "fins" inside the nut. Also the hose revolves freely inside the nut; can't remember if this was true before the separation or not. Thanks
    Master:
  • 604 Answers
Posted on May 12, 2017
lester482529
  • 226 Answers
SOURCE: water leaks from shower head while bath faucet is running
sometimes there are orings or gaskets that get tore in assembly one of those may be bad,or if it is around the threds you might try wraping teflon tape around the thred once or twice.hope this helps
Posted on Jun 14, 2009
muralme
  • 20 Answers
SOURCE: Hi, Advice please, my shower when on hot comes
If you are taking about then neck of the shower head this is what you must do. its no need to turn the water off to the house or to the bathroom first you will need a pair of channel locks and some Teflon tape. first remove the shower head if you dont want to scar the nut on the shower head place cloth between the pliers and the fitting, once removed (very important) turn the channel locks upside down stick one side of the blue handle up in the neck of the shower and rotate to your left to loosen if you are having a leak leak there it should already be semi loose, once removed wrap the threads with the Teflon tape and re-insert making sure it is tight, then wrap the the outer end of the neck with Teflon tape and place the head back on.The reason it leaked is because the plumber who installed it did not tighten it up completly because he wanted it to look straight coming out of the wall and the additional water pressure causes it to leak wheras the hot water causes it to expand and seal
Posted on Jul 16, 2009
  • 20 Answers
SOURCE: I have a Triton Rapide R2 electric shower problem
you can check the pipe lines there are normally more thane one way to set the pressure of the water one by the shower knobs 2 by the behind the head in the wall there are some water valves that may need to be opened up or by the water heater there are some valves there one coming off the heater one just on a pipe by the heater they may need to be opened. try that if that doesnt work come back and let us know and see what else you can do to fix it
Posted on Nov 11, 2009
radar001
  • 1051 Answers
SOURCE: I have a WaterPik shower head that keeps coming
If your unit has a threaded connection for the handle and hose the threads are most likely stripped. You can get thread grip material at most hardware stores and repair it yourself. Otherwise replacement is necessary.
Posted on Feb 21, 2010
jeff_drakesr
  • 155 Answers
SOURCE: waterpik shower head came apart at the water
Try this link its a PDF. http://www.waterpik.com/shower-head/install-shower-head/metal-pivot-ball.pdf
Posted on Mar 31, 2010
Connected shower head to hose and the hose connection to shower head leaks back toward line. There is a white end over the inside of the end of the hose. I believe this restriction is causing the line to...
I understand that the white vac breaker end should be connected to the valve not the hand shower. FYI a little leak from this connection when the water is switched off is normal.
Sep 27, 2010 | Water Pik Shower Head
Water Pik Elements Hand Held leaking at flow adjustment
Shower heads, by and large, are not built to be serviced. There are generally no parts available for even the most expensive head. Consider it a light bulb...when it dies it's dead and there is no rebuild
May 23, 2010 | Water Pik & Wallmount Showerhead
My shower head is corroded with calcium, etc.
unscrew the head from the hose,then put it in a ziploc bag with a vinager and water mixture
Apr 10, 2010 | Water Pik Hand Held Shower
Feb 21, 2010 | Water Pik Shower Head
Hi, Advice please, my shower when on hot comes normal out of the shower head but when water temperature normal it stream out of the bottom of the wall fitting, gainsborough shower 2 years old approx....
Jul 08, 2009 | Water Pik Wall Mount Shower Head
1/2 water through shower head 1/2 through tube
patmac make sure the clear hose is a overflow first. then make sure all connections are correct,sounds like an areator problem,some after market shower heads don't come with one you can purchase one at your local plumbing store.
Apr 05, 2009 | Home
Water pressure drops after a few seconds to almost nothing...
In the hand held shower head where the hose attaches to shower head. In the head there could be a flow restrictor. It may be rubber or plastic. In some cases you can remove it, or check if something is blocking it. Also try running the shower without the head on to see if there is some debris in the hose, and to check your water flow.
Jan 29, 2009 | Water Pik Waterpik& Elements& Handheld...
Water Pik Waterpik& Flexible Arm Showerhead  Logo
49 people viewed this question
Top Water Pik Home Experts
john h
Are you a Water Pik Home Expert? Answer questions, earn points and help others
