Question about Freezers
Hi I live in Zambia, have no power and was given a gas deep freeze 230l. I cleaned the pipe with a brush and hung the swivel back in. I have had it on for about 4 hours but the pipes on the inside are not getting cold although the bottom of the fridge is getting cool. Any ideas on what could be wrong and what I can do to fix it. Thanks. Tris
    Master:
    Sergeant:
  • 449 Answers
Check your flame if to much carbon has built up on the inside exchanger your refrigerator will not cool down hope this helps
Posted on Sep 28, 2010
Freezer side not freezing
Check for ice / frosting inside the freezer .... If present you probably have a defrost problem.... This causes the freezer coil to ice up and block the air flow ... the causes could be a bad defrost heater , defrost timer, defrost sensors, or control board. Also make sure that the condenser coil is clean. remove ALL dust with a vacuum and a coil brush .the coil is located either on the bottom or on the back side of the unit... You didn't give the Make and model #
Apr 04, 2014 | Freezers
Westinghouse wrs6r3ew2
Hi
Check if the refrigerant gas is enough. You can feel this on your compressor motor. if the one pipe from the compressor motor is hotter and the other has to be cooler/warm.
Feb 16, 2014 | Freezers
Frigidaire upright freezer ice forming in bottom and leaking not freezing ice cream
This does not sound good because the breakers tripping may indicate a compressor windings short. Have someone do the test below,
Unplug the refrigerator and remove the back panel that covers the compressor. There should be 3 wires going inside the cover of the compressor. Mark all 3 and mark their location so if compressor is OK you can put them back in same order. The plastic cover may snap on and you may need to squeeze the sides to unlock the cover and sometimes there is a metal clip holding the cover in place. Remove the cover. May look hard but it's simple. There will be three connections under the cover and 2 will go through the start relay. Unplug them leaving the three prongs exposed. They may be marked R =Run, S=Start and C=Common. Set your meter on continuity and then begin by testing 2 at a time until you have checked S to R and R to C an C to S and S to R again. You should get a reading all the way around. If no reading between any of the pairs as you go around you should get no reading between any two the compressor has an open winding and is defective. Then if it passes that test then touch one probe to R and the other to the copper pipes or clean metal on outside of compressor, then S to metal outside and C to metal outside. If you get a reading this way even just a little. The compressor is a burnout. Then let me know what you find. Thanks, Sea Breeze
Feb 07, 2013 | Frigidaire 20 cu. ft. / 566 liter Upright...
Hi, i have a whirlpool chest freezer, and the red light has come on and its not freezing up we have cleaned it out and found it started to freez at the bottom then after about 1 hr it turned to...
dear sir/madam
please make sure first your freezer,s compressor is working if it,s working and it,s not making ice it,s mean your freezer copper pipe has been leak from somewhere because you bring it outside for do clean it. it,s very possible during of cleaning it has been leak .then it,s need to brazing and refill freon gas .
please contact to your maintenance personnel for further action
hope answer the question
thank you
please vote!
Sep 07, 2010 | Freezers
My GE deep freezer seems to be getting warmer. There only seems to be a freezer sensor panel. Does this mean that the sensor is broken or is there another way to get the freezer back to a deep freeze?
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Dec 03, 2009 | GE Freezer  14.8 Cu. Ft. Manual...
How to disable deep freeze? plz give me solution.
If there are two compressors on your unit, disconnect the freezer compressor. If only one compressor, nothing can be done as the fridge and freezer piping are in series. Assuming you have an upright fridge.
Oct 23, 2009 | Amana 15.6 cu. ft. Upright Freezer...
Scotsman Ice maker DCE33PA
check the condenser coil it maybe plugged up use a hand brush to clean out coils and if you can use a air compressor to blow out coils this is the best way and this coil is used to remove heat from the system if it looks clean you can shine a flash light on the opposite side to see the light though the coils to check deep inside other then that the water vale may have a slight leak allowing warm water to seep though prolonging the freeze time or  you may have a compressor with weak valves or low ref. start with the maintenance thats the first thing people usually over look the dirty coil that you should clean once to twice a year that can over heat the compressor and cause it go out.
Dec 05, 2007 | Freezers
Freezers Logo
52 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
