Question about Refrigerators
Water collecting in bottom of unit - Refrigerators
  • Refrigerators Master
  • 19,396 Answers
Hi.
The drain hole located inside the fridge compartment is probably blocked. Most common reason for drain blockage is water freezing in the drain line. Do a complete defrostor use an hairdryer set on cold to free the drain line. The complete defrost is better.
If that does not do the job use a flexible shaft to free the line from debris.To this purpose use a thin flexible shaft called pipe cleaner, along with warm water and vinegar or citric acid. Contrarily to what suggested by users I would not use any soap. This can clog the drain more. Best unclogger in my experience is citric acid and water.Disconnect power before doing the cleanup.
If that is not enough, inspect drain pan and check the drain exit at the back of fridge.
Here the Pipe Cleaner (click).
Here Citric Acid (Lemon Salt) 7oz.
Defrosting clears the problem most of the times, providing that
the fridge is clean and not too old.
If problem is not condensation and clogged drain hole, check for leaks from icemaker and dispenser.
Regards.
Ginko.
Posted on Sep 27, 2010
When defrosting bottom freezer where does water collect?
The water will normally drain out out the lowest point of the freezer and collect in a drain pan outside of the unit close to the compressor area unless its a built-in unit. I hope this helps
Aug 17, 2014 | Refrigerators
Why does ice collect at bottom of freezer?
The freezer has the only coil in the unit that gets cold. IT does build up with ice. The unit has a defrost heater that comes on to melt the ice. The water from this process is supposed to drain down a tube into the bottom pan that you cannot se under the unit. IF the tube is plugged with ice or other debris, the water from the defrost cycle cannot drain correctly and runs into the bottom of the freezer. There is quit a bit of work involved in getting this to work again.
Jul 18, 2014 | Whirlpool Refrigerators
Ice build up in the bottom of the freezer compartment to the point that it will flow under the gasket like a glacier and melt. There is not an icemaker hooked up. No free water is piped to the unit and...
You have a common problem of a clogged drain, in the back bottom of the freezer, behind the shelf and drawers, you will find a drain pan that has frozen completely over with a ice sheet. This has caused defrost water to run forward and collect under your racks in the freezer. I would advice you to turn off unit, and remove all the ice collected in the freezer, clear the pan with warm water, then restart your unit back up.
Once the pan and drain tube is clear, your unit should be fine.
I hope this helps
Aug 02, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
I have a sharp window AC unit, model af-609x. does it have a drain hole? there is no water coming out of it, but when we take it out of the window we get soaked from water somewhere inside the unitl
All window air conditioners will remove moisture from the air if there is any. Most window air conditioners collect this moisture in the bottom pan of the air conditioner and attempt to evaporate the moisture. The evaporation process works as follows: First, the water drips down off of the cold evaporator coils on the front of the unit. Then the water collects in the bottom of the air conditioner base, the "pan." If the air conditioner is installed properly it will be tilted slightly back.
The water then collects near the back of the unit. On some units, the fan blade used to cool the rear condensing coils will have a rim on the outside of the fins of the blade. This rim, or "slinger," will come close to touching the inside of the air conditioner pan when the fan is spinning. As the water collects in the pan and reaches the depth necessary for the fan ring to touch it, the ring will lift some of the water up and the fan will blow it at the condensing coils. Because the coils are warm, they will evaporate the moisture to the outside.
While this is happening it is normal to hear water splashing and sloshing around. As long as there is no water leaking inside the room that is being cooled there is no cause for concern.
Never drill into the bottom of and air conditioning unit to "let the water out."
Jul 22, 2011 | Sharp AF-M609X Air Conditioner
Unit runs all the time and water collects at interior bottom floor.
Is the unit cooling properly? Its a broken or misaligned water hose that runs from freezer to water reservoir for evaporation from compressor heat. Or there is too much humidity causing lots of water to collect inside and your unit is running all time, it can be a case of door not closing properly.
- Please check the door if its closing properly without any gap.
- Any broken pipe inside
- Chiller tray flooded or not in its position.
May 11, 2011 | Refrigerators
Water collects under crisper drawers
Does it have darin at the bottom to drain out the bottom of the frifge into the drip pan? if it does push a wire threw the hole with the unit unplugged.
Aug 28, 2009 | Refrigerators
It seems it's collecting water in the tray and blowing it out through the top vent, dripping from the bottom inside the house and is making a sound constantly like the fan is hitting water as it blows.
AC units do take the humidity out of the air and water collects in the bottom. The unit should be tilted slightly downward on the outside so that the water runs outrside. Make sure the drain holes are clear. The pinging noise is common, the fan is hitting drops of water, nothing to be concerned about
Aug 19, 2009 | LG Electronic Window Air Conditioner
Sunbeam air conditioner
It is normal for water to collect in the lower base of an air conditioner. See the section entitled: "There is water sloshing around inside." If water leaks out the front it is usually because the unit is tilted forward in the window frame. All air conditioners should be installed so they tilt slightly back to allow for proper removal of the condensation collected.
There is water sloshing around inside All window air conditioners will remove moisture from the air if there is any. Most window air conditioners collect this moisture in the bottom pan of the air conditioner and attempt to evaporate the moisture. The evaporation process works as follows: First, the water drips down off of the cold evaporator coils on the front of the unit. Then the water collects in the bottom of the air conditioner base, the "pan." If the air conditioner is installed properly it will be tilted slightly back.
if this helps please give me a fix ya
Jul 14, 2008 | Sunbeam Heating & Cooling
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
