Question about Emerson Home
The in-sink erator did not start , i reset the red botton , it is humming and the electric lights dims but the machine does not start
    Problem Solver:
  • 8 Answers
If this is a unit you have used within the last few days, it may be jammed. You will need to turn off the power to the unit; then examine it to locate & remove the obstructing item. If it is not easily seen and removed, you may need to remove the disposer unit from the sink and examine it more closely.
Posted on Sep 28, 2010
IN SINK ERATOR model 55 hums have reset turned wrench still not disposing
Copy following link:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Humming means voltage is less than 80% nameplate, or start capacitor has burned out.
Replace disposal.
Mar 23, 2013 | Electrical Supplies
Insinkerator model 55 hums
Copy following link for troubleshoot walk-thru:
Check that unit is receiving 80% rated voltage
Humming sound means start capacitor has gone bad.
Replace disposal.
Mar 23, 2013 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
My Badger 5 in sink erator is leaking at the bottom of the unit where the electrical wire is connecting tot the metal plate. When turned on, there is a humming noise but the blades do not spin. I have
Thier is an Allen key hole at the very bottom and center of the badger. Try using that with an Allen key. And if it leaks your from where your wires are coming out of your seal is probably bad. Means new badger
Nov 27, 2012 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My insinkerator is humming and not working. I bought the wrench and keep playing with it but it it stuck. My son insists that the engine is seized but I feel if it were seized it would not turn on at all....
Your Badger 5 spins the blades counter clockwise. If you want to dislodge an item stuck in their, you have to spin the blades clockwise. I use the handle end of my plunger to do this. If it turns free with the handle, it should work when you turn it back on. If you don't hear it hum any more their is a little red reset button on the bottom of the motor housing you must press to reset it.
Sep 03, 2011 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
My garbage disposal won't turn on, and i've felt down there and can't feel anything blocking it...what can i do now
Check circuit breaker.
Check red reset button on side of disposal and see if it's popped out. It's under sink, next to wire connection on disposal.
See if electric switch has gone bad. Listen if disposal makes humming sound. Humming means electric power is good.
Use vacuum cleaner hose instead of hand to check for stuff inside disposal
Use wood broomstick and see if cutter disk rotates freely.
If disk is stuck, wedge broomstick against side of sink opening until disk comes free, or use allan wrench on bottom of disposal.
If electric power to unit is good, and reset will not reset or reset is not tripped out, and if cutter disk rotates freely, then disposal has gone bad.
You can continue using sink as long as there is no leak that will damage cabinet underneath.
I wrote ex disposal replacement steps from my apartment maintenance days.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Aug 15, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My insink erator the red botton will not reset. it won't pop out. The disposal spins but does not dispose of anything. What's wrong? It is less than 6 months old
If the disposal cutter wheel can spin freely but the motor will not operate, and reset is not tripped, then check circuit breaker.
The check for power at the disposal switch.
If disposal is getting electricity, then disposal may have gone bad.
I used to replace disposals, and some went bad right away, and some never stopped working.
Your disposal probably has 2-year warranty. Buy same brand and size and it will connect to same sink strainer basket without changing out everything.
I wrote ez replacement step from days I worked apartment maintenance.
Dec 26, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
MY BADGER INSINKERATOR XP IS NOT SPINNING AND THE RESET BUTTON IS NOT RESETTING. WHAT WRONG.
It sounds like the garbage disposal has a fatal short, and the reset won't push in because there is an electrical failure inside the unit.
Nov 03, 2010 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
The motor on my Badger 5 disposal was humming but not rotating. I cleaned out all the debris, reset it and now there's nothing - no hum, nothing. Is my badger dead?
The badger 5 has a dislodge device on the bottom right in the very center. An allen wrench will fit if you have lost the tool that came with it.
FIrts you will need to dislodge anything preventing it from turning. (Insert the right size allen wrench and turn both directions) The remove whatever comes loose after dislodging.
Then opush the red reset button on the bottom. Check the breaker that powers up the disposal, as you may have tripped it.
If the breaker is on, the unit is turning freely, and the reset button is pushed, then the next step is to check for power using a volt meter, to make sure the disposal is indeed getting power. If all the above has been done, the unit IS getting power then yes, the disposal needs to be replaced.
Oct 11, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Jammed disposal (in sink erator) i believe a nail was lodged there. it came out but it still doesn't work. Had a allens wrench and hit red button and it still doesn't work
My unit was not spinning, seemed like no power after it would just sit there and make that humming noise. Used the wrench to loosen up (if any) debris. I didn't realize the little red reset switch on the bottom was not popping out all the way. After the wrench, I then depressed the red button and it worked fine. I would check to make sure your switch is out all the way before trying other solutions.
Jul 04, 2008 | Dishwashers
Home Logo
205 people viewed this question
Top Emerson Home Experts
Donni Steen
Tom Chichester
Are you an Emerson Home Expert? Answer questions, earn points and help others
