Question about Samsung SyncMaster 753S 17" CRT Monitor
I am not getting any red when i connect the monitor
    Guru:
  • 452 Answers
The RGB red power is missing due to a destroyed capacitor Or the RGB amplifier is dead.
Posted on Oct 16, 2010
Connect rbg cable tv
Contact Arris Support ARRIS for Consumers
Mark
Motorola Support
Apr 23, 2014 | Motorola Audio Players & Recorders
I need detailed instructions on how to connect a wii console to an asus vw266h monitor
You need to get another cable for that WII that is for HD. It has 5 connnectors on it. The red and white are the sound, the other three are for the video.
http://www.amazon.com/s?ie=UTF8&keywords=wii%20hd%20cable&page=1&rh=i%3Aaps%2Ck%3Awii%20hd%20cable
Dec 02, 2012 | ASUS VW266H - VW266H 25.5 LCD Monitor -...
My acer monitor has a vertical red line, about 3 inches long, starting from the bottom of the 23" screen. It is definitely the monitor because when I disconnect it from the computer, the red line...
If there's a minute fracture in the control array, you could find that one of the transistor control lines has failed. Basically, you've got a grid of transistors, with wires connecting them, behind the monitor. Specialised control systems and timing keeps them working, but basically, it's a load of wires turning on and off. If one of those wires gets damaged (From you saying that red is on permanently, it could be a short on the red pixel line) then you get the symptoms you saw.
Mar 10, 2011 | Acer 19" LCD Monitor
When I turn the monitor on it has a red green blue screen
It would appear that the monitor is not getting a signal from the computer. You should try to power down the monitor and remove the power plug and let it cycle. Also, check the VGA cable connections to make sure they are connected properly.
If this does not cause any change, you can try to connect it to a different computer and/or connect another monitor to the computer you are using this Gateway monitor on if you can do that.
Let's start see if we can get this problem solved.
Brian
Feb 07, 2011 | Gateway EV 700 17" CRT Monitor
Trying to connect ps2 to samsung syncmaster have connected the red and whie cables but all i get is a fuzzy black and white picture - do i need a different cable??
Is the cable you are using a set of Yellow, Red & White cables? If so do you have them plugged into the ports on the "side" of the Monitor? or are you trying to use the ports on the back?
It should be hooked up to the ports on the side.
Jan 05, 2011 | Samsung SyncMaster 940MG 19" LCD Monitor
LG 700E CRT 17" monitor,
problem with the monitor Display cable. it is damaged.
Normally monitor will receive 3 colors red, green, Blue signals from CPU. If one cable i.e Red wire connection is missing in display cable which is connected to monitor, Red color image on monitor wil be replaced with other fade color.
So, need the replace the display cable or display connector!
Dec 09, 2010 | LG Studioworks 700S 17" CRT Monitor
My monitor has suddenly turned red.
Is the monitor still under warranty?
Connect the monitor to a different computer (desktop/laptop) to see if the "redness" follows the monitor.
Connect a different monitor to your computer, to see if the video-card (or the "data" cable) is causing the "redness".
A qualified technician would cost $50 to $75 to trouble-shoot.
A replacement monitor would cost $100 to $150, and would come with a warranty.
Sep 20, 2010 | HP Computers & Internet
LG 37lc2 no red
open your monitor and resolder the CRT board. CRT board is a board that attach to picture tube .
Feb 20, 2010 | LG Flatron F700P 17" CRT Monitor
Viewsonic VP930b color problem - Red tint
Go to the setup menu on the LCD panel by pressing button 1 on the front. See if there is an option to reset the lcd to factory settings. Reset it and report if it helps not.
Jul 29, 2009 | ViewSonic VP930b 19" LCD Monitor
Dell monitor 152fpc orange coloring replacing red
If you connect the monitor to a laptop's "video-out", do you get correct colours, or do you still get the "orange" ??
If so, then the monitor is the problem.
Apr 17, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Samsung SyncMaster 753S 17" CRT Monitor Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
