Have a Toshiba TV 42", would like to mount on wall, but need directions on how to remove base. Model #42RV530U, Chassis TAC0801
SOURCE: How to Remove the Base
The 2 screws on each side directly above the stand legs need to be removed. You do not need to remove the big plastic back panel. Remember the TV is heavy, the screws are under pressure and when the screws are removed the TV will drop. I suggest 3 people, 1 to remove the screws and 2 to hold up each side during and after the screws are removed.
If you want to remove the speakers, just disconnect the wires at the TV source, & remove top 2 screws from the brackets on each side of the centerline. Lower the speakers & rotate the bottom forward & out the front.
Posted on Jan 06, 2008
SOURCE: Wall mounting Panasonic Viera 32" tv
Took me a while to find this. Remove the two lowest screw, holding on the plastic back, in the centre and it drops out.  -- Andrew
Posted on Apr 27, 2008
SOURCE: Remove base of Insignia ns-ltdvd26-09 lcd tv for wall mounting
Open up the panel on the back of the TV which covers the various input connections. At the bottom of the area previously covered, there are 8 screws (two rows of four screws). Remove them, and the entire stand should now slide right out of the TV. You can then replace the screws back in their holes, so you don't lose them. You do not need to disassemble the stand to do this.
Posted on Aug 18, 2008
SOURCE: removing base from tv
I researched this problem on the net and found the solution. Someone on one of the posts said the base can be removed by taking out four screws - all from the back of the TV. One screw is the one closest to the power plug, the next screw is beside it, the remaining two screws are the corresponding screws on the opposite side of the base panel (still on the back of the TV). Once these screws are removed the base comes off including the mounting bolt and the rectangular shaped plastic panel. There are no electronics or any components inside the base panel, only the bolt and plastic base which are held on by the four aforementioned screws. It was very easy to remove!
Posted on Feb 25, 2009
  • 2318 Answers
SOURCE: i want to remove stand from 42 to hang on the wall 1080
Click here to download the user's guide and check page # 5 for instructions on how to remove the pedestal stand.
Posted on Jan 02, 2010
Hi,Iwas watching TV and the screen went black.No lights on,I unplugged and plugged again but anything happened. My TV is a Toshiba Regza model 42RV530U. Can you help me? Thanks
If there was a popping noise of any kind when the tv screen went black there's a high possibility that one of the fuses in the tv popped and there is no power to the tv. It could also just be the outlet itself and try plugging the tv to different working outlets.
May 24, 2011 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
My tv is a 42 inch toshiba model#42HL67 im trying to remove the base from the tv so that i can mount my tv
Hi, I have looked into whether or not this t.v. is wall mountable. The only way to tell if this is possible will be to look on the back of t.v. and if wall mounting is possible then there will be 4 screw holes approximately 15 inches apart forming a square. If these " mounting holes are not present then there is no way to mount the wall bracket. Second if holes are present there may be a protective plastic cover at the top of the table top stand where it meets the t.v.. It more than likely is just a snap on type situation and a little bit of prying will pop it off revealing the screws. I hope this has been useful, and thanks for asking FixYa, Good luck- Prodzilla.
Apr 20, 2011 | Toshiba 42HL67 42 in. LCD Television
I have a 42" Toshiba flat screen. It was a floor
Electronics stores don't sell bases for TVs.
Each TV comes with one base, each base comes with a TV. The only way to get a replacement base would be to contact Toshiba and ask them directly for a replacement. For this to work, you'd need the model number of the tv. This can generally be found when you look at the back of the TV, it will have the label on a small sticker somewhere on the back.
Once you have the model number, try doing a quick search on Ebay. Someone may have an old base there that they no longer need, otherwise you're stuck with a wall mount or with contacting Toshiba.
Mar 10, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
42rv530u toshiba tv no sound no picture change power supply and main board
The 42RV530U is known to develop problems in both the power board and the main board. You can check out our power board repair service at
http://www.coppelltvrepair.com/p/442/repair-service-for-toshiba-42rv530u-power-board-75010942-dead-tv-or-clicking-on-and-off-problem
and I'd also recommend that you search for 42RV530U at http://blog.coppelltvrepair.com as we will eventually release an article on how to test the board.
Hope this helps.
Aug 12, 2010 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
I need a pedestal stand for my Toshiba 42RV530U. Do you know where I can get one?
Manufacturer Toshiba Part Number 75010935 Description BASE BASE ASSY, BASE
Aug 08, 2010 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
I want to remove stand from 42 to hang on the wall 1080
Jan 02, 2010 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
The screen goes complete blank with sound still on. It takes to shut TV off and power it on right away to get picture back-though the intervals getting shorter down the road . MY Screen goes black and I...
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Jun 01, 2009 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
Phillips 42 inch tv
Vendor nap.jpg Part Number 310430814621 Description Stand Base
Tritronics, Inc.
(800) 638-3328
call these guys and they should be able to locate it for you or at least tell you where to get one.
Mar 18, 2009 | Philips Televison & Video
Stand base removal
how do you remove the stand of lg 50pg30fd so it can be wall mounted
Jun 15, 2008 | Toshiba 42HP66 42 in. LCD Television
Akai PDP42Z5TA 42 in. Plasma base removal
If you ever get the base off, I'd like to buy one.
Apr 13, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
Electro Med Services...
