Question about Garden
Model 917.273403 craftsman lawn tractor will start and run ok at approximately1/3 throttle and when i move to full throttle the engine starts to miss and then I can see some black smoke come out of the muffler. What might the problem be?
  • 7,482 Answers
Check your fuel tank for debris/trash and clean it out if necessary.
If the mower/weedeater is over a year old, then I recommend that you buy
and install a new carburetor repair kit,because the diaphragm will get hard
and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor
internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small
rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid
and letting it run a few times like that and it will flush the gunk out of
the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to
reassemble the carburetor or follow the instructions you get with the
carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need
to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes
to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first
and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Dec 24, 2010
Why is my Craftsman lawn tractor so hard to start?
Most likely needs valves adjusted. If you can give model number off of the engine, i can try to find the manual or instructions on how to do this for you.
Jun 28, 2014 | Craftsman 21 HP 42 in. Zero Turn Tractor...
My craftsman lawn tractor will start but not move. Canyou please help!
mycraftsman lawn tractor model no. 917.273140 motor will start and run will not move
Nov 06, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I start the engine and it sputters at fast idle and then eventually shuts off.
I think that after you start the engine you need to move the throttle lever off what you are calling fast idle (which is full choke). Simply slide the throttle lever down until it smooths out and runs properly.
Oct 15, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Rpm maxes out and I can't bring it down
check that throttle linkage is ok and free, check that throttle plate is free to move and not jammed - check that srew in the throttle plate is not allowing plate to restrict and jamb throttle
check the governor springs and links are in the correct places and are free to move , check that governor is working ?
if its not migght be governor is adjusted wrong or slipped
or its flown to peices
if unit is ohv model have seen the the ocilating balancer
torque link rod break and cause a engine to go to full throttle
as sson aas the engine was started
please let me know model and type numbers off the engine in question and its make ie briggs etc
and will try help further
cheers paul
Aug 15, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Hard to start lawn tractor
I have 2009 lawn tractor that will not start (from day 1) unless I use a small squirt
of start fluid into the air cleaner area. Nothing else seems to work. The battery will run down before it starts. Once engine is warm it starts great. Love the tractor,
hate the starting problem. Elevation is not a problem in michigan.
Jan 11, 2010 | Briggs & Stratton Briggs Stratton Intek V...
When the choke is fully up the, engine cuts out , canyou help me? can it be the carb. needs new parts? never had problems with this mower. tx. in advance guy
When the choke is full up you are flooding the engine, not allowing it to run. There should be a notch on the throttle control where you move it to after it starts. Moving the throttle control fully up helps get the engine started but you do not leave it there to run. Check the air filter as well it may be dirty.
Sep 26, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Starts OK but after about 15 or 20 minutes starts losing power and after moving throttle up and down for five minutes or so to keep going dies After cooling for twenty or thirty minutes will start and go...
When your ignition coil get to engine temp. it will begin to lose its power, therefore your engine will eventually shut down, when it cools it will start up again,
Good luck
Jul 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
57 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
