Question about Kitchen Ranges
Owner's manual for Permutit 932 water softener
3 Suggested Answers
  • 101 Answers
SOURCE: Pentair water softener leaks water;
open the top and reseat the hole,if not replace the hole. hop this could help you.
Posted on Apr 23, 2008
hmerchant110
  • 7191 Answers
SOURCE: I'm trying to locate a
Please let us know the brand and complete model number of the product.
Thanks for using FixYa.
Posted on Aug 10, 2011
Waterboss 93000 water softener
It most likely is due to a plugged eductor/injector assembly which pulls the salt brine out of the tank to regenerate softener. If it is plugged no brine will be pulled from salt tank during regen but it will keep filling the salt tank and eventually overflow with each cycle. Or there could be a leak in the valve causing the tank to overflow.
Here is the owners manual for your model.
http://www.waterboss.com/media/WB_Softener_V1_Manual.pdf
See page 23
RJ
May 05, 2014 | Water Dispensing & Filtration
Need owner's manual or set-up instruction manual for Pentaier Structural Water Softener - Model #CH30127
That is only the softener tank. We need to know what water softener valve you are using on the tank itself for further assistance.
RJ
Aug 19, 2013 | Pentair 14 x 65 Structural 30785 Poly...
Model 18215 A programing
http://ngsales.net/valves/tech_hb.pdf
see the owners manual here and there are a few pages on programming
Apr 05, 2013 | Hamilton Beach Water Dispensing &...
My water heater is leaking and only 4 years old. Will the use of a water softener void the warranty?
The warranty should not be void by using water softener, BUT read product manual.
http://waterheatertimer.org/Water-heater-manufacturers.html
1) First thing: Why is water heater leaking? Where is the leak?
http://waterheatertimer.org/Leaking-water-heater.html
For example, if you have electric water heater leaking from element, then replace element.
Replace leaking TP valve.
If water is leaking down vent pipe, and combustion chamber rusted out, then vent problem must be corrected.
These are not covered by warranty.
If tank is rusted out, then read below.
2) If water heater is rusted out after 4 years, you might have stray current corrosion.
This happens when hot and cold pipes are not connected together with a ground wire, and/or if cold water pipe is not grounded to earth.
This might not be covered by warranty.
3) Read water heater instruction manual for advisories.
Tanks rust out when anode rod is depleted. Softened water depletes anode rod faster.
Instruction manual says to check anode rod each year.
Checking anode rod is like checking oil on an engine. If oil was never checked and engine burned up, the manufacturer will not honor the warranty.
If anode rod is depleted, and tank is rusted out, the warranty might not cover the rusted tank since owner was supposed to check for anode depletion.
4) Anode rods can also be covered with calcium deposits and stop working.
This night not have anything to do with water softener, but anode stops working and tanks rusts out.
In any case the owner's manual probably says to check anode rod to prevent leaking from rusted tank
http://waterheatertimer.org/Replace-anode-rod.html
Sep 07, 2011 | Water Heaters
I need to know how to set the program on an elite water softener
You can find your owners manual here. http://www.nelsencorp.com/default.aspx?page=customer&file=customer/nelcor/customerpages/Fleck_Serv_Man.htm
Your system is a fleck 5600SE
RJ
Apr 12, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Water softener seems to be draining all the time
http://www.puritecwatersofteners.com/documentation/Hydrotech_5600MI_manual.pdf
I'm pretty sure this is the manual for your unit. It might not be exactly like the one you have but at least could give you info for it. This is something you might have to contact the manufacture for. Hope this helps!!
Mar 31, 2009 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Kitchen Ranges Logo
136 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
