Question about Maytag Performa LAT2500A
Maytag lat2500eea water level wont switch only goes from lrg to ex lrg
  • 15,935 Answers
The LR error on your non-spinning Maytag Neptune is usually, though not always, accompanied either by a burn spot or a blown fuse on the Motor Control Board.
Maytag upgraded the motor and motor control board because this problem was so prevalent. Big rash of these a few years back... and insludes replacement instructions with the kit.
The LR code means "locked rotor" which is just a way of saying the control is not seeing the motor turning.
The image below contains the wiring diagram for this washer as you requested but there are some other things to consider.
Usually when the LR code is displayed the motor has stopped turning for some reason.
By definition the LR code means the control has tried to turn the motor but was unable to.
The error code can be caused by to large of load, to much soap/suds in the water or a problem with the spin bearing.
The cause of the LR message can be little problem like suds or a major problem like the spin bearing and sometimes it's difficult to pin down.
You don't mention in your question if the LR code occurs every load or once a week.
Try running a rinse and spin cycle empty and see if the washer completes the cycle.
The 2nd image contains the information on how to enter and run a diagnostic cycle which may help pin the source of the problem down.
This test completes all functions of the washer is a short time. It will fill, tumble, drain and spin all is a few minutes.
At the end of a successful test cycle a PA should display which means "Passed" and is what you want to see.
Image 1: http://media.fotki.com/1_p,sqwrrqkkqkstsftxgtqsskgwtqkq,vi/kkwrfdskkxkgbffwfww/1/1303472/5961857/image53872img-or.gif
Image 2:http://media.fotki.com/1_p,sqwtrsgdwsqtqsqxgtqsskgwtqkq,vi/kkwrfdskkxkktggsfsw/1/1303472/5961857/image53908img-or.gif
From another source..."Installing replacement motor, motor control harness, and motor control circut board.
Pretty easy install. On a scale of 1 to 10 (ten being hardest) I'd call it a 3.5. If you can use a screwdriver, a wrench, and have played with legos before, you can probably do this job. It took me about 3 hours to do, but this was with inferior tools, and two smoke breaks included.
Minimum tool requirements: Adjustable-head cresent wrench (8 or smaller handle), phillips head screwdriver, utility knife.
Recommended tool equirements: Small ratchet with socket set, ratcheting screwdriver with phillips head and small socket attachments, brew.
The instructions are pretty clear. Once you pull the front panel off, there are two braces at 45 degree angles on the lower corners of the washer. The instructions don't ask you to, but I would remove the brace on the left to make life easier. This gives your arm more room to work and makes it easier to pull the motor out the front.
They ask you to remove the wiring harness from the motor first and then pull the harness out with the control board. My wrench was too big to get to the bolt to remove the harness from the motor. All I did was cut the harness - since they supply a new one - then pull out the control board, then pull out the motor. As far as getting the pulley off, slip it on and off at the large wheel, this is much easier than taking it off at the small motor drive shaft. The only other thing of note is to make sure you look at the diagram for the conectors a few times before you snap it together. There are a few ways you could hook it up wrong so pay attention. There should be no loose ends when you finish. Also, I couldn't get the flange back on on the rear acess panel when closing it up, but it doesnt seem to serve muc purpose besides asthetics, so I tossed it.
The $200 for the parts and shipping was well worth it. I saved about $150-250 to do it myself...."
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$%$
Posted on Oct 01, 2010
Maytag legacy washer
The pressure switch, also called the water level switch, is what control the amount of water goes in the machine, If your machine is constantly filling to the overflow point, then that is your problem. Now, if water is going in and the level is staying the same then your machine drain line is lower than the pump and your siphoning out the water as it goes in. Pull the drain up a little a that should fix the problem.
May 28, 2012 | Maytag Washing Machines
Washer immediately goes into wash cycle when filling with water on initial start.At the end of the spin cycle ,washer dumps water back in to drum.Also,it's not getting the detergent out of clothes. Maytag...
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Jan 26, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
My washer wont aloud my water to go insidethe washer
If the washer makes a humming sound, but no water goes in, and there is no other action, the water shut-off valve is off (outside the washer), or the pipes are frozen.
For top-load washers: If the washer starts agitating immediately without filling the tub, the water level switch is bad (falsely senses the tub is full already) or the water level sensing hose plugged up while there was water in the machine, and it has still has pressure inside it to fool the level switch.
Nov 27, 2010 | Maytag Washing Machines
Maytag pav2300 wont stop filling up. New timer
After the water fill, Switch off the mains, allow little water bleed through the hose that goes to the level switch. As the water flows try fixing into the level switch block.
Clean the water drips to dry and switch on the m/c. It should be alright since you say that the switch is OK when air is blowed!
Apr 01, 2010 | Maytag PAV2300 Top Load Washer
Why wont my washer fill up all the way with water
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Feb 28, 2010 | Maytag Washing Machines
My maytag washer model lav3600aww continues to overfill and overflows
Hi There
I have found some stuff for you to read and hope this helps you. Let me know how it goes.
It's overfilling If your washer is overfilling, check these: Water-inlet valve Water-level switch Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve. Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
thank you for writing to fix ya.
Best Regards Richard
Dec 29, 2009 | Maytag PAV2300 Top Load Washer
Washing Machine wont recoginze the load amount to fill with water, ex..small, med, it justs keep filling up to the brim??
Sounds like your problem is one of three things. Most common is that you have to "reset" the water level. This is done by turning the water level knob passed the large load size, and then down to small. Any time you want to go to a smaller sized load, you have to do this. Another possibility is that the pressure switch is bad, this is an easy fix (although not as easy as the reset) The switch can be purchased thru a local parts supply house. And the last thing could be a bad water valve. This will leak and continue to fill the washer after it is already full, this however is usually followed with water all over the floor. If it is not the reset, write me back and I'll walk you thru the other repairs. Hope this helps!
Dec 08, 2009 | Maytag Performa PAV2200
Maytag washing machine model PAV3360AWW won't stop water on selected water level.
It sound like you have a bad float switch and it is not reading the water level right.If it is filling and wont stop then a possible new water valve is in order:) The float switch is locatted under the top panel of washer
Dec 30, 2008 | Maytag PAV2300 Top Load Washer
Washer fills wont agitate or spin
supposed to be a problem only with water level switch.
hhhmmmnnn...
try checking the hose that goes from the bottom end to the pressure switch. if there is a hole or a crack or anything loose on the connection. if the pressure won't build up on the water level switch, it wont transfer the contacts to start agitating.
test the water level switch by pulling the hose from the drum end and blow unto it until you hear a click on the water level switch. this should turn your agitator so please be careful and watch out for parts moving rapidly.
tnx 4 using fixya,
drcool
Oct 28, 2008 | Maytag Washing Machines
Washing machine wont stop filling up
check hose to water level switch, if it has had an out of balance situation it can loosen or detach hose. replace hose firmly back on switch or replace hose if that doesn't work.
Oct 18, 2007 | KitchenAid KAWS750L Top Load Washer
Washing Machines Logo
53 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
