Question about Phoenix Gold XS2300 Car Audio Amplifier
Phoenix gold xs2300 car audio amplifier schematic'
A student brouht this to my class and wantsa to fix it. No output. Could use a schematic to help solve the problem.
Lights up, fuses good, no smoke or burned parts, a little warm on the resistors.
Help!
Thanks!
Don Olaver
dolaver@yahoo.com
or
dolaver@muhsd.k12.ca.us
  • Cade Austin May 11, 2010
    Phoenix Gold never released their schematics to the public, they did all of the repairs in-house, and all of the IC's, caps, and other circuits all have proprietary numbers on them, with no cross-reference charts available... so finding what you are asking for is nearly impossible (I worked at PG for 4 years).
5 Suggested Answers
  • 631 Answers
SOURCE: Phoenix Gold Octane-R 15.0:1
PG won't release schematic diagrams. Are the burned components resistors? If so, what are their circuit board designations (Rxyz)?
Posted on Aug 15, 2008
  • 109 Answers
SOURCE: need to repair amp
there is something touching or shorting out..could be speaker wire inputs on the inside..if you have it crossed over you could have it backwords or you could have a short in your RCA's..
Posted on Dec 04, 2008
  • 4 Answers
SOURCE: No power out put no lights come on when wired up
did u try an music shop
Posted on Feb 03, 2009
SOURCE: Hi.qx 900.1 d phoenix gold amp recently had a
what were u running from it...?
Posted on Apr 21, 2009
SOURCE: I have a phoenix gold 600.2 and it keeps blowing
check you have a good ground connection, make sure all wires are correctly installed and make sure it is not shorting out (ie none of the wires are in contact with one another) failing this will need more details.
Posted on Nov 11, 2010
Power wires are 3? other then red & block wires what is next conector for?
You have 3 sets of wire connecting to the amp (besides the rca connection), Red is power from the battery, Black is the round wire (shorter the better), lastly Blue is the remote turn on wire. Without the remote turn on, your amp will not power up regardless of the power from the battery.
RCA connectors are for your audio, it carries the noise signal to your amp from the head unit...
Mar 21, 2011 | Phoenix Gold XS2300 Car Audio Amplifier
What is the power and ground?
See manual for your amp posted here
http://download.phoenixphorum.com/Manuals/Amplifiers/XS/xs2300blk.pdf
Power is the B+ terminal, Ground is the B- terminal. The small terminal in-between them is the remote turn-on.
Jan 28, 2011 | Phoenix Gold XS2300 Car Audio Amplifier
Fuse blows constantly !Power light on ? Thanks
Possible that the audio output section is short . remove speakers and fix in the fuse to test, if itt blows out the fault must be confirmed by opening of the amp and disconnection of the power output driver.If teh fuse then stays the fault is confirmed. replace and test the speakers in this section before connecting.
Aug 30, 2010 | Phoenix Gold XS2300 Car Audio Amplifier
How many watts and what is cost
Hey there newton,
Looks to be just over 300Watts. MSRP is $220.00 but they can be had for $100.00 to $150.00
Click here for a review.
Best regards
Mike
Aug 02, 2010 | Phoenix Gold XS2300 Car Audio Amplifier
I need the manual for the phoenix gold xs4300
http://download.phoenixphorum.com/Manuals/Amplifiers/XS/xs4chan.pdf
Jun 12, 2010 | Phoenix Gold XS2300 Car Audio Amplifier
Can i hook up a powered 12'sub to a Pheonix Gold xs2500 amp without blowing the speaker
First I hope you remove the speaker wires from the speaker that come from the built in amplifire. You cannot hook the powered sub to the amp without doing that first. Then all you need to do is run speaker wire from the sub out of the box to the amp. In no way can you hook up any other part of the powered sub, but the sub itself, to the amp. If you know the wattage of the sub and the ohms then wire it to the amp correctly. Your phoenix amp will put out 125 watts x 2 at 4 ohms and 250 watts x 2 at 2 ohms and 500 watts x 1 at 4 ohms bridged. Remember, only the sub itself in the sub enclosure can be connected to the amp. Hope this helped you. Let me know if you need more help.
Aug 23, 2009 | Phoenix Gold XS2300 Car Audio Amplifier
Need to repair amp
Dec 04, 2008 | Phoenix Gold XS2300 Car Audio Amplifier
Aug 14, 2008 | Phoenix Gold Octane-R 15.0:1 Car Audio...
Phoenix Gold XS2300 Car Audio Amplifier Logo
786 people viewed this question
Top Phoenix Gold Car Audio & Video Experts
Matthew Spark
Matthew Spark
Jose Velazquez
Jose Velazquez
Jeffery Lewis
Jeffery Lewis
Are you a Phoenix Gold Car Audio and Video Expert? Answer questions, earn points and help others
