No display...orange led on monitor..... - Computers & Internet
    Guru:
  • 571 Answers
Thank you for using fixya, my name is Carlo.
You have two possible problems.
1. Monitor
2. Computer
Here's what you can do:
1. Unplug the cord which connects the monitor and the chassis or the CPU of your computer. It's the blue one.
2. Let the monitor to turn on even if it's not connected to the chassis or the CPU of your computer. If you can see their a box which is moving around the screen, then, your monitor is working fine. If none, then you should buy a new monitor.
3. If your monitor is working fine because you can see something on the screen after unplugging it from the CPU, then it's the CPU that has a problem on it.
If the monitor passes the test, then, the CPU needs some troubleshooting. Opening a chassis is not that hard but it still need some troubleshooting hands for you to do that. If you are not that techy, I suggest you get a technician to do that or any person who can do the troubleshooting.
Here's the troubleshooting that should be done.
1. Unplug the CPU the drain the power by pressing and holding the power button for 5-10 seconds.
2. Open the chassis. Then re seat the memory stick. Check if it works by turning it on, you have to connect the monitor while checking it.
3. If no go. Unplug, do the same with the hard drive, but most of the time, if the Led is orange, it's the memory that is not working fine.
Hope this helps.
For any questions, leave a message her. But if it helps, please rate and leave a comment and suggestion on how I am doing or on how I can improve my service.
Thank you for using fixya - your best online technical support site.
CARLO
var geo_Partner = 'cca8460f-a562-4792-a693-6fa0e7fcde78'; var geo_isCG = true;
Posted on Sep 27, 2010
    Sergeant:
  • 270 Answers
Monitor are smarter these days than before.
An orange monitor light means that your computer is no providing the monitor a video signal.
This could be because the computer has gone to sleep to preserve power, or the video cable has become disconnected. Some models have multiple input that require you to select the active input.
Please reboot your computer, (press and hold the power button for 5 sec for default shutdown.
If it was a temp glitch, the picture should come back when you reboot.
Today I received a faulty Monitor Dell E773c, the problem is that the Monitor get On and the power LED is Green and after remove VGA Cable from CPU it get Orange, But no Display (The Screen is Blank)
To get monitor work for you, you should connect the VGA cable to CPU. When you remove the VGA cable, monitor has got nothing to display so it goes in stand by mode with orange LED on.
Sep 15, 2013 | Dell Computers & Internet
The power LED of my compaq monitor blinks when powered. Sometimes it works well but after 20 minutes display disappears and it blinks the power LED.
if the light blinks orange after a few minutes after use. The monitor would either require repair or replacement since the power board has gone bad.
Thanks
Proton
Nov 13, 2010 | Compaq Presario 5000 PC Desktop
I have a problem with my dell vostro 200. There's an orange light on the power button and an orange LED on my motherboard which prevent normal display on my monitor. What can I do to solve it?
The power LED if it is flashing AMBER, then the power supply is failing. If the LED is Solid AMBER then the motherboard, or something connected to the motherboard has failed (Video Card, Modem etc)
May 18, 2010 | Dell Vostro 200 Desktop Computer
AOC color monitor model 5En...during power on all led lights blinks then stops blinking without display action. all led lights on no more action observed.
actually if u repair an aoc monitor alone without getting connected to cpu once u switch on the monitor all led's will lit on ( green light ) it will remain on situation until u connect the vga connector to cpu that's the time led's will lit off and only the power led will remain in green condition.some aoc 5en once u power on power led is in green condition and if not connected to cpu it will be in orange condition.hope u get some idea but i am not sure if it will work with ur monitor. but as long as LEDs lit on i think no problem with ur monitor.
Nov 02, 2009 | AOC 5 En 15" CRT Monitor
When I power on I get a green light on the monitor
Monitor is not geting the signal from the PC.
connected the monitor to the AVG port on the rear of the PC and see if you get the monitor to go up. if not, try to get a video card.
Jan 12, 2009 | HP Compaq d530 PC Desktop
Pc wont read monitor
If you look at the monitor there will be an led light on the front that is always orange or yellow when the computer is off but still connected to the monitor. This led will turn green when the computer boots up, sometimes even showing a "no signal" display before boot. If you see the 'command line'  text during the boot process (video info, BIOS version, POST text, etc) then the monitor is being recognized by the computer. If that text goes away and the led goes back to orange then it is a driver or operating system problem. Pressing whatever key is prompted at the lower left of the display, if you have a display, like F1, F2, F10, Delete or whatever will get you to the setup program and all is good with the display/computer connection and a green light will stay on. If you never get that green led light then either the video card is bad or not seated properly
Nov 16, 2008 | HP PAVILION A6230N DESKTOP PC
LED's blinking, no video
Your C5707 transistors in the monitor have failed. Suggest replacing all four with the Sanyo C5707 transistor. A common problem.
Dec 10, 2007 | Dell E173FP 17" LCD Monitor
All three LED's blinking, no video
hi, does the three lights blink only after u connect it to a display card??if yes then check if any of the connecter pins are damaged, or check out the display card..bye let me know
Dec 08, 2007 | Dell E173FP 17" LCD Monitor
The monitor would not turn on. Only the orange LED does.
1. Make sure the monitor cable is fully plugged into the computer. 2. If the new monitor works fine, The connection between the previous monitor and the PC was bad. Reconnect the original monitor to the PC and make sure that the connection is snug. Tighten down the video connectors until they are snug. Try again. good luck..
Jan 06, 2006 | Hitachi CM772 19 in.CRT Conventional...
Computers & Internet Logo
134 people viewed this question
David Payne
David Payne
