My canon pixma ip 3500 printer showing ink counter full.pls.tell me the procedure to reset ink counter
  • 472 Answers
1: Remove Cartridge
2: Unplug the AC Power Cord
3: Hold down the RESUME button
4: Release RESUME after plugging in the AC Power cord.
5: Press the RESUME once within 5 seconds and release the RESUME .
6: Press and HOLD RESUME for two seconds or more and release it.
7: Press and HOLD RESUME for two seconds or more and release it.
8: Unplug AC Power Cord to set data.
I hope this info helps.
Posted on Sep 27, 2010
My Canon printer is pixma ip 3500. My printer is blinking and when i want to print there is a message "the ink absorber is full". Please help me what is the solution? Thank you very much.
All inkjet printers have a waste ink tank for ink which does not make it on the paper. When it's full, the printer stops working. You might be able to reset the counter in the printer, but unless you also emptied the tank, it won't help. It's like using a chip resetter to tell an empty cartridge it has ink. The "out of ink" error will go away but you still can't print. Unless you want to go through the tedious and messy process of emptying the ink tank, you are best off getting another printer. They're practically disposable today.
Mar 06, 2011 | Canon PIXMA iP3500 Printer
Waste ink absorver is full problem canon pixma ip 1200 printer. How can solved is problem
* Download General Tool for Canon iP1200, iP1600, 2200 Printers. Download GeneralTool
* Extract downloaded file the run the software by click GeneralTool.exe.
* Select the connected usb port number from usb port then click lock Release then select the applicable model name in set destination setting.
* In clear waste ink counter, click main to reset the main waste ink counter or platen to reset the platen waste ink counter.
http://downloads.ziddu.com/downloadfile/11558413/resetterforip1600.rar.html
http://canon-printer-resetter.blogspot.com/2009/01/canon-pixma-ip1200-ip1600-ip2200.html
Dec 02, 2010 | Canon PIXMA iP1200 Photo Printer
Sir , my printer canon pixma ip 1200 when i start to print it show waste ink obsorber is full. please help
Hi. I think the problem on that one is the waste ink tank is already full, so you need to clean it or replace the pads on it, because when you are printing or opening your printer it blows little amount of ink to the heads so that it will not be clogged, and that ink goes into the used/waste ink tank. Also after cleaning the used/waste ink tank you need to reset the counter of the printer so that it would print again, you can just download the counter reset software2_bing.gif over the internet or just bring that machine to an authorize canon printer technician. Hope this Helps
Jun 09, 2010 | Canon PIXMA iP1200 Photo Printer
Waste ink absorber?
Hi. As you have not mentioned the make and model of the printer, I am giving here the procedure to reset waste ink counter applicable to most printers. Hope it helps.
Canon Pixma iP1200, iP1600, iP2200 Resetter
  1. Download software for Canon iP1200, iP1600, 2200 Printers.DOWNLOAD Service Tool Software for Canon Pixma Printer iP1200, iP1600, iP2200
  2. Unzip downloaded file by WinZip, 7Zip, Izarc, etc
  3. Run GeneralTool.exe
  4. Select the connected USB port number from USB PORT
  5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
  6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
If you have a different printer model, then please tell me and I will research that for you. Thanks.
Jul 29, 2009 | Canon PIXMA iP1600 Printer
How to reset pixma ip1980
This is the REAL working method of manually resetting Canon ip1880 - ip 1980.
1. Unplug the POWER cord.
2. Press & hold the power button.
3. Connect the power cord WHILE holding the power button.
4. Keep on holding the power button for about 30 seconds.
5. Release the power button. The printer should be turned off.
6. Turn the printer on and that's it!
NOTE: You have to do this every time you turn on your printer. Or you will get the waste pad full error.
Hope this helps.
vulmec.wordpress.com
Jul 11, 2009 | Canon PIXMA iP1800 InkJet Printer
I have my canon pixma 1980 series... error says ink absorber is full and need to reset... please give me a resetter software.... thanks
Manual reset for canon pixma iP 1980 it easy and like resetting canon ip 1880.If found problem in your printer canon iP 1980 maybe this methode can be use. This reset manual be used to reset waste ink counter in canon pixma iP 1980.
Here how :
  • Turn on your printer Canon Pixma iP1980
  • now Press and hold Resume button for two (2) minutes and then release Resume button.
  • Turn off the printer and turn on again, the Printer will back to normal again.
May 02, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
How do I clean out my waste ink on my Canon IP 2200 printer
Hi. I researched on this and found that these steps have fixed the problems most of time. Also, it does the required procedure automatically.
  6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selectedwaste ink counter will be reset. MAIN resets the main waste inkcounter, PLATEN resets the platen waste ink counter.
Feb 07, 2009 | Canon PIXMA iP2200 InkJet Photo Printer
Where is the waste catrage in the PIXMA iP3000
Try this solution to reset the ink tank , it should work for most pixmas and several other Canon printers.
http://www.fixya.com/support/t538192-waste_ink_almost_full
Dec 23, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
My prixma IP 1000 has message "Waste Ink Tank full, contact Service Engg."
Please try below steps on your Printer and let me know the result. I hope this should work.
Steps are:
 Reset waste ink tank counter CANON PIXMA iP 1000
STEP 1:- Disconnect printer from AC power
STEP 2:- Press and HOLD the POWER button, and connect printer to AC power
STEP 3:- release the the POWER button
STEP 4:- Press the POWER button again
This should work. please let me know the result.
Bye.
Oct 18, 2007 | Canon PIXMA iP1600 Printer
Computers & Internet Logo
David Payne
David Payne
