Question about LG L1530S 15" LCD Monitor
My LG lcd monitor Flatron L1530S goes flashing blinking when i turn on the power button,and the power gone off,
    Problem Solver:
  • 6 Answers
Press and hold the power button on your computer for 8 seconds and release... then press once more to turn it back on.
Posted on Sep 27, 2010
Goes to sleep as soon as I turn it on
Hello, If is goes to sleep when you turn on , it has a power supply problem.
Jun 03, 2014 | LG L1530S 15" LCD Monitor
Flatron W2353 monitor wont turn on
LG W2353 dvi power saving mode
how to fix ?
Dec 22, 2012 | LG FLATRON W2353V 23 inch LCD Monitor
Osd locked
To un-lock the OSD - press and hold the MENU button while the monitor is off and then press power button to turn the monitor on.
Feb 28, 2011 | LG L1530S 15" LCD Monitor
LG Flatron - green power led blinks twice
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed LG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 21, 2010 | LG Flatron L1750S 17" LCD Monitor
How do I turn the monitor in
It sounds more likely to have power supply failure if you hit the power button and it does not turn on.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply. You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Apr 02, 2010 | LG Flatron L1951S 19" LCD Flat Panel...
When i turn on my flatron 22 inch monitor the blue power button comes on for a second then goes out,it will not stay on.
HI,
your monitor is not working properly, bcoz monitor data cable no connected properly into the System or any internal problem in your monitor.
Thanks
Aug 15, 2009 | LG 22" FLATRON LCD Monitor
LG LCD Monitor L1530S problems
Most screens will show nothing or go to power saving mode until the PC is turned on. The monitors need a signal in order to be 'active'.
From your description it could just as well be a problem with the PC rather than the monitor. The easiest way to find out is to connect another PC or laptop to the screen or connect another monitor to the PC unit.
Did you try pressing the Del key or F2 key when you turn on the unit to get into the Bios?
Jules
Jul 16, 2009 | LG L1530S 15" LCD Monitor
Lg flatron blank screen
t certainly seems like the monitor is not getting a signal. Did this happen after you changed something, or just on normal boot up?
It could be the video card that has failed.
Also, check the pins on the connector; sometimes they can get pushed in.
If you can, try swapping out the video card or use the monitor on another computer.
Good luck,
May 09, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
LG Flatron L1550S power light blinks green.
shorted components on the circuit. send it to a repair shop if you don't have experience on electronic troubleshooting!!!
Nov 27, 2007 | LG Flatron 995FT 19" CRT Monitor
LG L1530S 15" LCD Monitor Logo
521 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
