Question about Magimix Le Duo 250 Watts Juicer
It wont turn on. i have changed the fuse but still nothing help
    Sergeant:
  • 270 Answers
Devices these days are safety-ed up the whazzoo (technical term)
The safety catches and hardware all must be correct for these devices to work.
It is possible that a keeper or stationary lock of somekind is still installed preventing the machine from working.
Check the outlet to insure you have power there.
Insure all of the covers are in place and then insure a catch is provided for the output.
Failing all that, return it.
Posted on Sep 27, 2010
Wont turn on
check thermal fuse inside tiny as a aspirin non resettable though
Feb 25, 2014 | Juiceman JM480S 1.1-HP 2-Speed All-in-One...
Jack lalanne power juicer mt-1020-1 wont turn on
Hi Have you checked obvious things like fuse or loose wiring in plug?
Jan 01, 2014 | Jack Lalanne Power Juicer 250 Watts
Not working
This juicer has a 10 year warranty and you can contact Omega directly for warranty information and servicing the juicer. The link for their website is below:
http://www.omegajuicers.com/juicers/masticating-juicers.html
Jun 02, 2013 | Omega Vert HD Machine VRT350 VRT 350...
Dash juicer wont turn on
Just fixed this problem!
Take bottom off juicer. The 4th screw is an "odd" one...I drilled the center out and used a flat head.
When you look up inside the juicer, you will see a silver lever arm. It touches the arm lock mechanism (so the juicer will only run when the arm is engaged).
The lever arm should be behind the black lever arm part on the side. When I opened mine up, the silver level arm was on top of the black post thingy. I took a screwdriver and pushed it off the black post thingy, so it the very bottom of the silver lever is behind it. (I can no longer see the entire silver lever easily when it is in the correct position.)
Totally fixed it.
I think it bounced out of the correct spot when I juiced some hard veggies or when I moved it, it hit the counter pretty hard.
Anyway, good luck....I am not a mechanic so sorry if the language is non-technical.
Oct 05, 2012 | Juicers
Philips Avance Juicer 1871 has just completely stopped while juicing lemons - its been cleaned and nothing is stuck, what should I do? Its only 3 months old.
Push the reset button underneath - this worked with mine when the same happened to me; I only realised it was there after changing the fuse, which didn't fix it. I turned it over and found the button and voila!
May 17, 2012 | Juicers
My machine won't turn on when I flip the switch. It is properly connected, I tried it in several outlets - that are working for other appliances and I am left baffled. I haven't used it in about 6...
do you have user's manual with wiring diagram? if not try H.B. If you get one, there is a diode that keeps your machine from frying from over-voltage. Kinda like a fuse, but is not a fuse. If you can check voltage across it, it is not the diode. That is a simple start and the most common problem for not starting.
Aug 03, 2011 | Hamilton Beach 67601 Juicer
Motor wont start. good power through switch. is there a fuse or therma protector? do the capacitors go bad on these?
Hi,every PCB has fuse on it.It varies on the value of the fuse.When short circuit or overheating happens in the system .Fuse will trip off.usually for PCB fuse is replaceable.When it blown out it need to be replaced.Its like a normal fuse.when it blown out it should be replaced by another one.Now there might also a problem with the capacitor it will no longer take and supply power to the circuit.There might be some complications with the IC's on the circuit and if it will not be checked by a technician it may damage other IC's either.Or might be the Power supply or the DC transformer was damaged..Better check it with technician..Hope this helps..
Jun 21, 2011 | Champion G5NG853S Household Juice...
The pulp collection receptacle has a tiny clear plastic button on the bottom. If this has broken off (it happens often) the machine won't turn on. The button must be present to depress the safety switch at the bottom of the machine. If everything else is properly assembled and the machine won't turn on, this is probably the cause. Check the bottom of the pulp collection receptacle to see if the button has broken off. (picture #2) If so, replace it with a piece of pasta or a tiny piece of wood. Sounds silly, but it works. The safety switch at the bottom of the machine must be depressed before the machine will run.
Nov 04, 2008 | Jack Lalanne Power Juicer 250 Watts
Juicer not working...
me too. it was a x-mass gift. got it out of the box and it wont turn on? bummer
Sep 16, 2006 | Black & Decker JE 1500 Juice Extractor
Magimix Le Duo 250 Watts Juicer Logo
172 people viewed this question
Top Magimix Juicers Experts
eyecam
Tom Chichester
David Payne
David Payne
Are you a Magimix Juicer Expert? Answer questions, earn points and help others
