Question about Frigidaire ATF6000ES Front Load Washer
I have teh atf6000ES1
My frigadaire Affinity frontloader is sayin Pau... When i hit any button it goes to Err and beeps 3 times. What can be done to get my machine back working...
Very Respectfully
Rob
  • 4 more comments
  • Romeo_Taz May 23, 2008
    Not that i am aware of... went to put a load it about 2 hours ago and that is when it started happening
    I am try to get my washer to work.. It is currently saying Pau..57. I hit each button to get it to work or clear.. I hit a button and it says Err and beeps 3 times
    It is flashing between pau and 57.. If i hit any buttons it goes to Err and beeps 3 times
  • Romeo_Taz May 24, 2008
    I did as recommended and it showed Err and beeped 3 times than went back to flashing between Pau and 57
    I still have not gotten anything different on my washer
    how hard would it be to install a new board or is it better to call a service man
    Genius:
  • 3,587 Answers
Pau? as in end of life? seems that perhaps the control board is speaking in a foreign language? anything happen recently to make it this unhappy?
Posted on May 23, 2008
  • 3 more comments
  • Patrick Michaels
    Patrick Michaels May 23, 2008
    ok...let me see if I got this straight...the panel is saying Pau...57?
  • Patrick Michaels
    Patrick Michaels May 24, 2008
    do you have a copy of the users manual handy?
  • Patrick Michaels
    try this technique
    unplug the washer for 30 seconds and plug it back in. With in five
    seconds press and hold the start/pause and cancel buttons together. As
    long as these buttons are held in you should get the error code. The
    code should appear as an E followed by two numbers, a number and a
    letter or two letters. We need to find out what the actual error is.
  • Patrick Michaels
    ok..well..that error code states that your control board is really gonzo...you'll need a replacement. This the sort of thing you like to do?
  • Patrick Michaels
    not hard..just dirty...call a service pro
2yr old daughter hit some buttons now it won't - pau 33 pau 33
did you get this fixed? how? my 2 year old son did same thing.
Dec 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Pau err
I have had that problem before...Try unplugging it and plugging it back in...sometimes it's almost like dealing with a computer.
Apr 22, 2009 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire affinity atf6000es1 - control panel locked
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines hope it may for you..............And please rate me if helped
Feb 21, 2009 | Frigidaire ATF6000ES Front Load Washer
Error messege, front loader wont start.
my name is joyce
first try the simple step, unplug unit for 60 secounds, then replug unit back up. reset load and see if that works. let me know if I can be of further assistance.
joyce
Feb 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Affinity washer displays ERR. PAU and 56
I fixed this myself and it only took about 5 minutes. The problem is the door latch needs to be reset, which requires unplugging it's three electrical connections. This has to be done inside the washer outer seal, but it is easy to get to. First remove the outer ring that holds the seal on. Next remove only the side of the seal closest to the door latch (again only the outer seal needs to be undone). With this done remove the two screws holding the door latch in place (inside). Remove the latch, unplug the three connectors, plug them back in then reassemble everything. When all is back in place hit "cancel" and it should be good to go.
Dec 27, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire affinity indicates 'err' light - nothing else
Dear Abhkss
ngfam at you service,
Sounds like you need service for electronic parts!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
Aug 25, 2008 | Frigidaire ATF6000ES Front Load Washer
Machine stuck on pause/err
un plug the washer for 5 minutes and re try
May 28, 2008 | Frigidaire ATF6000ES Front Load Washer
Err pau
Press "stop" & "cancel" together for over 10 seconds to clear the display; and continue your..........
And rate me pl.......
Dec 01, 2007 | Frigidaire Affinity ATF7000E Front Load...
Err Err err err err pau
Nov 15, 2007 | Frigidaire Affinity ATF7000E Front Load...
Affinity Washer: Will only display 56...Pau, Err on any button
This was exactly what was wrong with my washer!!!!!!!!!!!!!!!!!!!! Stupid Easy Fix! I would recommend leaving it unplugged until you are ready to undo the plug for the door lock. This was a perfect solution!!
Feb 27, 2007 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Frigidaire ATF6000ES Front Load Washer Logo
367 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
