Question about LG LP1200DXR Portable Air Conditioner
Compressor wont start..blows hot air - LG LP1200DXR Portable Air Conditioner
This unit changes the mode from Cool to Fan constantly. Even tho I set the mode on Cool, it runs as Cool only 1~2 minutes and changes the mode to Fan. But it says its Cool. But I'm not fool. I can say what's fan and cool. If it's normal situation. This is just piece of ****. I have read trouble shooting 10 times but I don't know what's wrong.
Posted on Jul 08, 2011
  • LG Master
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Sep 27, 2010
I have a 1998 oldsmobile intrigue 3.8 ltr. AC was blowing hot air. Vacumed system down. Now compressor wont start, wont take freon. Low pressure switch is not on receiver drier or firewall.
It should still take refrigerant even if the compressor isn't running--but it'll be a LOT slower. Whatever you do, DON'T jumper across the low pressure switch. That'll start the compressor clutch and the system will run with low or no refrigerant. The refrigerant is what carries the oil, so it'll burn up the compressor.
Jun 18, 2017 | Oldsmobile Cars & Trucks
MY AC blows hot, it wont take a charge. a shop told me it needs a compressor so put on a new one and still won't take a charge and blows hot air
Hello again. is your heater tap actually operating? its not stuck on hot is it? just check the tap actually moves when the hot cold selector is switched.
Jul 06, 2012 | Oldsmobile Cutlass Supreme Cars & Trucks
My pacr10 blows air but compressor wont kick on
sounds like a blockage in the refrigerant circuit, the compressor is shutting down, protecting itself. possibly the compressor is overheating, possibly it's overcharged.
Oct 13, 2017 | Windchaser PACR10 Portable Air Conditioner
Air cinditioning wont stay on, it switches to heat and wont shut off
What do you mean when you say it wont shut off? is it blowing hot air or do you just feel a lite flow of hot air even if you have the settings to cold?
If this is the problem that you always feel hot air at low flow and the ac goes to hot air then i would say one of two things, first if you have the selector to cold and you feel hot air then there may be a problem with the blend door, this door move to allow hot or cold air, the door may be broken or just a bad motor that controls it. keep in mind if the ac system shuts down for any reason the air then will be warm, it will be about the same temp as outside and maybe a little hotter.
this problem almost sounds like the ac compressor shuts off and then you are getting the outside air which is hot, there are many reasons for the compressor to shut off, it could be the compressor clutch heating up and disengaging , this would be due to a bad compressor clutch.
another reason is the fans are not working, the best thing to do is when the system starts to blow warm check and see if the compressor is running, start engine and look at the front of compressor, with ac off the front of it will not move, and then with ac on the front will spin, check it out and let me know, if it blows warm air and ac is not working then it may be compressor problem but if you are getting warm air and the compressor is spinning then it may be a door problem.
This is hard to check with out testing the system, so i listed a few things to check and let me know the out come. also the ac blows cold for how long before it gets hot air blowing out of the vents, good day.
May 25, 2012 | 2000 Dodge Grand Caravan
2008 3500 55890 miles a/c just blows hot
you may have a high pressure problem or a high pressure switch defective also make sure you have good air flow clean condeser
May 30, 2010 | 2008 Dodge Ram 3500
My 2002 Expedition air conditioner will sometimes blow hot air and others cold air
I would check the following possibilities:
1. Is compressor clutch working? - You need to do this when the ac is blowing hot air only - locate compressor drive pulley on engine - rubber belt wraps around it. Start engine and set to max ac. When the ac is blowing hot air, look at the center of the compressor drive pulley using a good flash light - watch it for a while, it should be spinning with the pulley - this means the compressor is engaged. If not, the compressor is not engaged. If your ac is blowing hot air, then the compressor should be engaged and running (trying to cool). If it is not engaged, then your compressor clutch is probably going out. Could be low voltage to clutch, but more likely the clutch is worn out and only working some of the time. Note: if working normally, the compressor clutch will engage and disengage in cycles- but the air should always be cold. If clutch is bad, compressor would need to be replaced (sold as one unit). This is tricky to diagnose and could take some time - you need to do it when ac is blowing hot air but set to max cooling.
2. Low on refrigerant or refrigerant has moisture in it? If your ac blows cold initially after being off for a while, then heats up, and continues to regularly cycle back and forth between hot and cool air, then the system may be low on refrigerant or the refrigerant may have moisture in it that is freezing and restricting refrigerant flow. An a/c shop can check refrigerant level and even replace refrigerant if moisture is suspected.
Could be other issues, but I would start with these.
Good luck
May 07, 2010 | 1999 Ford Expedition
My duted air conditioning started blowing hot air instead of cold and then stopped. blew a fuse and now will not work
Sounds as if the compressor has gone bad. The blowing of hot air and then the fuse blowing lets you know the compressor is pulling a lot of amps causing the fuse to blow and no cold air could mean the compressor is locked up and therefore you need a new compressor.
Dave
Jan 24, 2010 | Honeywell ER150B Air Conditioner
2005 KA blowing hot air out when set to cold
start car.turn on air conditioner high cool .raise hood look to see if the compressor clutch is engaged and running.if yes your ac air door could be stuck closed or the air door vacuum actutator not receiving vacuum.a vacuum line is broken or off. or the control switch bad.that control the AC and heater mode. if compressor clutch is not engagged.check for power at compressor clutch.if yes compressor clutch coil open. or the air conditioner refrigerant R 134 is low take car to a private garage with a good reputation. they wont be expensive as the dealership.have them hook car air conditioner to a manifold gauge set to check your refrigerant low side and high side pressure.
Jun 24, 2009 | 1999 Ford Taurus
Air conditioner wont cool
the compressor has a capacitor that helps to start the compressor if the compressor does not reach the speed required to jump from the start coil to te continum work in about 10 sec the termic protector disconect the compressor for about 5 minutes but the blower or fan does work just blowing the air and that is not cold
Dec 31, 2007 | Heating & Cooling
LG LP1200DXR Portable Air Conditioner Logo
570 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
