Question about Sony KDS-R50XBR1 50" HDTV
I turned my TV on and no image appeared, it stayed completely black. The power/standby light just keeps blinking with a yellow light at a steady pace. Its not the lamp light (which is below the power/standby light) so I am not really sure what the problem is. Any help would be much appreciated!
    Scholar:
  • 120 Answers
Well the blinking is an Error code, The TV circuits are detecting a problem, preventing power on and displaying the error code. Unfortunately the codes are not very useful .Next step would be to open i up and check for power at a few points. Look for poped caps etc, Aside from that take it in for repair or sell for parts
Posted on Sep 27, 2010
What component board on the Toshiba regza 42rv530u needs to be replaced? Where can I purchase this component online?
My advice is take it to a television repairer. It is far cheaper in the long run. Fixya is full of people who have bought every board off eBay and still don't have a television that works. Correct diagnosis is the key plus experience of that particular make or model. The course to be a television engineer is 2 years full time college course.
Jan 24, 2018 | Toshiba Televison & Video
I have a Hisense led tv model F39V77C.
Yeah, replace the set since it appears to be trashed. But if you have a few bucks lying around you might want to try replacing the unit's power supply to see if that resolves the many issues you have.
Jan 03, 2017 | Hisense Televison & Video
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
Sharp lc-32sb220u lcd tv. Green Power LED flashes steady
Okay, I found the problem. There is a problem with the
ccfl (lamp) groung PCB. Mine is completely burnt through. I am going to attempt to repair it, but will likely need to extract it from a different unit. This board is on the front right of the lx in the lamp housing behind the
lcd panel. What is happening: The inverter circuit on the power supply is detecting that one of the lamps is not lighting and it goes into shut down.
Hope this helps!
~Seth
Feb 07, 2012 | Sharp LC Televison & Video
Hi i have a kp-57HW40 sony projection tv. Right now it is failing, and when I turn it on I hear multiple clicks. The screen will not even light up, just stays black as it if were powered off. On the...
Thats the error for having a issue with the +5V which can be caused by either the A board or the B Board with the B board being the most likliest cause.
Jul 09, 2011 | Sony KP-57HW40 57" Rear Projection...
Standby light stays on and the tv will not go on
Please check batteries in remote that seems not working. Sony TV would either turns On or standby light will blinks if TV gets any internal problem.
You question shows standby light stays On that means TV does not receive power on command from remote.
If standby light is blinking in sequence, let me know how many times it is blinking and also intimate exact model number of TV to find out possible solution.
Thanks.
Sep 21, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Green spots/pixels at top of TV screen
I have a 50" Pioneer PDP-503MXE with the same problem - the fans don't run. It appears to be a problem with the temperature sensor that controls the fan speed. However, the fans can manually be switched to MAX.
To do this, put the display in standby. Press the 'Menu' button and within 3 seconds press the 'Power/Standby' button. The 'Integration Menu' will appear. Select the 'Option' tab on the right. Scroll down (next page) to the 'Fan Control' option. It will most likely be set to 'Auto'. Press 'Set' to change it to 'Max'. Within a few seconds the fans will run.
At Max the fans are a bit noisey but it will cool the unit down.
May 05, 2009 | Pioneer PureVision PDP-503CMX 50 in....
TV turns itself off.
if you now how to used soldering iron , resolder your tv
Oct 22, 2008 | Televison & Video
Black Screen / Computer Stays in Standby Mode
Completely remove the battery and unplug the power cord for a few minutes. Reinsert battery and power up. You can also hit F8 when starting and see if you can boot into safe mode.
Sep 06, 2007 | HP Compaq Presario V2000 Notebook
Sony KDS-R50XBR1 50" HDTV Logo
88 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
