My Xerox B/W Copier XC 1044
All I get is a flashing "H4" code. Xerox support said "Reseat the Fuser". I did and still get the same H4 code. The Fuser Bulb appears intact and shows OK on a multimeter continuity check, and the copper contacts are proper and centrally connected. What should I look for next?
  • dansalvo Jun 09, 2008
    No p-aper jam/toner looks fine
    Power cycling already tried many times. Still "H4" display. Fuser was "reseated"-no help. Are you suggesting I purchase a new replacement Fuser ? I already thought of that but would expect some degree of certainty before replacing expensive parts. Is there a way to "default" or clear the "H4"?
    Genius:
  • 1,447 Answers
Power cycle the unit and reset it to default, if you have the same error try replacing the fuser.
Posted on Jun 09, 2008
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Jun 09, 2008
    Resetting the settings or clearing all warnings should get rid of the error but if you had the fuser for quite a while then chances are you need to replace it, that is a consumable part of the printer actually.
    Master:
  • 555 Answers
When was the fuser last replaced?
    Brigadier General:
  • 3,614 Answers
Look for any paper jam, and inspect the toner
  • micromaster
    micromaster Jun 09, 2008
    An H4 Error code indicates a low fuser temperature, below normal operating conditions. Try first turning off the power supply for 5 seconds, then back on-
  • micromaster
    press then release these buttons individually, in this order: "clear" "exposure mode" "clear" "exposure mode". after this set number of copies then press print button. if this fails the fuser unit is faulty..
    let me know..
    please rate my solution here.
I have a number 4 and a letter H flashing
To reset the H3 or H4 condition on just about any Xerox XC or XD series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
This procedure will work on all Xerox XD and XC models
Good Luck and Thank You for using Fixya
Jul 16, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
Tip
Xerox XC and XD series copier H3 or H4 error code reset procedure
This procedure will work on all Xerox XD and XC models.
on Mar 20, 2010 | Office Equipment & Supplies
XEROX COPIER XC865 HAS AN H4 ERROR CODE HOW TO RESET AND WHAT DOES IT MEAN
H4Fuser temperature too low. Must be reset in diagnostics
Dec 18, 2009 | Xerox XC356 Copier
Xerox model # XC1040 flashes H4 when turned on will not make copies ? code
H4 is a fuser error code. it basically means that the fuser is heating up. from what i can see the fuser lamp alone will be about $60.00. that would be the best case scenario if the rest of the fuser parts are ok. the upper fuser roller is 135.00 and lower 144.00.
Oct 16, 2009 | Xerox Office Equipment & Supplies
Xc 1040 xerox Red light is flashing and the copier will not
On a XC 1040 machine either there is a jam on the fuser, the fuser switch fell out of place, or the sensor swich arm fell off the registration sensor.
Since we cannot see the machine we might understand what is taking place.
If the machine is turned off and back on and there is no red light, then the machine must be able to attempt to make a copy. If a copy does not come out, then there is problely some worn feed rolls.
If when the machine is turned on and there is a red light then th There can be some bad paper feed cluthes as well.There might be a paper stuck at either fuser assemly or paper feed roller areas.
Provide more description about the visuals on the machine.
Good luck.
Jul 15, 2009 | Xerox WorkCentre 4118 Network Kit...
My copier ( xerox xc1040 ) hit a power surge . It
i speak a littlebeat english.
H4
00
Low Temp
you cant erease this code
in panel control
press (clear ) (exposure select key) (clear) (exposure select key) (14) & (start key)
14: Resets H3, H4,
Feb 28, 2009 | Xerox Office Equipment & Supplies
Xerox pro 215, error H4 please help
H4 is a fuser error....not getting up to temperature.
Press [C] (Clear), press [Image Quality], press [C] (Clear) again, press [Image Quality] again.
If this doesn't bring it back to operations then the fuser lamp needs to be replaced.
Jan 17, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Xerox XC 1020 copier code H4
With "H4" flashing press:
1.Clear button
2.Auto button then again
3.Clear button
4.Auto button
It should be done quickly. If it's done quickly enough all lights on display should go off.
5.Enter number 14 (as if you are making 14 copies).
6. Press START/COPY button.
The machine goes back to normal. If not, thermistor on the fuser (heater) should be replaced.
Sep 02, 2008 | Office Equipment & Supplies
Xerox Copier problem
Turn power on and within 4 sec.press the following sequence;clear,exposure,clear,exposure.The screen will go blank.Enter '1' and '4' then hit print.turn off. This will reset H4 if the fuser has no problems such as a bad fuser lamp or thermal fuse.And yes it,s worth fixing with the right guy working on it!
Jun 30, 2008 | Xerox Office Equipment & Supplies
Here you go. If you have no underlying problems this should work. If it comes right back, you have a fuser problem.
  1. Turn the power off.
  2. Locate the Clear Button, which is grey in color, in the upper right corner above the green Start Button.
  3. Locate the Auto Button the lower left corner of the Control Panel.
  4. Turn the power back on.
  5. Press the buttons in the following sequence, releasing each button after each time you press it: [Clear], [Auto], [Clear], [Auto]. Every light on the Control Panel should go out, and the error code should clear.
  6. If the error code has not cleared, wait a few seconds then repeat Steps 1 through 5.
  7. Program the copier as if you were going to make 14 copies.
  8. Press the green [Start] button to store the reset code. The copier will return to the ready position.
  9. Run a test copy.
Jun 09, 2008 | Office Equipment & Supplies
287 people viewed this question
k24674
jasbo
jasbo
