Question about LG Heating & Cooling
The compressor wont turn on....just blows hot air!
  • LG Master
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
aa
Posted on Sep 27, 2010
I have a 2002 pt cruiser that is blowing the ac 10amp fuse repeatedly. I mean within minutes of changing it. Also the ac is only blowing hot air. Can someone please help.
An AC system blowing hot air is usually due to a low freon charge or a non operational AC compressor. If the fuse blows, disconnect the compressor electrical plug and turn on the AC. If the fuse doesn't blow, suspect a compressor problem. If the fuse continues to blow with the compressor disconnected, there is a direct short between the ON/OFF switch and the compressor which can take hours to diagnose
Sep 07, 2015 | AC Cars & Trucks
MY AC blows hot, it wont take a charge. a shop told me it needs a compressor so put on a new one and still won't take a charge and blows hot air
Hello again. is your heater tap actually operating? its not stuck on hot is it? just check the tap actually moves when the hot cold selector is switched.
Jul 06, 2012 | Oldsmobile Cutlass Supreme Cars & Trucks
My pacr10 blows air but compressor wont kick on
sounds like a blockage in the refrigerant circuit, the compressor is shutting down, protecting itself. possibly the compressor is overheating, possibly it's overcharged.
Oct 13, 2017 | Windchaser PACR10 Portable Air Conditioner
Air cinditioning wont stay on, it switches to heat and wont shut off
What do you mean when you say it wont shut off? is it blowing hot air or do you just feel a lite flow of hot air even if you have the settings to cold?
If this is the problem that you always feel hot air at low flow and the ac goes to hot air then i would say one of two things, first if you have the selector to cold and you feel hot air then there may be a problem with the blend door, this door move to allow hot or cold air, the door may be broken or just a bad motor that controls it. keep in mind if the ac system shuts down for any reason the air then will be warm, it will be about the same temp as outside and maybe a little hotter.
this problem almost sounds like the ac compressor shuts off and then you are getting the outside air which is hot, there are many reasons for the compressor to shut off, it could be the compressor clutch heating up and disengaging , this would be due to a bad compressor clutch.
another reason is the fans are not working, the best thing to do is when the system starts to blow warm check and see if the compressor is running, start engine and look at the front of compressor, with ac off the front of it will not move, and then with ac on the front will spin, check it out and let me know, if it blows warm air and ac is not working then it may be compressor problem but if you are getting warm air and the compressor is spinning then it may be a door problem.
This is hard to check with out testing the system, so i listed a few things to check and let me know the out come. also the ac blows cold for how long before it gets hot air blowing out of the vents, good day.
May 25, 2012 | 2000 Dodge Grand Caravan
Brick Air blowing hot air
if you hear the compressor turning on,no heat, the coolant has leaked out. if the compressor doesnt turn on, its a control issue.
Jul 25, 2009 | Heating & Cooling
2005 KA blowing hot air out when set to cold
start car.turn on air conditioner high cool .raise hood look to see if the compressor clutch is engaged and running.if yes your ac air door could be stuck closed or the air door vacuum actutator not receiving vacuum.a vacuum line is broken or off. or the control switch bad.that control the AC and heater mode. if compressor clutch is not engagged.check for power at compressor clutch.if yes compressor clutch coil open. or the air conditioner refrigerant R 134 is low take car to a private garage with a good reputation. they wont be expensive as the dealership.have them hook car air conditioner to a manifold gauge set to check your refrigerant low side and high side pressure.
Jun 24, 2009 | 1999 Ford Taurus
Air conditioner
If the fan blows cold air the compressor is already on.
Jul 18, 2008 | Heating & Cooling
Air conditioner wont cool
the compressor has a capacitor that helps to start the compressor if the compressor does not reach the speed required to jump from the start coil to te continum work in about 10 sec the termic protector disconect the compressor for about 5 minutes but the blower or fan does work just blowing the air and that is not cold
Dec 31, 2007 | Heating & Cooling
Heating & Cooling Logo
77 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
