Question about Sharp AR-160 Copier
Sharp ar-161 l6 problem,how can you reset the machine do you have to replace the scanner? thanks for your help
  • 33 Answers
SOURCE: sharp AR-5316, showing L6 on display
The L6 code means trouble with the laser unit ( polygon motor), it has to be replaced. The laser unit is under the exit tray. Hope this helps.
Posted on Jan 02, 2008
  • 61 Answers
SOURCE: Sharp AR-162 Laser Unit
Hi, the laser unit is situated under panel where the copies come out. Replacing the unit requires removing the front op's panel and sliding the panel out. the unit is held in with four screws, rear ones can be tricky, unplug and replace.
regards
Andy
Posted on Jan 20, 2008
SOURCE: 5316 SCANNER DRIVER
the sharp 5316 does not work as a scanner
sorry for that
Posted on Feb 12, 2009
007tech
  • 95 Answers
SOURCE: need to reset key operator code on Sharp AR-287
Make sure the copier is in "copy" mode.
To get into service mode press the following keys one after the other "P" key - "interupt" key - "clear" key - "interupt" key (do not play around with setting in service mode as this can render your copier useless)
enter 22 and press "start" enter "7" and press start. This should display the admin code.
Restart the copier and you should be good to go.
Posted on Mar 26, 2009
M2Tech1
  • 313 Answers
SOURCE: Sharp AR 163 display L6 error
The error is for the polygon motor if you have done the test for the motor and it doesnt work I think thereis the answer because they spin so fast the motors will eventually go if it had been a little noisy p[rior to this then it has a read or seize error if you know how to take it out youcan manually gently spin it to see if it is stuck just make sure you use a clean dry cloth to cover it prior to turn as you might mark the mirrors.. Good Luck A
Posted on Jul 01, 2009
Service l6 10
Sharp AR-M207 . Enter these keys one after the other to reset:
  1. # - * - C - *(pound, star, C, star).
  2. The screen will go blank and ask you to enter a code
  3. Enter "14" and press the print button.
  4. It comes back and asks if you are sure(showing "1" as default). Press enter.
  5. Machine should then reset
Aug 21, 2013 | Sharp AR-275 Copier
I have a Sharp AR-M280N copier and it has an error code of L6-10 on it can you tell me what that means?
An L6-10 code means that the polygonal motor isn't rotating at 25,000 r.p.m. This motor is located inside the laser unit of the machine. You can try this procedure to try and reset the machine. Press the following buttons in this order: #,interupt,C,interupt,1,4.The operation panel may ask if you want to do this, choose "yes or 1". Then press the "copy" button as if you were making a copy. This will reboot the copier. The polygonal motor will need replacing soon regardless.
Oct 15, 2010 | Sharp AR-275 Copier
My Sharp AR-M205 Copier has developed a problem. The code L6 is flashing up on the Display panel. Someone suggested I might be able to fix it by 'resetting' the machine. Can anyone advise how precisely to...
L6 is polygon motor lock (in the laser unit). To try and reset on the keypad press P * C * (pound star clear star) and enter sim 14 and press copy button. the machine should restart if down right. If the code comes back the LSU unit will need to be replaced. Should be done by a trained tech.
Aug 25, 2010 | Sharp AR-M205 Copier
Sharp AR-M205 - Error Code L6
Hello sir; "L6" display it means laser motor defect need to replace.
Aug 19, 2009 | Sharp AR-M205 Copier
I have a sharp AR-m205 with a flasing l6-10 erro message. Can the machine be reset?
Hello sir; the code you display,can not be reset, the problem of it, is laser motor bad you need to replace one.
Jun 11, 2009 | Sharp AR-M205 Copier
The L6 code is flashing on my copier
No you can't, it is the polygon motor not rotating. It is inside of the Laser unit. You should replace the polygon motor. The part code is RMOTN0028QSZZ. It will cost you about US$ 80
Jun 04, 2009 | Sharp AR-160 Copier
Sharp Photocopier AR 161
it is the signal h4 if this it is the problem heater unite
Jan 07, 2009 | Sharp AR-161 Laser Printer
Error code L6
L6 is a Polygon Motor Lock
You could try to reset the machine with a simulation code 14, which to perform it:
1. Push Clear, Auto, Clear, Auto in a steady rythmic fashion. If done correctly the screen will go blank and all the lights will turn off. If done incorrectly wait 15 seconds then try again. Clear is the red "C" and auto is on the left hand side, the word auto directly above the button.
2. Once you're into this mode enter the number 14 as if you were doing 14 copies then push the green copy key.
If the L6 returns after the reset then you will need service on the machine, Sharp will fix it for a flat rate charge of $140.00 for parts and labor out of warranty. Give them a call 1800 237 4277 in this case.
Dec 26, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316, showing L6 on display
Jan 02, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-160 Copier Logo
182 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
