Question about Samsung SCX 4521F All-In-One Laser Printer
Paper feeded is constantly jamming. Help help help
  • 360 Answers
Hello please clean your paper feed rollers and seperation pad
Posted on Sep 28, 2010
Getting a constant "Paper Jam 071-100" error when printing from Tray 1 (no jam found).
You need to replace the paper pick up, feed rollers and separation sub-assebly.
Nov 27, 2012 | Dell 3115CN
Duplexor jams paper when pulling in for 2nd page
Would need to see it in the shop, there are too many things to check, missing or bent rollers, springs out of place, ink build-up on rollers, paper scraps, dirty encoders. Too many to try and help here...
Jul 01, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Paper feed jams
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 08, 2009 | HP Photosmart C7280 Laser Printer
Samsung 6210 paper jam
open access(load area) check feed roller take a q tip and use rubbing alcohol and clean photo eye that detects paper be sure all jammed paper is removed
most jams are at the exit and there may be some paper obstructing that area
insert card stock through the paper path
insert ine
Dec 30, 2008 | Nikon COOLPRINT Thermal Printer
I have a canon L380s Fax with a paper feed problem, the paper pick-up tyre constantly rotates, causing, obviously! paper jams. I had the side off but can't quite work out how the planetary gear clutch...
There is a soloniod arm on the lower left side of the machine that hook on the feeding clutch.Check the soloniod for any problems.
Please rate me!
Nov 04, 2008 | Office Equipment & Supplies
PAPER JAMS
Does the fault clear when you open/close? If it does you probably don't have a jam.
Does the machine begin to try to make copies, then stop-if so it has probably failed to feed off the tray, hence the jam message.If this is the case, pull out the paper tray, check for obstructions, clean feed rollers and try again.Are there "skid marks on the paper(indicating the rolls have turned?) If so rolls could be dirty/worn. If no skid marks, can you determine if the rolls did in fact turn? Go from there
Nov 11, 2007 | Office Equipment & Supplies
Constantly jams
Xerox has some good information on their web site regarding troubleshooting problems with their printers. I'd first suggest you visit there for help. As for general jam problems, try to determine where the paper is jamming. If it is a feed problem, for example, you can clean the feed rollers with Isopropyl Alcohol or run them over the sticky side of clear packing tape to clean them. If the paper is folding or getting stuck somewhere, look for what might be blocking it. I've seen this happen when one page jams and the page is torn and part is left in the printer. I've also seen situations where labels were put through the printer and some got free and stuck to the inside of the printer causing jams. If you can provide a bit more detail on where the jam is located, we can help you find the cause.
Aug 22, 2007 | Xerox Phaser 5500N Laser Printer
Samsung SCX 4521F All-In-One Laser Printer Logo
219 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
