Question about Canon Cameras
Lens not openning or closing - stuck in the middle and it says "lens error, will shut down automatically, restart camera"
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Sep 27, 2010
My camera says..lens error will shut down automatically restart camera..! so my lens wont close even when i turn my s100 on or off. please help???
Make sure there is no dust or foreign material that could be jamming the lens and lens shutter. Have you tried removing battery or battery pack or try to reset camera? Just a suggestion.
Oct 02, 2013 | Canon PowerShot S100 Digital Camera
The lens is stuck open and when I turn the camera on it says lens error will shut down automaticlly restart camera
Try moving around the lens GENTLY. If does not help, call Canon, they will probably fix or replace it.
Aug 29, 2011 | Canon PowerShot SD1300 IS IXUS 105...
I have a canon camera IXUS 105 and the lense is stuck out and when i turn the camera on it says 'lens error, will shut down automaticly, restart camera' i have restarted it many times but the lenses wont...
A lens error can be caused by physical damage to the mechanism that controls the lens, or debris that is interfering with the operation of the lens.
This article may be able to help you with a "do it yourself" solution.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
In the event that your problem is due to physical damage and not just dirt or debris, you will need to take it to a local camera repair shop for troubleshooting-- though with most consumer digital cameras, labor and parts cost of a repair can easily exceed the value of the camera.
Mar 05, 2011 | Canon Cameras
Lens error, restart camera
i had the the same lens error restart camera problem for almost a month.  If you haven't already, try restarting the camera with the sd1000 in the view pictures setting.  This may allow the lens to retract into position. Next, with the lens extracted, try looking down on the camera from the top to see if the lens is angled downward in any way.  If it is, this means it is jammed into place on one side.  Simply use your fingers to slightly push the lens into proper position.  If you hear a pop, you should be in business! hope this helps!
Jan 22, 2009 | Canon PowerShot SD1000 Digital Camera
Lens Error!
Same problem. The lens is stuck in the zoom position. When the camera is turned on, the lens moves a just afraction like it want to fully open or close, then the camera beeps and prompts with the "Lens Error" Restart Camera. Solutions?
Dec 05, 2008 | Canon PowerShot A550 Digital Camera
Lens error,restart camera
My Camera: Canon PowerShot SD770 IS Digital Camera
Went to the beach yesterday, by the end of the night my camera gave me this error: "lens error, restart camera". The lens would no longer come out.
I figured sand got stuck within the lens, so I did the following:
1. Turn camera up-side-down (with lens facing down)
2. Gently tap the sides of the camera (to loosen particles in lens)
3. Turn camera on
4. The lens will eventually come out
5. Gently tap the sides of the lens
6. Turn camera off (continue tapping side of lens as it retracts)
I turned the camera on and off a couple of times to ensure I removed all sand particles from the camera.
Now the camera works...thank god.
Aug 31, 2008 | Canon PowerShot SD600 Digital Camera
Lens will not close
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Nov 11, 2007 | Canon PowerShot SD850 IS Digital Camera
Cameras Logo
81 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
