Question about Samsung HLP5085W 50" Rear Projection HDTV-Ready Television
Just installed lamp and tv not working can u help me
  • 10,594 Answers
Make sure lamp cover has been fixed back in place correctly, lamp cover is first thing that you removed from tv to replace lamp, it should be fixed properly after lamp replacement.
Are you sure replacement lamp is original from Samsung?
Thanks.
Posted on Sep 27, 2010
Replaced lamp, pic is dull and not sharp any more,
Did u unplug the tv about half hour before u change a new tv projection lamp,for the tv so the tv power storage left over to disapper and what ever statictic charges magnatic field left to completely gone or to lower it enough not to harm the new tv projection lamp u just starting to put it in wright?The new projection lamp when u handleling it did u have a pair disposable glove on to not causes human static charges and the oils from ur hand to tranfer to the new tv projection lamp itself to caused to it quality funtions?This is the same exact same brand and make to the tv old projection lamp u are replacing not a clone or a tv compatible tv projection lamp wright?U check all connections are correctly installation and tightly before u turn on the tv again wright?U do all these safety procedures,before and after u are replacing a tv projection lamp will help 90-95% it to work correctly,if the tv causes are just requiring replacing a new tv projection lamp only.
Oct 06, 2011 | Mitsubishi WD-62531 Projection Television
Replaced lamp in Sony 50WE655 DLTV. Now green light comes on only a few seconds, then red light flashes 3 times stops and repeats. I was told to reste lamp timer, but TV will not come on to get to...
Recheck the tv installation of the tv projection Lamp make sure the installation of the tv projection Lamp it is properly install and tightly and correctly connections of all wires?Yes,make sure the tv Lamp door close tightly and the latch switch closed in it proper prosition?Yes,turn the tv on,if the tv now make alot of clickings noises and the tv LED light flashes.Mean the tv Ballast board it is also dead too and must be replaced,this Ballast board only job are to ignite the tv projection only.
Aug 16, 2011 | Sony Grand WEGA KDF-50WE655 50" Rear...
AsI have a sony kds55a2020 tv, I recently replaced the lamp because the lamp light was on. after I replaced the lamp, the tv power blinks 4 times and never comes on. what else can it be?
hi,
Check is the lamp is properly installed or not. If the tv was at working condition before replacing the lamp then then the new lamp is not properly installed. Check one more time. If you can then just remove the new lamp and insert it again. Make sure that the lamp is properly attached. And then check.
ok
Jun 11, 2011 | Sony KDS-55A2020 55" Television
I bought a mitsubishi wd 52327 new several years ago. I've replaced the lamp once and it worked fine but now it needs to be replaced again. We bought a lamp off EBay w/housing. I installed it but the tv...
Hi Brent, Mitsubishi's have a problem with the power supply and the Light Engine which incorporates the Digital Module of which it has to be purchased as a complete assembly. I sincerely believe you should not put that kind of money into a dlp set. The cost of the light engine is in the area of $1100.00. Your last idea is the best one.
Mar 09, 2011 | Mitsubishi WD-52327 52" Rear Projection...
I have a Suamsung tv HL T5675S Blinking lights all over. How can I fix that?
Hello, lets try this solution.
All LED's blinking , indicate that lamp does not light. Check the lamp, is it broken ?, or not installed properly.
Check ballast lamp too , is it work or not ?. Its a simple way to check the ballast lamp. Unplug the lamp, than turn on the TV set. If you hear sound like high voltage from ballast, that mean OK. The problem just from the lamp.
Replace the lamp.
I hope that will help you.
Thanks.
Dec 31, 2010 | Samsung HL-T5675S Television
Installed new lamp ..tv turns on then shuts off standby light flashes for a few seconds then tv turns on then shuts off again
did you replace the all three lamp the red,green and blue lamp?if not what color of lamp did you replace?try to dis connect the lamp that you installed then power the tv again if it work there might be a problem on your compatibility of lamp u use..or you can replace the convergeance ic there are two big ic in there sometimes labelled STK replace them...hope this could help..good luck!!
May 21, 2010 | Sony Grand WEGA KF50XBR800 50" Rear...
Where is the lamp located on my 50v710 Hitachi TV
The lamp is located behind the lower removable speaker grill on the front of the TV. There will be a lamp door then the lamp is up inside the TV behind the lamp door. Make sure the lamp door is back in place before turning on the TV after replacing the lamp as the set will not work without it installed.
Mar 02, 2010 | Hitachi 50V710 50" Rear Projection...
Just replaced the lamp after 2 years. TV worked
Make sure that the lamp cage is seating well .. then make sure the door is closed properly. there is a door switch and if the door dont close right the switch may be telling the set the lamp is out.
Oct 23, 2009 | Mitsubishi WD-62531 Projection Television
Lamp failure indicator
I had the same issue when replacing my lamp for the first time. I replace just the bulb with the Phillips replacement bulb. After installing the power down issue started and it would take up to 7 attempts before the TV would stay on with a picture.
Since I never had this problem until i replaced the bulb i decided to send the new bulb back and replace it with a difference one. In my opinion replacement parts are never made to the same standard as original OEM parts. This TV is definitely very temperamental in regard to the bulbs.
When the second replacement bulb arrived I decided to not only replace the bulb I also cleaned the connector plug in the cartridge with a QTip and alcohol. I did the same for the plug receptor in the TV.
When I replaced the bulb i insured the the top of bulb lettering was facing the handle of the cartridge so when you put the cartridge back in the TV the top of the bulb would be facing you.
I also cleaned the entire inside of the TV where the cartridge is inserted including the screws.
Once I did all this the TV turned on the first time and has been working fine for three days now.
I do believe the replacement bulb position is very important as to how it heats up and determines when it needs to cool.
I hope this helps others with the same success i had because I really do not want to replace this TV and start replacing all the parts others have done with little to no success for this issue.
Jul 11, 2008 | Mitsubishi WD62527 62 in. LCD HDTV
Samsung HLP5085W 50" Rear Projection HDTV-Ready Television Logo
76 people viewed this question
Jerry Greenberg
Jerry Greenberg
