Question about Sony Cyber-shot DSC-T70 Digital Camera
When the camera is exposed to hot temperatures 100 plus the camera will not focus properly the image on the screen jumps and the lens or focus feature inside the camera vibrates you can feel the movement through the metal case. This does not seem to occur in cooler weather only after the camera is opened and closed several times in hot weather.
  • 10,594 Answers
There is steady shot mechanism located at end of lens assembly, that mechanism gone bad and vibrates, replacement of that mechanism will fix your camera issue.
Local camera repair shop will do this job as camera will take apart to replace defective part.
Thanks.
Posted on Sep 27, 2010
Why is my screen blurry and out of focus?
First-things first,
Check to make sure the lens is free of grit! When the lens becomes dirty, the image on your screen will be blusry and out of focus.
Aug 31, 2014 | Cameras
Lens error and out of focus images
HI there the camera lens guide pin is damages and thats why not focusing the image properly . that's why you got the lens error message. So you need to replaced or repair the lens guide pin. Thanks.
Apr 01, 2010 | Casio Exilim EXZ75 Digital Camera
I own a Canon 100 - 400 mm IS and mostlyl use it for bird photography. My problem is that the focusing of the lens is not very consistent. For example, when I was shooting a great egret somewhere between...
Which camera body do you own? It is the camera that determines where to focus and when you are in focus or not. I have 3 Canon film bodies and two digital. On all, the camera can be set to detect focus using all or a specific focus point visible in your viewfinder. Check how you have the camera set and choose ONE focus point. place this focus point on your most critical item in the image, in the case of your birds, the HEAD of the bird, press your shutter button half way to lock exposure and focus, then shift the aim to compose your image before pressing the rest of the way to make the exposure.
For birds, on my digital cameras, I choose to go into live preview mode, zoom in to 10x magnification and manually focus. This eliminates the camera not knowing what I want in focus.
try using a tripod to steady the shot, and do not forget that Canon states you should turn off the IS when the lens is used in conjunction with a tripod. From firsthand experience, I agree with this instruction, often when stable on a tripod, the IS can actually be trying to correct for its own movement and cause a degradation in image focus.
Good luck
Jan 02, 2010 | Canon EF 100-400mm f/4.5-5.6 IS USM Lens
My Fuji S5100 now fails to properly focus. I have
1 ensure that your camera is not set in Macro mode test by taking a picture of a subject very close up ie. 10 - 15 cm if the image is in focus then you may be set in macro mode.
2 if lens is removeable ensure it is fitted properly. remove the lens and refit ensureing the connectors are clean.
3 ensure the switch on the lens or camera is set to AF for auto focus.
4 suspect autofocus sensor is defective if you try to focus on subjects which are close and far away and you do not hear to camera re-setting the focus then it is in manual focus or the focus sensor may be defective or in need of adjustment.
5 recommend specialist have a look at this problem.
Nov 16, 2009 | Fuji FinePix S5100 Digital Camera
Blurres LCD image and blurred photos
1 suspect dirt on the lens ensue the lens is cleaned with proper cloth and fluid.
2 suspect auto focus sensor is defective or blocked ensure the little windows on the front are clear and fingers do not cover them while taking pictures.
3 suspect camera is set in macro setting, Macro only has a depth of field of a few centimeters any subject outside this field will be out of focus but his may not be visible on the small viewing screen on the camera but becomes apparent when images are viewed at larger sizes.
change camera setting to landscape or portrait setting.
Nov 13, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Can't get the moon in focus.
Full moon is very bright, so you are probably seriously over-exposing your image......not enough contrast in there for the camera to focus on.
Under expose in small increments until the camera can latch onto to the image accuratley.
Oct 04, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
Camara not focusing/ zoom not working
Its an error code and shows problem of Lens mechanism.
Lens focus / zoom motor is stuck that's why camera gives out of focus image.
You need to replace Lens Assembly and it would cost you more then camera worth.
Oct 26, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
How do I use the Minolta 2.8 100 mm lens ? Sothat I can choose the image ratio and focus on a 7D Minolta Dslr
well is it a analogue lens designed for 35mm film camera's of minolta ? Most of the time wenn using a non -cpu lens on a dslr body yuo have to lock the apature to the highest count (for example F 22 ) otherwhise thae camera will or might refuse to operate. if the lens is not to old you can try if the camera will outo focus if not you have to set the Autofocus to Manual Focus and lock on the target by turning the focus ring
Devlious greetingsz
May 31, 2008 | Cameras
Out of Focus
Hello. There are some possible reasons for this. First one could be that the lens assembly isn't focusing corectly because the lens aren't aligned properly. This is a common problem with digital cameras and is happening due to some shocks received by the camera. Sometimes it can happen without any obvious reason because of some small parts in the lens mechanism that get out of position and jams other components preventing them to move the lens properly. In your case, there could be a more minor defect because if the lens assembly fails the camera will display error messages or "turn off then back on" kind of messages. I've seen cameras that take blurry pictures because of temperature variations that happen quickly resulting in moisture or condensation over the lens. Altrought this probably isn't your case, be carefull with any camera, not to expose it to hight temperature variations (from cold to hot places especially). If your camera is still in warranty contact an authorised service to have the camera checked out. Problems can range from lens assembly damage, firmware corruption, processor to ccd sensor imperfect contacts and so on. They will run a special diagnostic mode on the camera and tell you for shure. Sorry for my bad english as I am from a non-english speaking country.
Mar 17, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Taking pictures
This could be due to a jammed lens element preventing the camera from focusing properly. When you push the button the camera attempts to focus the image before it takes the picture. If the focus component in the lens is not moving properly it cannot focus and thus will not take the picture. Do you see the camera attempt to focus the image when you press down the button? If it does not make any noises when you push the button, and the camera does not attempt to focus the image then it is most likely a jammed or malfunctioning focus motor. This would require professional repair.
Feb 19, 2007 | Canon PowerShot SD550 / IXUS 750 Digital...
Sony Cyber-shot DSC-T70 Digital Camera Logo
55 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
