Question about Whirlpool LER5636P Electric Dryer
Thermal cutout How do you know if the thermal cutout is bad??? I have one and there is no continuity between the two wire connector points. The dryer will spin and blow air, but it is not heating up.
  • 5,911 Answers
If there's no continuity, replace it. The Thermal Cut-Out should read a short if it is good. This could very well be the cause of your heating problem. Make sure you replace the hi-limit thermostat at the same time. Without doing so, one or the other often go bad again. Whirlpool sells the parts as a set and can be found at searpartsdirect.com. I hope this helps you. Let me know if you need further assistance.
PS Double check the heating element too. Disconnect the leads and take a resistance check at the terminals. If good, it will read between 9 and 13 ohms.
Posted on May 24, 2008
Electric dryer won't heat
Thermal overload cutout tripped or is defective and needs replaced. Look for a red reset button near the heater element on the thermal overload. If no reset button, replace the thermal overload cutout. The timer itself could be defective, which will prevent power going to the heater element.
Sep 14, 2015 | Roper Dryers
DV210AEW/XAA won't heat
More than likely the element is shorted or the thermal cutout on the element assm has failed you can test them for continuity if they don;t have continuity they are bad. 1st reset your house breaker, the dryer needs a full 220volts to turn the heater on, if that is good check the cord and make sure you haven't lost 220 there, then check the element and cutout.
Jan 17, 2014 | Samsung DV210AEW Sensor Dry Electric Dryer...
KYOCERA MK 1500 ERROR C-6 000
Contents: Broken fixing heater wire
• In fixing warm-up, the time to reach
50°C/122 °F exceeds 13.5 s, the time
to reach 100°C/212 °F exceeds 10 s,
the time to reach the primary stabilization
exceeds 10 s or the time to
reach the secondary stabilization exceeds
24 s.
Causes: Poor contact in the thermistor connector terminals.
Check procedures/corrective measures: Check the connection of connector CN4 on
the power supply board (KP-5059) and the
continuity across the connector terminals.
Repair or replace if necessary.
Causes: Thermistor installed incorrectly.
Check procedures/corrective measures: Check and reinstall if necessary.
Causes: Thermal cutout triggered.
Check procedures/corrective measures: Check for continuity. If none, replace the
thermal cutout.
Causes: Heater lamp installed incorrectly.
Causes: Broken heater lamp wire.
heater lamp.
Oct 10, 2010 | Kyocera Mita KM-1815 All-In-One Laser...
Kyocera km-1820 error occured call service person c6000
Contents: Broken fusing heater wire
• In fusing warm-up, the time to reach
50 °C/122 °F exceeds 13.5 s, the
time to reach 100 °C/212 °F exceeds
10 s, the time to reach the primary
stabilization exceeds 10 s or the time
to reach the secondary stabilization
exceeds 24 s.
the thermistor
incorrectly.
Thermal cutout
triggered.
incorrectly.
Broken heater
lamp wire.
Check procedures/corrective measures: Check the connection of connector YC4 on
the power supply PWB and the continuity
across the connector terminals. Repair or
thermal cutout.
heater lamp
Sep 13, 2010 | Kyocera FS-1118MFP Laser Printer
The screen is saying c-6 and won't let us clear it.
If you wait is the 6 followed by 0's after words if so its a C-6000 and is as follows.
• In fixing warm-up, the time to reach 50°C/122 °F exceeds 13.5 s, the time to reach 100°C/212 °F exceeds 10 s, the time to reach the primary stabilization exceeds 10 s or the time to
Broken thermistor wire.
Solutions:
Check the connection of connector CN4 on the power supply board (KP-5059) and the continuity across the connector terminals. Repair or replace if necessary.
Measure the resistance. If it is ∞ Ω, replace the thermistor.
Check for continuity. If none, replace the thermal cutout.
Check for continuity. If none, replace the heater lamp.
Something in the fixing assy has gone awry.
Hope this helps.
Aug 23, 2010 | Copystar CS-1500 Copier
Hi, I have a probLem! No doubt you hear that frequently!! First, you need to know I'm 60, and not a mechanical or electrical bone in my body. I found this site as I was looking for a heating element for...
The two red wires on the dryer probably connect to the short red/wht wire at the end with the extra connector. The other end of the red/wht wire would then connect to the blk/wht wire with small brass connector. This arrangement should place the thermal cutout in series with the high limit (ie, one after the other). Suggest you post pictures if this doesn't sound right.
Feb 27, 2010 | Whirlpool LER8648P Electric Dryer
Drum turns but does not heat the air. I replaced the ignitor, but no help there. Whirlpool gas dryer model 63003W0
If the ignitor glows but does not light the burner you need to replace the gas valve coils.
If there is no glow you must check all the thermostat safeties and thermal cutout fuses for continuity with a ohm meter. No continuity is a bad component. Remove at least one wire from each component before testing.
Unplug the dryer before any test.
Feb 17, 2010 | Whirlpool Dryers
Ther is no heat
This is most often caused by a bad thermal fuse or thermostat high limit cutout. Check them for continuity (with the machine unplugged, of course) They should have continuity -- replace them if open. They should be available at www.appliancepartspros.com Also, if one or both are bad, check the dryer vent as they often are damaged by high heat due to a restricted vent pipe.
Dec 31, 2009 | Amana DLE330RAW Electric Dryer
The dryer does not produce heat
This is most often caused by a bad thermal fuse or thermostat highlimit cutout. Check them for continuity (with the machine unplugged,of course) They should have continuity -- replace them if open. Theyshould be available at www.appliancepartspros.com Also, if one or bothare bad, check the dryer vent as they often are damaged by high heatdue to a restricted vent pipe.
Dec 31, 2009 | Kenmore 73952 Gas Dryer
I have a Frigidaire gallery series dryer.(GEOQ2152ESO). It will spin but will not heat. I suspect blown house fuses in dryer circuit. How do I access and replace fuses ?
the dryer circuit will be clearly labelled in the house box, there will be two fuses or a single two phase breaker for this circuit.
there are not usually electrical fuses as such IN a dryer, there are thermostats to regulate temperature, and a thermal fuse, that cuts the power totally to the heat element if air temperature rises above its melt point.
the element itself has a limited life span and may fuse/burnout.
to test electrical components.
Unplug dryer
open case, by removing the front,
described elsewhere in any of the 'changing belt' threads
locate the thermal cutouts, on the fan housing or exhaust duct and disconnect one wire to isolate it from the rest of the circuit, test with ohmmmeter, no-continuity replace, continuity reconnect wire
3aca526.jpg5d18df6.jpg thermal cuttouts look like these ~1inch accross.
locate the heat element and disconnect one wire to isolate it from the rest of the circuit, test with ohmmmeter, no-continuity replace, continuity reconnect wire
while you have the dryer open de-lint the fan and exhaust ducting, most common cause of element or themal fuse failure is air flow restriction
7713ef8.jpgce0732c.jpg you get a lot of lint out of the fan even when proper cleaning is done, and clean out the ducting right to the exterior walls
95b69b0.jpgthis was the rather extreme result of not cleaning the duct (brainiac placed a wire across the terminals of the burnt out thermal fuse)
Oct 23, 2008 | Frigidaire Dryers
Whirlpool LER5636P Electric Dryer Logo
87 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
