Question about FIC VC 11 Motherboard
I had just one memory module on this motherboard which was kingston ddr, 256mb, pc2100. Then i upgraded my mobo with one stick of pc3200 ddr ram, and it keeps restarting and sometimes it just turns off randomly. Help needed!
  • dolke022 Sep 28, 2010
    Yes, I'm very sorry... indeed i said it was PC2100 but as i looked again it was PC2700. Well, BIOS update I found on the net, but i didnt manage to flash it. I think that one I found is the latest BIOS update for that specific mobo.
    Check this link pls:http://ixbtlabs.com/articles2/roundupmob...
    So, basically that means that i can use PC2700 but i need to put some voltage values manually, right? Can you tell me what values i need to use?
    Ty in advance
    Problem Solver:
  • 15 Answers
PC 3200 is not supported by this motherboard. It will cause problems. You need to use PC2100 RAM.
http://www.motherboards.org/reviews/motherboards/988_2.html
Hope this helps.
Posted on Sep 27, 2010
  • 5 more comments
    Well that is strange because after i wanted to make ram upgrade on this system, it had one module of 256 mb, pc2700 installed. System was slow, but it was working, no restarts and shutdowns on it self...
    Also i found some newest BIOS update for this model of FIC mobo... in the change log i found that it fixes some ddr 333 comparability issues...
    I'm pretty much confused right now
    I wanted to say before i decided to make ram upgrade, sorry.
  • ITboykc Sep 28, 2010
    That's strange, because in your post you said it was PC2100. Also, incorrect voltage may cause instability. Check to make sure the speed/timings are correct in the bios as well. Where did you find the bios update?
    Yes, I'm very sorry i made a mistake. I checked again and module was PC2700, Kingston, 256mb.
    Indeed, it could be voltage but can you tell me what voltage values needs to be set? Basically, i can use PC2700 but I need to set voltage values in BIOS manually, right?
    I found BIOS update somewhere on the net, but at 1st i found details here:http://ixbtlabs.com/articles2/roundupmob...
    It is written something about latest version of BIOS for that mobo - BIOS SAB42...
    I just downloaded the file but didn't flash the mobo, as I haven't found proper tutorial for that and utility also.
    Ty in advance
    PC3200 is out of the question. PC2700 will work, I was wrong, according to your link specified. The bios update may help you, but has a chance of bricking the mainboard. It appears to have a phoenix bios. Use Winphlash to update it. In order to tell you the voltages, I will need the specific model information from the memory.
  • dolke022 Sep 29, 2010
    I'll go with the flashing first and then if that doesnt do the work I'll get you memory module informations so you can assist me setting the proper voltages. I'll get back to you asap.
  • dolke022 Oct 05, 2010
    Just want to update this issue I had.
    I didn't flash the BIOS, the risk was to great and its not my PC so I passed it.
    Instead, I bought one PC2100 512 mb module and I'll put it in the PC this evening.
    So, the one which is PC2700 should be fine too, because it will slow the clock to pair the PC2100.
    I'll post details after its done...
    Regards
I want to extend the RAM memory on my NEC computer. The motherboard is a GA-8SIMLNF Rev.1.1. It has two memory slots and presently one slot is occupied with a PC2100U-20330-A1 256 DDR 133 CL2 memory. I...
Check your manual (Gigabyte will have the manual on their website), to make sure your motherboard can handle 1Gb of Ram, or more. Generally in my experience, medium aged motherboards handle 1GB per slot, max (mine uses PC3200, not PC2100, and will take up to 4GB in its 4 slots).
You'll want PC2100 ram (easily searched for on http://www.newegg.com), either in 2x512MB sticks, or a single 1GB stick for your open slots (bringing you up to 1.25GB).
Mar 01, 2011 | Intel Motherboard
I wish to add RAM in the PC. Mine motherboard-Epox-EP-4BDA533(I). ID(identification)-05/09/2003-i845d-6A69VPA8C-00. On it costs RAM 256Mb -DDR PC2100 266Mg FSB-400Mg. How many Mb it is possible to add....
Manufacturer Specifications - EPoX EP-4BDA533I Number of Slots:
Slot 1
Slot 2
Each memory slot can hold DDR PC2700,DDR PC3200 with a maximum of 1GB per slot.*
*Not to exceed manufacturer supported memory.
  • 184-pin DIMM Banking: 2 (2 banks of 1)
  • Chipset: Intel 845D
  • Error Detection Support: ECC and non-ECC
  • Graphics Support: AGP 4X
  • Max Component Density: 512Mb
  • Max Unbuffered DDR SDRAM: 2048MB
  • Module Types Supported: Unbuffered only
  • Supported DRAM Types: DDR SDRAM only
  • USB Support: 1.x Compliant
Q: What memory goes into my computer, and will a faster speed be backward-compatible?
A: DDR memory with support for DDR PC2700,DDR PC3200 speeds.
Because DDR memory is backward-compatible, you can safely upgrade your system with any of the guaranteed-compatible DDR speeds listed below, even if your manual calls for PC1600 or PC2100 speeds.
Q: How much memory can my computer handle?
A: 2048MB.
Adding the maximum amount of memory will improve performance and help extend the useful life of your system as you run increasingly demanding software applications in the future.
Q: Do I have to install matching pairs?
A: No.
No, you can install modules one at a time, and you can mix different densities of modules in your computer. But if your computer supports dual-channel memory configurations, you should install in identical pairs (preferably in kits) for optimal performance.
Q: Does my computer support dual-channel memory?
A: No.
Your system does not support dual channel.
Q: Does my computer support ECC memory?
A: Yes.
Your system supports ECC. You can put non-ECC modules into an ECC system, but be sure not to mix ECC and non-ECC modules within a system. Install the same type of modules that are already in your system.
Jan 13, 2010 | ASUS Intel 845D Chipset P4B266 (P4B266-PA)...
I got intel 845 gl motherboard having ddr 256mb pc3200 ram. there are two slots availble. i want to upgrade
If you want to upgrade your ram, buy the same memory frequency like your current ddr 256 mb pc3200 memory. You can upgrade your memory up to 4GB and be sure they have all the same frequency to avoid system complications.
Dec 19, 2009 | Intel Motherboard
Install DDR-DIMM PC3200 to MS-6367 MSI
That motherboard was made for PC2100 DDR266. A PC3200 DIMM *SHOULD* be backward compatible. Depending on the density of the PC3200 memory you might have problems. If you have not bought the memory yet I would go with the PC2100 for sure since the PC3200 will give you no speed gains at all and will be running at PC2100 speeds anyway.
If you already have the PC3200 memory then I would say just give it a shot. The worse case scenario is your machine will not boot up with the higher speed ram installed. Assuming you take all the normal hardware upgrade care and do not physically break anything you can test this memory with no harm to your motherboard.
Aug 12, 2009 | MSI MS-6367 Motherboard
I can't recognize what specific RAM this motherboard accepts..
Dear sir,
In reply to your post- Generally now a days we use DDR400 RAM(DDR 1) for this type of motherboard.So DDR 400 RAM is More compatible then other RAM,you can use this RAM for your motherboard to obtain good performance.
good luck
chandrashekhar
Aug 04, 2009 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
PC2700 or PC3200 DDR memory in this mobo ?
MEMORY ecs_buttom_03.gif 2 x 184-pin DDR DIMM socket support up to 2 GB ecs_buttom_03.gif Support DDR400/333/266 DDR SDRAM
Copied above from ECS website so the answer would yes as it supports up to 3.2GB/s transfer rates at DDR400
May 14, 2009 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
What type and how much memory can i put in the MB MS 6577 Ver 4.1?
1GB Of PC2100/PC1600
According to:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=bph07843
Apr 24, 2009 | Computers & Internet
PC Motherboard Memory upgrade
From Asus tech: Memory 3 184-pin DIMM slots for PC1600/PC2100 DDR SDRAM
Supports up to 2GB memory
No ECC supportThis is only compatible RAM so make sure your new chip is PC1600 or PC2100. If you mis the 2 it the faster RAM will run at the slower chip speed. Hope this helps.
Feb 20, 2009 | ASUS P4B266 Motherboard
Choosing/upgrading DDR memory
hi there,
i dont see why u should not upgrade to 1gig RAM ... but u should stick to one memory speed ...and Size but if u can try to get the PC2700 - DDR400Mhz memory
Apr 14, 2008 | Syntax SV266A SKA KT266A Motherboard
Please help with memory upgrade problem
Roy,
This is a common problem with memory. Memory that matches what you have in your computer may not be compatible. The best way to find compatible memory for your computer is to visit websites of manufacturers who produce memory. Here are two sites where you can begin. You will need your computer brand and model in order to search for compatible memory.
www.kingston.com
or if not:
www.corsair.com
Apr 10, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
FIC VC 11 Motherboard Logo
146 people viewed this question
Top FIC Computers & Internet Experts
David
David
John Anderson
John Anderson
Are you a FIC Computer and Internet Expert? Answer questions, earn points and help others
