Question about Karcher 2500 PSI Pressure Washer
Karcher pressure washer k3.86 just keep running when you let go the trigger
InMrFixIt
  • 121 Answers
SOURCE: My 3.99 Karcher pressure cleaner
Hi! robcarroll
Did you purge the air from the pump before starting the motor.
InMrFixIt
Posted on Aug 28, 2008
  • 92 Answers
SOURCE: Electric Karcher pressure washer surging when turned on
Dear firenutt681,
One simple thing you can do, is to check for leaks. Check if hose at machine is leaking. Check gun if it is leaking. You can also check if water still comes out of lance nozzel. These leaks however so small, will cause the machine to surge.
Another reason is due to a faulty SPILL VALVE. This spill valve( often called CONTROL VALVE) will contract when the gun is closed. When it contracts under the enclosed pressure it will switch off the machine by means of a Micro Switch. Now if this Spill valve is faulty it will loose its compression under pressure and puts on the micro switch again. This can be seen once in a while or more frequent, as in your case. I sometimes do service Spill Valves, but mostly I replace them with a new one. I do not know the model number of your machine, but normally you have to open the cover and you should spot the spill valve on the head. Most probably you see a thick wire or a cap containing the micro swith. If you find the micro switch, you have found the spill valve. Sometimes it is a bit hard to pull out the spill valve. Myself, in various Karcher models I remove the spill valve by trying to feed water and put on a bit the machine. In this way the spill valve will be spitted out.
Another reason which makes your machine surge, is leakage from from the detergent inlet.
If you do not see no leakages at all....then for sure it is the SPILL VALVE.
If you cannot do this job yourself or you do not find spare parts...you can continue using the machine as it is...but before closing the gun...switch off the electricity. I only recommend this in an emergency. You do this so that you do not leave the machine surging. This surge will for sure damage the electric motor and the capacitor (assuming it is single phase).
Regards,
Fulltech.
Posted on May 30, 2009
  • 104 Answers
SOURCE: Karcher K 3.68M Electric Pressure Washer. Wand trigger Locks Up.
Sounds like the pressure valve is broken thats why you cant depress the trigger , the valve is on the pump , i would suggest taking it to a repair shop as they are fiddly things to fix
Posted on Jun 05, 2009
  • 92 Answers
SOURCE: karcher 550m has lost alot of its pressure,Why
Dear emmettbrickw,
Many of the models of Karcher machines, have a valve that under pressure...will compress and at the same time it will let water by-pass and circulating inside the head. As this valve compresses it also puts off a micro switch. This all happens when the gun is closed. This valve is called a SPILL VALVE or sometimes a CONTROL VALVE. Now for various reasons (example you store the machine with pressure in the system)....the seals of this Spill Valve get damaged. So you can have a problem in which the machine stays off....or a problem like yours...the machine continues running with gun closed. Your problem with gun closed...the spill Valve is not compressing and therefore not stoping the machine. At first when this happened it caused a fault also in your machine's valves. The gun was closed...pressure grew high...and this burst the intake valves for sure.
So my advice is that the spill valve must be renewed and also the intake valves. You must also check the Miro-Switch to see if it got stuck in the on position. If micro-switch is faulty, this also must be renewed. The Spill Valve is often located where you find a micro-switch holder with an electrical wire coming out. When you find this micro-switch...detach it from machine...then put on machine for a few minutes and press micro switch to see if machine stops. If machine stops...then at least Miro-Switch is OK. Always do these tests with electrical protective clothing, Shoes and Gloves!! Now if your machine does not have a micro-switch...then you have a spill valve which only by-passes water. This type of spill valve also needs checking and if need be renewed.
In a few simple words, the spill valve does all the work after one has opened or closed the gun. Sometimes by changing the spill valve only....the pressure will get back to normal. If not ...suction and delivery valves must be checked.
Regards,
Fulltech.
Posted on Jul 21, 2009
  • 1388 Answers
SOURCE: pressure washer does not spray consistent flow of pressure
Pressure washers have a pressure regulator/unloader that bypasses the water back into the intake when you let go of the trigger with motor running. If you let the machine run for long preiods in bypass the system could be damaged due to heating of the water being bypassed. The water is in a closed loop. The as the unloader wears it will tend to want to bypass which is what is happening in your case. Dirt trapped at the tip will cause this also. Install clean tip to solve problem. If clean tip did not help then try lowering the pressure by turning pressure regulator counterclock wise. If problem is gone then parts are failing but keep using pump. Good luck.
Posted on Jul 11, 2010
My Karcher 530M runs ok until I release the trigger, then it will not start again unless I switch and allow the water to run through for about 15 secs before switching on again
Hi Cliff:
My experience is that the pump pressures prevent the engine from starting, so we hold the trigger while starting.
My brother has cut a wedge of wood that he uses to jam the trigger open to bypass the problem. It can get a bit wild if the wand is not secured when the unit is started..
Aug 10, 2016 | Karcher Garden
My electric Karcher pressure washer does not shut off.
this can be that you need to bleed the system of air or that there is a problem with your trigger gun sticking when you release the trigger.
These are two things I would check before you go into the machine.
May 14, 2012 | Karcher Garden
I have a Honda XR2600 pressure washer. When the wand trigger is pulled, the throttle does not open, the RMD just drops. If i manually open the throttle, it works fine.
Your engine produces max horsepower at 3600 rpm. The engine throttle should be set to max before you pull trigger. Pressure washes generally do not have automatic throttle. You do not have to use max power, but enough power to keep the engine running when trigger is pulled. You washer will actually last longer if you only use about 75% of rated capacity. Good luck
Oct 15, 2011 | Karcher 2500 PSI Pressure Washer
Why dose my Karcher K2.35 keep blowing the gun hose off?
There is a good chance you are missing the black plastic clip that holds the hose into the trigger gun. If you look at where the hose goes into the gun there should be a flat slot where a black plastic clip would slide in and keep the hose into the trigger gun.
Oct 24, 2010 | Karcher 2500 PSI Pressure Washer
Pressure pump keeps pulsating when trigger not pressed
There is orobably a minor water leak on the output side of the pump. The pump is sensing a pressure drop due to the leak so it will run for short periods to maintain the pressure i the output line.
Aug 20, 2010 | Karcher PSI Electric Pressure Washer
Karcher pressure washer hunts ~ off/on ~ when running. How do I fix?
HI Your machine wil start and stop if you have any external leaks when the machine is running at not pressing the trigger. Please start the machine and not pull the trigger and look form leaks. A common one is around the high pressure hose outlet and also the trigger.
Jun 11, 2010 | Karcher 1750 psi Electric Pressure Washer
We have a Karcher G2500VH pressure washer. If you start the engine with the trigger pulled on the spray wand it will run at full pressure until you release the trigger. after that, when you pull the...
Hi, Karcher calls the unloader valve a spill valve,
this is a link to a full drawing/parts listing , and your fault description might well be a sticking /seized unloader(spill ) valve hope this helps
http://www.pressureparts.com/ManualViewPage.aspx?Manual=/mmDEV/PDF/karcherparts/g2500vh.pdf
the part number is on page 9 of the drawing
spill valve 45910400
hope this helps , we usually use some good quality silicone grease to lube the valve ,
Mar 07, 2010 | Karcher 2500 PSI Pressure Washer
Karcher pressure washer trigger problem
The wands that it will not run with would most likley have a little dirt in the tip of the nozzle. This would not allow the water to flow through in turn activating the pressure switch and shutting the machine down
Troy
Jul 05, 2009 | Karcher K2.26 Electric Power Washer
Jun 04, 2009 | Karcher PSI Electric Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
41 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
