Question about Kenmore 60721 Refrigerator
Kenmore Refrigerator 363.78965894 how do i access the pan under the unit?
5 Suggested Answers
peyton32034
  • 410 Answers
SOURCE: Water Leak around left front wheel
I would check the defrost drain inside the freezer. this is real easy to do on this model refrig.
  • remove bottom basket (if it isnt frozen in place) and the shelf above it.
  • in th back just below the coil cover in the freezer section there is a ledge that will most likely be frozen over remove this ice using a hair dryer or hot water which ever is conveinant for you
  • you should uncover a drain hole flush this drain with hot water I use a turkey baster or large syringe to forcefully push water thru to clear anything in the drain
  • put it back together and you should be good to go
when ever the unit goes into defrost (which is about twice a day) the water runs over the ledge and then out of the door by the hinge puddling up next to the wheel. this unit has a hard fiberglass drain pan that is built in and unless it has been dropped i cant imagine the drain pan being damaged.
Let me know if you have any other questions Peyton
Posted on Mar 08, 2009
peyton32034
  • 410 Answers
SOURCE: water in refrigerator, freezer is cold refrigerator is not
sounds like you have a frozen defrost drain. This is a fairly easy repair you can do yourself.
  • Unplug refrigerator
  • unload food from freezer
  • remove icemaker if present (there are 3 screws remove the one on the bottom and loosen the 2 on top of icemaker then lift it off the 2 screws unplug from wiring harness)
  • remove 2 screws holding rear cover in place
  • move cover to the side or remove from unit altogether
  • defrost any and all ice from bottom of freezer and aluminum drain pan that is now exposed
  • flush drain hole that you will see once ice is cleared with warm water. (sometimes I use a large syringe or turkey baster to forcefully flush hot water thru the drain tube)
  • reassemble in reverse order
that should fix you up. if you have any further questions leave me a comment here and I'll gladly help any way I can. thanks Peyton
Posted on Mar 12, 2009
aasc
  • 1606 Answers
SOURCE: drain pan over flowing
The rubber seal on the water filter is bad . Replace the filter in the bottom kick plate . When the filter goes bad , water will drip into the drain pan , causing it to overflow .
Posted on May 12, 2010
heatman101
  • 43501 Answers
SOURCE: my kenmore refrigerator no more cooler come out ,
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Sep 24, 2011
Where can I access the defrost drain hole in my Kenmore model 253.74879404 Refrigerator? Disassembling the freezer did not work.
I've used used a compressor for that drain hole at the back of the fridge. A hanger wire will work too. I've never tried it but maybe a can of compressed air might work also.
The water drain line is plugged and that little catch tray is overflowing. That's why you're ending up with water under your bins inside the fridge. The problem is not in the freezer or else you'd have a skating rink on the floor of the freezer.
I don't recognize the photos exactly but they're all the same principle. Take everything out of the fridge , including the racks. It's far easier than o find the screws and disassemble the drain "catchall".
Good luck.
Dec 18, 2014 | Kenmore Refrigerators
Kenmore side by side refrigerator 51262103 how to remove drain pan.
Usually, there is a removable grille at the bottom of the refrigerator which provides access to the drain pan. Removal can involve some twists and turns to get the pan clear.
Sep 20, 2014 | Kenmore 51262 / 51264 / 51269 Side by Side...
I HAVE A MAYTAG AUTOMATIC ELECTRONIC DEFROST CONTROL REFRGATOR MODEL MSD2272VEB00. EVERY FEW DAYS WATER LEAKED FROM UNDER THE REFRIGERATOR ONTO THE FLOOR FROM WHAT APPEARS TO BE AT THE FRONT RIGHT SIDE OF...
Inside of the unit is a drain hole that will drain out water to the drip pan. The drip pan is located under the unit and it uses the heat of the motor to evaporate the moisture that collects in it. The drain hole is plugged. Go on youtube and you can watch a video on how to fix it. Very easy.
Semper Fi,
Z
Apr 27, 2017 | Refrigerators
How do i remove a drip pan from a kenmore refrigerator
The drip pan collects water when the freezer goes into a defrost cycle. Most times there is very little water and the water evaporates quickly. When there is a problem with the freezer or the water does not evaporate between defrost cycles, the drip pan fills with water. If the front bottom of your refrigerator has a grille, you access the drip pan from the front. If there is no grille, access the drip pan from the rear.
Instructions
Rear Access
1 Unplug the refrigerator from the wall outlet. Pull the refrigerator away from the wall so that you can access the rear of the refrigerator.
2 Look under the refrigerator with a flashlight and locate the drip pan. Often when people install refrigerators they neglect to pull the packing from around the drip pan. The drip pan may have tape or styrofoam around it.
3 Remove any packing material away from the drip pan and pull the drip pan out from under the refrigerator.
Front Access
4 Pull the grille at the bottom of the refrigerator below the refrigerator door with your fingers. The grille secures to the refrigerator with plastic clips.
5 Remove any debris from the access area and throw the debris in the trash. The coils and fan under the refrigerator attract dust and dirt. Clean out the area with a lint brush if you have one.
6 Pull the drip pan out from under the refrigerator.
Apr 20, 2012 | Kenmore Refrigerators
Kenmore elite (795.75544401)is suddenly dripping water from the bottom of left french door.
Hello and Welcome to FixYa!
The dripping water could be from the evaporator coil unit.... Under normal conditions,Self-defrost refrigerators usually dispose the water generated during the defrost cycle through a tube or channel that directs the water a pan (Known as Drip pan), commonly below the refrigerator unit.... The channel or tube is clogged and the water is leaking to the refrigerator unit, so you need to clear that contamination....Once the blockage is removed, the generated water will move through that channel/tube directly to the drip pan and there will no water on the top shelf in the refrigerator compartment. Another cause may be the refrigerator may have doorframe heaters to evaporate any condensation on the cabinet frame. If your refrigerator is equipped with a switch inside that says “energy saver” or something like that, while running in that mode the door heaters are disabled. Turn the switch to the opposite setting and wait 24 hours. If the water disappears the problem is solved.
Best of Luck,
Please do Rate the solution, if you feel that this helps you,
Concerned.
Aug 18, 2010 | Kenmore 24.8 cu. ft. Trio French Door...
Our frig. Leaks a small amount of water from inside about every 3 days
Actually the leaking water is from the evaporator coil unit.... Under normal conditions,Self-defrost refrigerators usually dispose the water generated during the defrost cycle through a tube or channel that directs the water a pan (Known as Drip pan), commonly below the refrigerator unit....
The channel or tube is clogged and the water is leaking to the refrigerator unit, so you need to clear that contamination.... This is all you need to do....
Best of Luck,
Concerned.
Aug 10, 2010 | Kenmore 64802 Top Freezer Refrigerator
Water inside refrigerator
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Jun 15, 2010 | Kenmore 74522 Top Freezer Refrigerator
Need to remove the drip pan under my Kenmore side by side fridge.
Mine is a whirlpool side-by-side ED5GTN which must be the same design as your Kenmore.
There is no way the drip pan will come out without tilting the refrigerator backwards.
The tape is removed, the foam packing, the filter removed, the pan is not flexible enough because the pan broke.
I have worked on this until my hand is bleeding from struggling with this poor design. Custumer service was no help..said, "Well, I don't know."
I'll wait for help to tilt the thing because there is black mold and I want all removed from the bottom of the refrigerator. This design is not only "NOT customer friendly but unhealthy for your home."
Jun 22, 2009 | Kenmore 44273 Side by Side Refrigerator
New refrigerator
A refrigerator must get rid of condensate and "frost". There is a collection pan under the back of the unit where there is also a fan that helps removes the excess moisture back to the atmosphere.
Jan 05, 2008 | Kenmore 44273 Side by Side Refrigerator
2 year old kenmore elite water leaking in freezer area
Does this happen when unit is in a defrost?? If so, sounds like the drain line is clogged.The hose and pan are located under the unit.You can access this by removing the cardboard back cover.Find the drain line tube.I'm sure the drain opening at the evaporater is iced over.You will have to unplug the unit and keep the doors open to defrost.(Removing product in unit will decrease defrost time.) Maybe an hour to an hour and a half.Could be longer!! Try using a wet/dry vac to clear.
Nov 25, 2007 | Kenmore 53642 / 53644 Side by Side...
Kenmore 60721 Refrigerator Logo
48 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
