Question about NAD Audio Players & Recorders
My NAD 310 is "humming" throgh speakers even at low volume with no input. With CD on there is distortion which I initially thought was a blown speaker. It's coming through both channels on the amp - is it easy/worth fixing? Cheers Kev
    Genius:
  • 1,175 Answers
Hi...
If you can afford $75-150 , get it fixed . Most likely the power supply capacitors
Posted on Oct 05, 2010
PA speakers distort even at low volume
Firstly check if you R getting clipping at the input ,if U have it, then lower the vol of the music source andif their is no clipping at the source then U must have you speakers checked for it may have some voice coils burnt .with best wishes .system tech.
Apr 13, 2014 | Yamaha S215V Main / Stereo Speaker
Woofer sound distorted
What audio source you put into your Amp? you can lower the source volume also the amp volume to confirm, where the problem come.
Source input is also important whether you using low level or hi level input.
Nov 18, 2012 | Acoustic Research P315 HO Speaker
Nad 7140 fm low frequency hum
This is probably a 60 cycle hum and the problem is more likely confined to the am/fm board, there is a bad ground due to poor solder joints, broken ground wire, an open capacitor, this may not be easy to find, but it is a start.
Apr 22, 2012 | NAD 7140 Stereo Receiver With Phono Input
Bose L1 Speaker Distorting
See this article on the inputs on the Bose L1®.
L1 Model Bose L1 Encyclopedia FAQ Wiki
Set the trim levels so that lights are solid green with occasional flickers of red.
Mar 15, 2012 | Bose L1 Speaker
Re: Boston digital BA735. Hum with or without input signal.
Hmmm I just got the same problem. They worked fine on my old Dell desktop but when I plugged them in to my son's old Dell PC (maybe 1 year newer than my old one) they all hum like crazy - as you say even if it's just the power plugged in and nothing else. Yes it does have the original power supply. I get no music (but still it hums) from digital out/in but when I switch to analog out/in I hear the music and it still hums, plus the sound is distorted. Wierd.
Jul 14, 2010 | Boston Acoustics BA735 Computer Speakers
Eratic volume
Hi....
ONe of the leads on the CD cable has a broken ground (thats why it hums loud)
The speaker that has only the tweeter working: The woofer is blown in the speakers.
Check also for good solid wire connections at both ends of your speaker cables
Mar 29, 2009 | NAD C372 Amplifier
Sound through one channel only.....NAD 310 Amplifier
If swapping of left and right input sources and left and right speakers does not help...you might have a bad channel in your amp.
Sep 24, 2008 | NAD Audio Players & Recorders
Nad 310 amplifier VERY QUIET
take audio out from tv and insert it in aux in in your amp.
Jul 15, 2008 | NAD C320 2-Channel Amplifier
Gemsound power speaker pxa105
First,
Disconnect any input cables from the amp. Turn down the volume controls and disconnect the speakers. Power back on. If you still blow fuses with nothing hooked up, have the amp fixed.
If the fuse holds, shut down and connect the speakers, leaving the volume controls down. Power up and see if your fuse holds. If you have hum, an output transistor is most likely shorted. If you have no noise, SLOWLY turn up the volume controls and listen for the hum. If all is quiet, turn down the volume controls and connect your input cables and turn the volume back up. Noise? check your cables!
Mister Phil
Apr 07, 2008 | NAD C350 2-Channel Amplifier
Yamaha RX-V861 Low frequency "flutter" after turning on
How close to your video monitor is this rxr? It is not shielded well as far as sync circuits in your TV are concerned. Refer to manual...accordianman
Apr 03, 2008 | Yamaha RX-V661 Receiver
293 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Larry Stiles
Larry Stiles
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
