Question about HP Wireless Optical Mouse
Need help with my mouse - do I need a receiver ?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,001 Answers
  • Excellent Bluetooth Receiver,stable connectivity and remarkable signal stability.
  • Smooth call conversation and non-stop and clear music streaming creates enjoyable listening experience.
Amazon com Charm sonic Wireless Portable Bluetooth 4 1 Receiver Wireless...
Posted on Jan 06, 2017
    Scholar:
  • 104 Answers
Unless your mouse uses Bluetooth (should be printed on the packaging or at least have a Bluetooth logo on the mouse itself) you need a receiver that plugs into either your computers PS/2 or USB port. If you do not have the receiver it is usually cheaper just to buy a new wireless optical mouse.
Posted on Sep 27, 2010
Connect my leeds 1690 wireless mouse to my laptop
hi Shon.
Connecting a Mouse with a Wireless Receiver.
Plug in your mouse's receiver. The receiver should fit into one of your computer's USB ports. You can typically find USB ports, which are thin, rectangular slots, on the sides of laptops and on the front of desktops' CPU boxes.
  • Plugging in the receiver before turning on the mouse will allow your computer to install any drivers or software needed to use the mouse.
Make sure that your mouse has batteries. To do so, you'll typically flip the mouse over and remove a tray on the bottom, though some mice instead have their batteries in a compartment in the back of the mouse.
  • If you haven't used the mouse in several months, consider replacing the batteries even if they were new when you inserted them.
  • Some mice, such as the Apple Magic Mouse 2, require charging instead of new batteries.
  • 3
    Turn on your mouse. This typically involves manipulating a button on the bottom of the mouse, though you may need to look for the On/Off switch on the side of the mouse.
    • If you can't find the On/Off button, consult your mouse's manual.
    Press your mouse's "Connect" button. This button's location will vary based on your mouse's developer, but you'll usually be able to find this button either between the two mouse buttons or on the mouse's side.
    • Some mice come listed as "plug and play", meaning that you don't need to manually connect them or download any software.
    5
    Move your mouse around. Once you see the cursor begin to move on-screen, your mouse is connected.
    • If your mouse doesn't start moving, try turning it off and then back on. If applicable, you may also want to change the USB port into which the receiver is plugged.
    this link will help you out some more if you need it.
How to Connect Wireless Mouse
Dec 08, 2017 | Leeds Computers & Internet
Cant find nano mouse receiver can i still use mouse without it
You will have to purchase a new receiver. There is no software solution for a lost mouse receiver I am afraid
Sep 11, 2014 | Gear Head Mp2325blk 2.4ghz Wireless...
Have a dynex wireless mouse. moved my desktop and now cant get mouse to work need help
You may just need to reconnect the mouse and receiver. To do that, make sure the mouse is turned on, then press the Connect button on the receiver, wait a second, and press the Connect button on the mouse.
Feb 17, 2011 | Dynex Wireless Optical Mouse
Mouse did not connect to receiver
Hello there, I am the Expert that will be helping you today. My name is damnor01.
Welcome to Fixya.
The mouse uses two AA 1.5Volt batteries, ensure that they are installed in the correct orientation. Positive and negative polarity, on each. New strong batteries are required for this application.
A red light shoud elumanate from the bottom of the mouse when batteries are installed.
Now connect the USB cable from the receiver to the USB port on your computer, you may need to try different ones.
Once this stage has been completed you can install the drivers for your Microsoft mouse, they can be found on the CD disk that came with your Mouse.
The drivers may need to be installed using a wired mouse.
Beneath the mouse there is a button, press it.
On the receiver there is a button press it.
The receiver will now find the mouse and connect.
Thanking you kindly
damnor01
Feb 11, 2011 | Microsoft Standard Wireless Optical Mouse
I have an hp wireless mouse, and it doesn´t work!! Tried everything...
Wireless device like the mouse needs a wireless connectivity to a computer like a bluetooth or a wireless receiver. Make sure that your mouse batteries are all working and the wireless receiver is properly plug into the USB(Universal Serial Bus) port of the computer. The wireless receiver don't need battery so you don't have to worry about it. The two both have a push button, press both buttons to activate the connection. Wireless connections has limit in distance so make sure that you are not too far away from the receiver while using the mouse and that is 9 feet or 2.7 meters so keep that in mind. When the cursor moves when you move the mouse, you have connected the mouse properly. If the cursor doesn't move, try repositioning the receiver. If it still doesn't work, you may need to restart your computer (if you haven't already) or reconnect everything.
Hope this could help you a lot..:-) Thanks..
Dec 27, 2009 | HP Wireless Optical Mouse
Hi, I have the wireless mouse 3000 and I just changed my batteries but on the receiver I can't get the green light to work. I tried pushing the button on the receiver but nothing. Any idea? The mouse has...
Try putting the receiver in another USB port on your computer. If it still doesn't light, push the button on the receiver and the reset button underneath the wireless mouse (you might need a pen/pin to do this) for approximately 10 seconds at the same time. The receiver and the mouse should now be synchronized.You should be able to use your mouse and and receiver should be giving a steady green light. If not, you will have to consider that the wireless mouse receiver is busted.
Nov 27, 2009 | Microsoft Wireless Notebook Optical Mouse...
Receiver will not light up so the mouse nor the receiver works? help
The reciever for this mouse does not have a light, however, your USB might be a dud (on your computer) so try another port. Also replace the batteries inside your mouse with new ones. This should fix the problem. Then reconnect them with the button on the reciever. Also make sure to hit the power button on the bottom of the mouse. If this does not work, then your mouse if fried and you need a new one.
Oct 02, 2009 | Logitech LX5 Cordless Optical Mouse -...
Keyboard not working but mous is working
Sounds like the keybaord, mouse, and receiver are out of sync. Under the keyboard is the Connect button. Press it, then press the Connect button under the receiver that's connected to your computer. You may want to do the same with the mouse as well, just so all three components are properly sync'd at the same time.
If that doesn't do it, try reversing the order (receiver Connect, then the keyboard Connect button).
Aug 25, 2009 | Logitech Cordless MX 3200 Laser Mouse
How do I open the receiver for my wireless mouse to replace batte
The receiver is plugged into a USB port and doesn't use batteries. The keyboard and mouse use batteries and they need to be replaced ever so ofter. to do so, follow thes instructions.
Normal 0 Are your batteries in the Keyboard and mouse good?
Press the Receiver button (and the lights will start flashing, then if its the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect.
If the MOUSE isn't working, do the same except push the small RESET?CONNECT button on the back of the mouse to connect. Then they should work properly. Hope this helps. Bud
Nov 29, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Mouse doesn't work
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Nov 03, 2007 | Micro Innovations KB985W Keyboard
HP Wireless Optical Mouse Logo
99 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
