Question about Dell V305w All-In-One R840635AU InkJet Printer
I am trying to get my dell v305w printer to scan and it keeps telling me downloading application list and then it says after 2 mins unable to download apps
  • 823 Answers
The printer is trying to connect to your pc to download a list of programs to send the scanned document and/or picture to when you use your scanner.
The printer will only scan to certain software and there are separate choices for handling pictures and text documents.
When it tries to communicate with your pc to find software that it can scan to, its not finding any installed that will work with your printer. Its telling you that it is unable to get the list of applications after attempting to connect with your pc.
So, what does that mean?
It means that either "bi directional support" is not enabled in your printing preference so your printer is limited to sending info one way oly (to the computer). If this is the case you can go to your control panel and then choose printers and check the preferences listed there.
OR
You don't have applications installed in your pc that your printer can send scanned documents to.
If this is the case then you need to install software that your printer will work with and then set the options on your printer to pick the default you want to use with both pictures and text documents.
Printers usually accept microsoft word, word pad, microsoft works and any other word processing software to scan text documents to.
Printers usually accept just about any picture editing software installed on your pc to send scanned pictures to.
You can avoid all of the above by checking to make sure that your printers software is 100% installed including the scanning features. Go to the Dell website and update the drivers on your printer to make sure you have the full version that is most current.
The printer will always use its own program to scan both documents and text to regardless of the other software applications you might have installed on your pc.
Posted on Sep 27, 2010
Im trying to scan a document so i can edit it.... but printer goes as far as" and then " unable to download application lists" downloading application lists " is message on printer and...
Try reading...
Update list of applications to send scans to
Make sure the printer is allowed past the firewall.
When scanning a document, the OCR Program needs to be installed.
Also try these tweaks.
Start, control panel, device manager.
Go to the USB Controller section and click the + sign.
Go to each USB Root Hub and right click on it, left click properties, left click power management. Uncheck the box, allow computer to turn off this device to save power.
Restart your computer.
Start, control panel, device manager. Click on Network and then right click on your wireless adapter, left click properties, power management. Uncheck the box, allow computer to turn off this device to save power.
Need more help, try posting at...
Dell Printers Forum
Rick
Jul 27, 2011 | Dell V305w All-In-One R840635AU InkJet...
Will not scan.printer says downloading application list.dont know if there is a problem with my computer or wireless network. have no idea what to try.any suggesions?
This is normal function and nothing to worry about.
There are two ways to initiate a scan using your machine.
You can use the keypad on the printer to tell it to scan and this makes the printer send the scan to the computer. Using this method lets the printer control the scan command.
To scan using the keypad - press the scan button on the printer. This will bring up the "downloading application list" on the printers display. What the printer is doing is looking for a list of installed programs/software on your pc that it is familiar with and can scan your document to. Your printer can use software like ,Adobe Acrobat, Microsoft Word or internet explorer ect. When it confirms a list of installed software available on your pc it will display them and wait for you to confirm where you want your scan to go. Word will only accept documents. I suggest scanning to a photo program for pictures. If your printer does not find any comptatible software that it can scan to on your pc then the downloading list notice will time out and it will display a scan error or just turn off and power down.
I suggest using the second method below to scan instead.
OR
You can use the software after its installed in your pc and go into the computer to tell it to scan using the printer and store the image in your pc instead. Using this method lets the computer control the scan command.
to use this method, you need to have the dell software for your printer model installed and click on it on your desktop. then just follow the prompts to find the scan command. If you dont have the software, its available on Dell's website. Go to customer support and find download software and drivers and enter your printer made and model number. Then follow the prompts to install the software on your pc and start your scan once more using the instructions above.
Hope this helps?
Mar 03, 2011 | Dell V305w All-In-One R840635AU InkJet...
I'M TRYING TO INSTALL MY NEW DELL V305W PRINTER ON MY NETWORK USING THE INSTALL WIZARD BUT WHEN I GET TO THE BIT ABOUT TYPING IN MY WPA NETWORK KEY IT KEEPS TELLING ME THAT THIS KEY MUST BE BETWEEN 8...
http://download.cnet.com/WirelessKeyView/3000-2092_4-10614187.html Download and run, and enjoy your internet! Just make sure you're in range of the router in question. You see, the same thing happened with my WEP key; the last digit changed from a 1 to a 2; no idea how or why it happened.
Jan 20, 2011 | Dell V305w All-In-One R840635AU InkJet...
When I try to scan on the v305w it says downloading application list - but will not - therefore will not scan
Your problem, like many Dell printers is a simple one. You never installed the OCR Reader Application from the CD, that came with the printer.
You must use windows explorer to view the CD, you will see a folder that says OCR
Run that app, then you will be able to scan
Sep 30, 2009 | Dell V305w All-In-One R840635AU InkJet...
The Printer cannot communicate with the computer.
you need to reinstall the printer driver follow this steps.
Don’t connect the printer usb cable first
1st you install the driver disc which is come along with the printer and when the software prompt you to connect the cable then plug the usb cable and follow the instruction.
Sep 18, 2009 | Dell V305w All-In-One R840635AU InkJet...
DELL V305 ""DOWNLOADING APPLICATION LIST FOR EVER!!!!!!!!
if you cd that came with it unistall and reinstall ,,if dont work go to dell web site and download the printer files you need
Aug 11, 2009 | Dell V305w All-In-One R840635AU InkJet...
I want to scan pictures to my computer from my dell v305 scanner
Put the printer cd back in the drive and install again. One of the choices is to install "Additional Software." Select that option. If you click the OCR option it will load everything you need. It needs to load the Dell Imaging Toolbox for your printer and computer to work together. I'm at a loss as to why this wasn't loaded automatically when the printer was installed. I missed it also the first time around. Good luck. dan
Mar 29, 2009 | Dell V305w All-In-One R840635AU InkJet...
Printer/scanner won't scan
Install the printer again and select the "load additional software" option. Select the OCR software and it will load the Dell Imaging Toolbox. That should do it. The toolbox is really cool. It will allow you to save in various formats. Good luck...dan
Mar 25, 2009 | Dell V305w All-In-One R840635AU InkJet...
OCR application error with the Dell ALL in ONE
OCR is a software provided by Dell to convert a scanned document to editable text(word) document. If you scan without OCR software, printer will scan it as a Picture and you can not edit it.
Now here is your answer.
When you install Printer CD, it also install OCR software (Abbyy Fine reader) along with it.
You might have uninstalled the printer drivers and reinstalled them by downloading it from Dell support site.
I must tell you that Downloaded drivers from Dell site DOES NOT contain OCR software.
Solution:
1. You can download free trial version(15 days) from Abbyy.com
Click here to download
2. If any of your friend or relative have printer listed below then you can use the same CD to install the OCR software.
List: Dell 924, Dell 926, Dell 928, Dell 944, Dell 946, Dell 948, Dell 964, Dell 966, Dell 968.
location on Disc:
D:\OCR\setup.exe
3. You can scan using MS Paint.
Click on Start > All Programms > Acccessories > Paint
Click on "File" on Top left corner.
Click on "From scanners and cameras"
Click on "Scan"
It should be able to scan.
4. If you want to use Dell All In One Center.
You can disable OCR option for scanning and it will scan as an image.
Open Dell All in one center.
Click on Advanced scan options Under scan,
Uncheck "Use OCR software".
Click OK and try to scan again using Dell All In One center or using the printer operator panel.
Please revert for any further assistance.
Nov 05, 2008 | Dell 924 All-in-One InkJet Printer
Dell V305w All-In-One R840635AU InkJet Printer Logo
334 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
