Question about Nokia E63 Cell Phone
Lower keypad 7 8 9 keys not responding - Nokia E63 Cell Phone
Is there a way to lock keyboard while entering data
The Hidden Numeric Keypad on Your Laptop - For Dummies
www.dummies.com/.../the-hidden-numeric-keypad-on-your-laptop.html
The key to finding a laptop's numeric keypad is to use the Num Lock key. ... It's great for entering numbers or working a spreadsheet, but rather frustrating at other ...
windows 7 - Touchpad does not respond when I am holding ...
superuser.com/.../touchpad-does-not-respond-when-i-am-holding-key-o...
Mar 11, 2012 - Is there any way I could check what is wrong with my laptop? ... holding Space works fine for a normal click for entering the number in non-pencil mode. ... The mouse may work while pressing these keys. .... tour help blog chat data legal privacy policy work here advertising info mobile contact us feedback ...
Oct 27, 2015 | Computers & Internet
The smart wash light on my kenmore elite model 66513753K602 is flashing. I have tried the suggested button sequences to reset it and they have not worked. How do I troubleshoot it to determine which...
From the tech sheet:
CHECKING KEYPAD
OPERATION
A rapidly blinking LED over
one of the keys of the keypad
(or sometimes a "dead"
keypad/console) indicates one
or more key switch lines are
stuck or shorted on either the
control or the keypad. To
determine if the control or
keypad is faulty, do the
following test:
1. Unplug dishwasher or disconnect
power.
2. Open the dishwasher door.
3. Open console and disconnect the
keypad ribbon connection from
the control (at P1). Make sure all
other connections are made.
4. Put console back together. Do not
close the dishwasher door.
5. Plug in dishwasher or reconnect
power.
6. Wait 5 seconds.
7. Close dishwasher door.
8. Monitor the control's response:
? If the control is OK (no longer
sees shorts with the keypad
unplugged), it will respond by
turning on a Drain Motor for
2 minutes. Check and/or
replace the keypad if the
control responds OK.
? If the control is not OK (still
unplugged), then the drain
motor will NOT respond and
will remain off. If no response,
replace the control.
Jan 21, 2015 | Kenmore Dishwashers
Whirlpool quiet partners II normal light flashing
CHECKING KEYPAD OPERATION
A rapidly blinking LED over one of the keys of the keypad (or sometimes a "dead" keypad/console)
To determine if the control or keypad is faulty, do the following test:
1. Unplug dishwasher or disconnect power.
3. Open console and disconnect the keypad ribbon connection from the control (at P1).
Make sure all other connections are made.
4. Put console back together. Do not close the dishwasher door.
5. Plug in dishwasher or reconnect power.
6. Wait 5 seconds.
If the control is OK (no longer sees shorts with the keypad unplugged),
it will respond by turning on a Drain Motor for 2 minutes.
Check and/or replace the keypad if the control responds OK.
If the control is not OK (still sees shorts with the keypad unplugged),
then the drain motor will NOT respond and will remain off.
If no response, replace the control.
Dec 18, 2013 | KitchenAid 24 in. KUDI02IR Built-in...
Some keys on the keypad of my treadmill do not respond when pressed, namely the Enter, and numbers 1, 2, 3, 4, 5, 0. Thank you!
adjust the REED switch, test it, clean it, and tight the plug or connector very well.see the diagram
2) Ribbon cable tight for keypad, and tight the upper plug vs lower plug
3)replace the new batteries, same mark, same type, and same polarity.
See block diagram
God bless you
Nov 16, 2012 | Exercise & Fitness
When i type the letters on my keyboard, the numbers show up instead. i don't know how to revert the system or functions back to normal. i must've accidentally pressed a button to change the characters when...
Sounds like the keyboard is in NUM LOCK mode
They keys map like this:
7 8 9 = 7 8 9
u i o = 4 5 6
j k l = 1 2 3
0 . = m .
Look for the NUM LOCK key on your keyboard.
Typically, you press the FN key (lower left corner) and the NUM LOCK key (typically towards the upper right) together to put the keyboard back into regular mode.
Apr 21, 2011 | Twinhead DURABOOK N15RB Notebook
Keys are not responding
Hello, what makes a phones keypad not to respond is when the IC that controls the keypad inside the phone is bad, it makes the keypad to freeze.
Also if there is dirt in the keypad, it can also cause the phone keypad to freeze.
To rectify problem you will assistance from a phone technician.
Jul 03, 2010 | Nokia 6120
Switches to "Quick Start" before I enter all information
The Maintenance Mode allows you to query and modify the basic settings of the Star Trac Pro
Stepper.
Engaging Maintenance Mode
Press and hold the0 , 2and OK keys together.
A beep will sound and the “MAINTENANCE MODE” will display momentarily in the information
window.
Release all keys. “SERIAL NO XXXXX” will display in the information window.
Modifying the Maintenance Mode
The following keys are used to modify Maintenance Settings:
Upper and Lower Data Information Window SCROLL keys: Display the next and
previous settings.
Increase and Decrease Level Keys: Adjust the value of the displayed
setting up and down respectively, in increments of 1 unit.
OK Key: Updates (saves) the value of the display setting in the Flash memory, and exits
Maintenance Mode.
The Keypad Test can be used to verify that all keys are functioning on the display assembly.
To engage the Keypad Test
Enter the Maintenance Mode (see Settings – Maintenance Mode).
Press until Keypad Test is displayed in the information window.
Press to enter the Keypad Test.
Press each key on the display. Each time you press a key, the information window will display
which key has been pressed.
To exit the keypad test, press .
If any of the keys do not respond, they may not be functioning and the display keypad must be
replaced.
Jan 23, 2010 | Startrac Fitness Products Sc4130 Star Trac...
Keypad not working
In lower part on the other side of PCB with player`s keys You can find 25-pin glass IC. Change it. It`s an usual EMI-filter the same as on the Main PCB z2400.
Jan 20, 2009 | Nokia 3250 Cellular Phone
Keypad Problem
Format your mobile! check the keypad!
Jun 30, 2008 | Nokia N70 Cellular Phone
Nokia E63 Cell Phone Logo
136 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
