Question about Acer Computers & Internet
The plug in for the charger is not working - it seems to be pushed in so the charge cord keeps falling out. The netbook is still under warranty it is not even an year old - is this kind of repair covered?
    Guru:
  • 571 Answers
Thank you for asking fixya..
Call 1-800-571-2237 for technical specifications and warranty information.. I am not sure about the coverage of the warranty of your computer. I have checked their website and it's not showing their because I don't have the access to your account their. Give them a call for that matter. There's really a need for you to call them because you need a replacement of the part. or you can check out their website. Click here: ACER WEBSITE...
I hope this helps. Thank you for using fixya.
Please don't forget to leave your comments on how I can improve my way of giving my service and please do rate this post.
CARLO
Posted on Sep 27, 2010
I have a 1 month old samsung n148 netbook. I rarely use it with the battery, mostly connected to the cord. However, after some time, i charge the battery. when i try to open it with just the battery power,...
Your Netbook is still under warranty and I will not advice that you experriment or tamper to loose the free warranty claim on the PC. So what could be done is to discharge fully the battery and then try to charge fully , if this wont charge then the battery is a suspect and you must claim for replacement as it could have developed back EMF and so will not charge.
Sep 19, 2011 | Computers & Internet
My charger is plugged in to my MSI U130 netbook and in to the wall but is not charging at all. It isn't coming up with the little image to show the charger is plugged in, I have tried plugging the charger...
Charger may be good but the plug going into laptop may not have the power because the wiring is damaged,,Happens with all of the handling it gets for charging and adapter use.
Aug 26, 2017 | Computers & Internet
My gateway netbook wont charge, they sent me a new battery but again it will not charge, what could be wrong?
The problem might be either from the charger or from the laptop.
To confirm and repair if it is the charger, all you have to do is to plug the charger on another laptop to see if it will charge, if it does not charge, then you know the fault is from the charger, and the solution is for you to replace it with a new one, before you replace it, try to connect another power cord to the charger, because sometimes the power cord might have been burnt, that have happened to me twice and replacing the power cord solved the problem. But if replacing the power cord does not help, then you need to change the power cord.
To confirm and repair if it is the laptop, plug in a new charger to the laptop, if it does not charge, then you need to understand that the charging port of the laptop is faulty and needs to be replaced, have a repairman replace the charging port for you.
Take care and good luck
Oct 31, 2010 | Gateway LT2021u Netbook
I bought my daughter and son each a 7'' mini netbook laptop for christmas my daughter went to charge hers and the charger started smoking. we thought it was just a bad charger but we tried to charge hers...
1. it seems there is some manufacturing defect in the electric wiring of that laptop. take it back to the dealer and replace it (it's still in warranty)!
2. you should check the electric port where u plugged ur charger using any other equipment, like mobile charger!
Dec 31, 2009 | Computers & Internet
My battery on my MSI wind u100 is not keeping a charge. This problem has started recently. I had the netbook for about nine months. The "cord" symbol on the toolbar shows, and the battery will say "89%",...
If it is under warranty, return the battery pack. If not, you can try to discharge the pack as much as you can, and then recharge it. Most packs are made up of several smaller batteries. When you don't discharge the battery pack all the way, some batteries have more charge than others, and will stop the charger when THEY get full, leaving the others 'starved'. Finally the others only have the 10 minutes charge you are seeing. You will likely not be able to get the 'better' batteries discharged enough, and will have to buy a new battery pack.
tom
Dec 22, 2009 | MSI Wind U100-016US Laptop
I have a garmin nuvi and the cable that you put into your cigarette lighter will not work. I changed the fuse and it still will not keep the unit charged. I can charge it on my computer with a usb cable....
Do you see a lightning bolt symbol over the battery bar graph? This indicates that its charging. If it's under warranty, please contact Garmin on their website. www.garmin.com and call them. No need to worry about this if its under warranty. Send them your charger too.
- Jim
Dec 12, 2008 | GPS
Acer 5050 screen blink...AC problem???
Very likely a problem with the connection between the power pack and the laptop itself. This is usually the weakest point, and often you need to wiggle the connection a little to get a good connection.
It is usually just a solder joint that breaks, but it is a lot of work to get fixed on most laptops so get it replaced under warranty.
Jan 13, 2008 | Acer Aspire 5050-3242 Notebook
Computers & Internet Logo
16 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
