Question about DeLonghi Pinguino PAC-210 Air Conditioner
I have a Pinguino AC inside room unit 10,000 BTU. I had it unplugged for several months. When I tried to plug it in it wouldn't turn on so pressed both TEST and RESET buttons on the plug at the same time, heard a big "CLINK" and the unit refused to not only turn on, but the light indicator on the top of the unit went dead. How can this be fixed? Please reply ONLY if you're familiar with Pinguino AC--these units are not like others. They're very fussy and have only ONE WAY they can be fixed. Thanks.
  • 3 more comments
  • venire23 Sep 27, 2010
    Thanks. Where can I get a (1) manufacturer spare or (2) GFCI plug and who usually replaces these things? How much (est.) will it cost? FYI Pinguino customer svc is totally useless. They always give a runaround saying that they have to "order the parts from Italy and it takes a couple of months" to get them.
    Mr./Ms. krbjmpr: Would YOU fix my air conditioner? I'm in San Diego.
    Linda
    I need to replace the GFCI cord/plug on my De Longhi Pinguino Air Conditioner. The other expert wrote this:
    The portion of the plug that you refer to is known as a GFCI protector. It is designed to interrupt the flow of electrical current to the device if there is an imbalance of current flow in the hot and neutral conductors.
    When you pressed the TEST and RESET buttons together, you essentially shorted out the sampling resistor, and blew the trip relay. Replace the plug / cord with a manufacturer spare.
    For temporary use, as in testing only, you can remove the GFCI plug and replace it with a regular and appropriately wired plug. This will restore power to the unit, and allow you to continue to troubleshoot without being impeded by the GFCI affecting the outcome.
    DO ANY FIXYA EXPERTS MAKE HOUSE CALLS TO FIX APPLIANCES? I LIVE IN SAN DIEGO CA. PLEASE REPLY TO VENIRE23@GMAIL.COM. Thanks!
    OK. So, all I need is to have an electrician replace the GFCI plug using the same cord? The unit weighs over 100 lbs. Would it be possible for him to change the plug at my home?
  • 2,019 Answers
If you do not have the manual, I suggest you download it.
http://www.retrevo.com/support/Delonghi-PAC-210-Air-Conditioners-manual/id/12861ci469/t/2/
Since the unit is supposed to be turned off before unplugging or plugging in, it should not be surprising that it did not turn on just by plugging it in. You should have just set the temperature and/or timer selection, and then turned it on.
You should NOT have pressed both the TEST and RESET buttons at the same time, under any circumstances.
Laws require electrical devices that have water associated with it, to have a built in ground fault protection, and that is what the test and reset is for. The test button causes a short that should throw the protection, and then the reset is required to turn it back on. Pressing both at the same time would initiate a rapid succession of shorts, that could generate a great deal of heat.
Not a good ideal.
But you should unplug it, empty the water tray by pulling out in front from underneath, clean the filter by lifting up in back, and then plug it back in, and hit the reset button.
Posted on Sep 28, 2010
  • Kirk Augustin
    Kirk Augustin Sep 28, 2010
    If the times has hit stop, then you need to hit the timer key to release it.
  • 905 Answers
Posted on Sep 27, 2010
  • Sheldon Dedek Sep 27, 2010
    Hi Linda,
    Sorry that I can't fix your air conditioner, but I am mid-continent. The service charge would be a killer!
    If the manufacturer isn't of any help regarding spare parts, you can use a cord that is intended for another air conditioner. As long as the cord matches the voltage (120v, 15amp), it will work as a replacement. You want to retain the GFCI functionality though.
    The power cord itself is not difficult to replace. But, it will involve disassembling the air conditioner far enough to get to the connections. Alternatively, take the air conditioner to an appliance shop, and they may be able to change the GFCI plug itself, leaving the original cable. That would be the easiest solution, and they can also take a look at it overall, and let you know of any problems that might be arising as well. There is usually a minimum labor charge, might as well get your money's worth.
  • Sheldon Dedek Sep 28, 2010
    You might be able to. Fixya does have a repair / service directory. www.fixya.com/repair and put in your city
Is there any kinds of problems with this air conditioner
Here are some reviews and questions that have already been asked on Fixya. any appliance that is only used for a few months of the year and then rests for months is going to exhibit some problems eventually. Usually just a matter of getting an AC engineer to add some more refrigerant gas.
  • Amazon.com: Customer Reviews: Arctic King MWK-06CRN1 ... www.amazon.com/Arctic-King-MWK-06CRN1-BJ7-Window-Mounted/product... Find helpful customer reviews and review ratings for Arctic King MWK-06CRN1-BJ7 6,000 BTU Window Mounted Air Condit at ... COOL AIR coming out of the Artic King.
  • Amazon.com: Customer Reviews: Arctic King MWK-05CMN1 ... www.amazon.com/Arctic-King-MWK-05CMN1-BI7-Window-Mounted/product... Find helpful customer reviews and review ratings for Arctic King MWK-05CMN1-BI7 5,000 BTU Window Mounted Air Condit at Amazon.com. Read honest ... by Arctic King...
  • Review of my Arctic King 5,000 BTU Air Conditioner - YouTube www.youtube.com/watch?v=oaB2CPeZLTs
    • BY GOLDENSONIC08
    • 7 MIN
    • 20K VIEWS
    2014-06-09 · Video embedded · Just a quick review of my Arctic King WWK-05CRN1-BI7 5,000 BTU air conditioner.
  • Arctic King 10,000 BTU Energy Star Window Mount Air ... https://jet.com/product/Artic-King-10000-BTU-HomeOffice-Window... This Arctic King Air Conditioner is designed to be installed in a standard double ... This 10,000 BTU window mount Arctic King Air Conditioner is one of the most ...
  • How to Repair Window AC ' eBay www.ebay.com > ... > Heating, Cooling & Air > Air Conditioners A window-mounted air conditioning unit can be a lifesaver for anyone in ... How to Repair Window AC. ... Arctic King 8,000 BTU Energy Star Window Room Air Conditioner ...
  • ACE Artic King Window Mount Air Conditioner 5,000 BTU ... www.fixya.com > Forum > Air Conditioners > ACE Recent ACE Artic King Window Mount Air Conditioner 5,000 BTU Model MWK-05CMN1-B, 1 ea questions, problems & answers. Free expert DIY tips, support, ...
  • ACE Air Conditioner Problem Support, Troubleshooting Help ... www.fixya.com > Forum > Air Conditioners ... Manuals & Customer Service for ACE Air Conditioners. ... ACE Artic King Window Mount Air Conditioner 5,000 BTU Model MWK ... ACE Artic King Window Mount Air...
  • Jun 09, 2016 | ACE Artic King Window Mount Air...
    I have a Delonghi portable a/c unit its a pinguino
    PF = Power Failure. May need to have a look inside for a loose connection etc.
    Sep 11, 2014 | Heating & Cooling
    There is an exhaust switch on the front of the unit. (open or closed position). When should each be used?
    exhaust when you want to change air inside room more than you want cooling and dehumid efficiency. It ports air to outside, to be replaced by air from the outside (often from elsewhere in house, rather than via the AC unit). Does that answer it?
    May 02, 2014 | Arctic King 10,000 BTU Slide Casement Air...
    My LG portable AC Model #LP1111WXR wouldn't turn off had to unplug it. Now won't turn on.
    Unplugging the unit lets the tiny computer like microprocessor reset--means problem is in the brain of the unit or its power circuit.
    Jun 14, 2012 | LG 11,000 BTU PortabAir Conditioner -...
    AC was cooling fine. Now, won't cool room even though cool air comes out. Exhaust hose is extremely hot.
    Check filter, if you have a 5000BTU unit (small) and it is extremely hot, then it wont work great for a big room. BTU is the rate of what the AC will put out. 5000 BTU is good for a small single room. 10,000 will cool a bigger room and 18,000 btu is meant to cool a home.
    Jul 07, 2010 | Whirlpool ACP102PS Portable Air...
    Frigidare window air conditioner with remote control about 3 yrs old. All controls seem to be working except when the energy saver mode is suppose to shut down the unit / the display goes dark but the...
    Hello, I can assist you.
    If the unit is supposed to turn off and it doesn't, it will be necessary to check several things.
    • First, is the unit cooling properly? See the section entitled "The air is cool but doesn't seem cold enough."
    • Next, is the temperature of the room adequately cool? If the room temperature is cold enough try setting the thermostat to a higher temperature. If the unit then seems to work properly leave the thermostat set to the higher temperature.
    • If the unit is cooling properly when it is turned on and the room is not cool enough the problem is probably that the unit is trying to cool an area that is too large for its capacity. Use the following chart to find the appropriate size air conditioner to use:
    AREA TO BE COOLED / CAPACITY (BTU/HR)
    100 to 150 square feet = 5,000
    150 to 250 square feet = 6,000
    250 to 300 square feet = 7,000
    300 to 350 square feet = 8,000
    350 to 400 square feet = 9,000
    400 to 450 square feet = 10,000
    450 to 550 square feet = 12,000
    550 to 700 square feet = 14,000
    700 to 1000 square feet = 18,000
    If the room is heavily shaded, reduce needed capacity by 10%
    If the room receives a lot of direct sun, increase needed capacity by 10%
    Add 600 Btu/Hr for each person in the room if there are more than two people
    If the unit is for a kitchen, increase the capacity by 4,000-6,000 Btu/Hr.
    If the room size is too big for the air conditioner you have two possible choices. Either decrease the room size by shutting some doors or partitioning off an area of the room. Or, increase the BTU of the air conditioner for that room by installing a different air conditioner with a higher BTU rating.
    Aug 02, 2009 | Heating & Cooling
    The 10,000 BTU portable room a/c unit is not running cold enough
    Make sure your vent is closed. check the filter to see if its clean. If you run the a/c you can check your evaporator to see if you have condensation or does it freeze up?
    Make sure you have your unit on early in the morning. If you turn it on in the afternoon the humidity might be too much and it will take along time to cool down.
    Try those things if that doesnt work then you need a service call.
    Jul 10, 2009 | Whirlpool ACP102PR Portable Air...
    How large a room does a 10,000 btu air conditioner cool
    What size unit do I need for my room? Use the following chart to find the appropriate size air conditioner to use:
    if this helps please vote me a fix ya
    Jul 21, 2008 | Heating & Cooling
    Pinguino pac-166 not cooling enough
    CHECK AND CLEAN THE DUST FIELTER AND ALSO CHECK THE BLOWER THEN TRY IT
    Jul 06, 2008 | DeLonghi Pinguino PAC-02 Air Conditioner
    DeLonghi Pinguino PAC-210 Air Conditioner Logo
    158 people viewed this question
    Top DeLonghi Heating & Cooling Experts
    Paul Carew
    Michael Youngman
    Michael Youngman
    Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
