Question about Hampton Bay AC434-NI Ceiling Fan
I need to know how to connect wires for ceiling fan Hampton Bay model #crc 552 nm (ch) pb Coming from my ceiling are black/white/red wires Fan has blue/white/black wires. Fan won't work but, I want to have lights come on.
    Sergeant:
  • 270 Answers
If you have a single switch for the outlet (I mean no separate switch for the fan) then on your fan you couple the blue and black wire and couple it to the black out of your outlet. The white (hot lead) to the white on your fan.
The red wire out of your house outlet may be for another control, but you should also ground the fan.
Use an electrical twist CAP for the red wire.
This configuration will turn everything on the fan and lights and allow you to use the pull cords to control the features.
NEVER LEAVE EXPOSED WIRES anywhere. Even if the insulation does not expose the wire, cap it.
(ps, I have this fan, and installed. It is heavy so make sure you have good support. After installation, make sure you balance the blades.)
good luck.
Posted on Sep 27, 2010
CONNECTING WIRES FROM CEILING TO WIRES IN CEILING
Don't know that fan because it's a low-end store brand, But, if it has no remote;
White to white
black to black
blue to red ( usually)
If no red wire in ceiling then put black & blue to black house wire.
Sep 06, 2013 | Hampton Bay 24002 Ceiling Fan
I have a red, black, white, copper wire coming from the cieling. I have a hampton bay remote with orange, two sets of black, two sets of white, and a green wire. I connected everything exept the red...
this is for a three way switch do you have two switch if so hook the red to the orange and black to black and white to white make sure you ground it to the fan and everthing shoul work fine good luck
Aug 08, 2011 | Hampton Bay 24002 Ceiling Fan
Just installed a new Hampton Bay 36" ceiling fan.
I suggtes recheck your wires, could use this wiring guide (click image for zoom)... support/t9590572-hunter_fan
Jun 29, 2011 | Hampton Bay 24002 Ceiling Fan
Trying to connect a ceiling fan light kit. I connected the blue wire from the fan kit to the black wire in the light kit and then connected the white wire from the fan kit to the white wire in the light...
Those connections sound OK ,, now you have to go to the canopy and see if all the wires for the fan/light are connected to a house wire. If there are two switches , then the blue fan wire would connect to the red wire .. it may be capped off in the ceiling. If there is only one control switch , then the blue wire from the fan will connect to the same ceiling wire as the black fan wire does.
Please Vote !!
May 30, 2010 | Hampton Bay 24002 Ceiling Fan
How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Jul 05, 2008 | Hampton Bay 04383 Calibre Ceiling Fan
2 many ceiling wires
ok lori connect the fan wires like this-----white from fan to both white wires---blue from fan to red---black from fan to both black wires then copper wires to a ground.let me know.
Jan 15, 2008 | Hampton Bay 46056 Callaway II Ceiling Fan
Installing ceiling fan with two switches AND a remote
in your ceiling box should be three wires. a red goes to the three way switches, a black goes to the hot and the white is the neutral. the fan wires are black, blue and white. since you have a remote, connect the [fan] blue & black together with the [line] black. connect all white wires together. the remote will now ramp up your lights from off to full on and the fan remote will let you choose lo med high and off. just tape up the red wire in the box.
Aug 17, 2007 | Hampton Bay 04383 Calibre Ceiling Fan
Problem with Hampton Bay 54 In. Flemish Pewter Ceiling Fan With Heater
did you check the circuit breaker to see if its tripped?im assuming the voltage rating of the wires your decribing are 110 volts and the fan likewise.the white wire could possibly be a neutral wire,meaning you should hook up the red and black wire.let me know
Jul 30, 2007 | Hampton Bay 54 In. Flemish Pewter Ceiling...
Hampton Bay AC434-NI Ceiling Fan Logo
335 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
