Aero Lite 10/100 Nas Enclosure - Computers & Internet
How to interpolate with 991MS
i am giving the key input with an example..
example-
at 0, value is 300
at 50, value is 270
so how much at 30...
On 991MS,
Go in Reg mode, for doing that : press Menu,Menu, 2
Enter the values as follows,
0,300 and press M+ key on the calci
(Note: there is a "," in between 0 and 300)
then enter the following,
50,270 and press M+ key
now enter the following input exactly as displayed below:
(30) shift 2 > > > 2 =
you will get the answer as 282.
I hope you got it!!!
LOFT!!!
Feb 22, 2011 | Casio FX-115ES Scientific Calculator
I do not have to driver for the D-Link DNS 323 2-Bay Enclosure
You have not said what you are using it on, is it windows xp, 7, linux? etc.
Feb 01, 2011 | D-Link Dns 323 2-Bay Network Storage...
How do i reset LG N2B1DD2 to factory default?
This is for some reason called "Enclosure mode" on this LG nas.
Read manual page 18 (find it on google) and it will reset to default
Jan 26, 2011 | LG N2B1DD2 2TB Super Multi NAS with Bluray...
I had to replace my router and I now cannot see the dlink enclosure. I wanted to get the IP so I can reconfigure the IP address but like I said I cannot seem to get the device to show up on my belkin...
You can try a couple of things, easy thing is to reset the NAS server by unplugging it and allowing it release its leased IP address, assuming that it is setup for DHCP. Once this is reset it should grab another IP address. If you remenber setting it up for a static IP, then you could do a google search for an IP scanner http://www.radmin.com/products/utilities/ipscanner.php or find one that you are comfortable with download and install look for device on your network that will give you your IP to the NAS server. Good luck
Nov 28, 2010 | D-Link DNS-321 Network Attached Storage...
D-Link DNS 323 Bittorrent doesn't start
Make sure that the ports for the application are open in both your modem and router
Dec 29, 2009 | D-Link Dns 323 2-Bay Network Storage...
I try to connect DLINK dns 323 to WD TV by USB cable but it not work how can i solve this
The USB port on the D-Link DNS 323 NAS is for a printer only. It won't work with your WD TV. Your best bet would be to plug the WD TV into a PC that is connected to your network along with the D-Link DNS 323 NAS and serve your media files that way.
Sep 04, 2009 | D-Link Dns 323 2-Bay Network Storage...
I've bought the Sumvision SATA net-box NAS enclosure, installed hard drive as described, but I cannot see the web interface for setting up the device. Manual is in very bad english and suggest allocating...
There's a discussion about some problems relating to this enclosure at http://forums.ebuyer.com/showthread.php?t=24636 and you may be able to get some help from the contributors there.
Jun 27, 2009 | Computers & Internet
Iomega StorCenter 1TB (2x500gb) no longer working with AFP
are the users correct? can you acces the storcenter web?
perhaps there's something incorrect after the halt.
Dec 26, 2008 | Iomega StorCenter Pro NAS 150d (33612) 500...
Computers & Internet Logo
207 people viewed this question
David Payne
David Payne
